DLS - LM Audio Best Price !!
Results 1 to 10 of 13
  • Short URL:  http://modifika.si/215145
    Audio For Live
    Post DLS - LM Audio Best Price !!
    Model : LM Audio - LM 3200.1D (Class D)
    1 Channel Class D POwer Amplifier
    1 x 3000 Watt (1 Ohm)
    1 x 700 Watt RMS
    Price List 4.750.000
    LM AUDIO Vintage Series T8
    * 4 Channel Vacuum Tube Power Amplifier
    * 4 x 75 Watt (4 Ohms) - 13.8VDC
    * 4 x 90 Watt (2 Ohms) - 13.8VDC
    * 4 x 85 Watt (4 Ohms) - 14.4VDC
    * 4 x 110 Watt (2 Ohms) - 14.4VDC
    * 20 Hz - 20 kHz Frequency Response
    Price List 3.950.000
    Scandinavia 1 (Tweeter)
    Description / type 28 mm soft dome tweeter
    Impedance 4 ohm
    Recommended amplifier 50 - 200 Watt
    Frequency range 1 kHz - 30 kHz
    Fs - Resonant frequency 655 Hz
    Sensitivity 93 dB
    Outer diameter 95 mm / 3,74"
    Mounting hole 75 mm / 2,95"
    Mounting depth 33 mm / 1,3"
    Price List 3.100.000
    Scandinavia 3 (MIDRANGE)
    Description / type 3" midrange speaker with Kevlar cone
    Impedance 4 ohm
    Frequency range 80 Hz - 16 kHz (in axis)
    Fs - Resonant frequency 80 Hz
    Sensitivity 84 dB
    Outer diameter 84 x 84 mm / 3,31" x 3,31"
    Mounting hole 78 mm / 3,25"
    Mounting depth 45 mm / 1,77"
    Recommended installation Open air or 1 litre (0,035 cuft) sealed enclosure
    T/S parameters
    single V/C
    Fs 80 Hz Re 3,7 Ohm Qms 2,37
    Vas 1,3 liter Vas 0,046 Cuft Qes 0,69
    Qts 0,54 Sd 38 cm² BL 4,07
    Price List 3.400.000
    Scandinavia 6.2 (Passive)
    Impedance 4 ohm Passive
    Description / type 2-way filter with slope: LP 6 dB / HP 12 dB
    Crossover point (Hz) 4 kHz
    Dimension (W x D x H) 145 x 85 x 45 mm / 5,7 x 3,35 x 1,77"
    Price List 2.200.000
    Scandinavia 6
    Description / type 6,5" mid bass driver
    Outer diameter 165 mm / 6,5"
    Impedance 4 ohm
    Frequency range 30 Hz - 1000 Hz
    Fs - Resonant frequency 39 Hz
    Sensitivity 86,7 dB
    Magnet size 108 x 15 mm
    Voice coil 50 mm / 2"
    X-max +- 8 mm / 0,31" linear excursion
    Mounting hole 140 mm / 5,51"
    Mounting depth 67 mm / 2,63"
    T/S parameters
    single V/C
    Fs 39 Hz Re 3,4 Ohm Qms 2,59
    Vas 18,5 liter Vas 0,65 Cuft Qes 0,38
    Qts 0,33 Sd 129 cm² BL 6,71
    Price List 4.850.000
    Scandinavia 6.2 (2-Way)
    Impedance 4 ohm
    Description / type 6,5" mid bass / midrange driver
    Frequency range 50 Hz - 6000 Hz
    Fs - Resonant frequency 42,7 Hz
    Sensitivity 85,4 dB
    T/S parameters
    single V/C
    Fs 42,7 Hz Re 3,7 Ohm Qms 2,97
    Vas 15 liter Vas 0,53 Cuft Qes 0,54
    Qts 0,45 Sd 127 cm² BL 6,17
    And Many More Product DLS - LM Audio
    Contact Person (021-50121264)
    YM : ieluphyoe2002@yahoo.com
    3 Wks 22 Hrs 29 Mins 43 Secs
    bro.. bole pm harga plss...
    thankss...
    thankss...
    Audio For Live
    Quote Originally Posted by michael_andry_s View Post
    thankss...
    Item Barang yg Mana Bos nanti saya PM ke anda Thx
    untuk speaker2 nya bro... kasi aj beberapa alternative nya...
    sekalian power yg tube, DLS & LM
    thank u very much...
    bos, tolong PM 3way DLS yah. thx
    Audio For Live
    Quote Originally Posted by dion789 View Post
    Ok Bos nti saya PM ke anda thx
    Audio For Live
    Untuk Informasi Langsung aja Telp ke Nomor saya coz saya agak jarang Online di Mod.com
    Thx
    Audio For Live
    Info Buat Product DLS Langsung aja bos
    www.dls.se
    www.x-program.com
    Audio For Live
    UP
    UP
    UP
Mega Glodok Kemayoran MBtech
  1. Replies: 196
    Last Post: 12th March 2015, 21:58
  2. FS: RCA Ramm Audio S3 & S20 , Cheap Price!!
    By VellFire in forum Cables & Interconnects
    Last Post: 1st May 2012, 08:23
  3. WTS : sub JL audio 10w6v2 (update price)
    By M 0 dif in forum Speaker - SubWoofer
    Last Post: 16th September 2010, 21:01
  4. WTS: Audio Stuff USED for 4 Months, DROP PRICE
    By netekdenkow in forum Bursa Audio Lainnya
    Last Post: 5th August 2010, 22:39
