wts : rockford fosgate punch 150s
Results 1 to 10 of 24
  • Short URL:  http://modifika.si/214966
    Central Java
    3 Hrs 23 Mins 9 Secs
    wts : rockford fosgate punch 150s murah
    power rockford fosgate 150s SOLD
    2ch
    bekas angkat treo tsi 10" 2biji
    * Stereo or bridged mono output
    * Tri-Way capable
    * 37.5 watts RMS x 2 at 4 ohms
    * 75 watts RMS x 2 at 2 ohms
    * 150 watts RMS x 1 at 4 ohms in bridged mode
    * MOSFET power supply and output devices
    * 80 Hz low-pass/120 Hz high-pass crossover, 12 dB/octave
    * TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise between the head unit and the amp
    * NOMAD advanced protection circuitry monitors temperature, voltage, current and impedence, and provides "intelligent" shut-down protection without limiting system performance
    * TRANS•ana circuit designs keep voltages low and signal paths simple in the pre-amp section, for minimum distortion and maximum musicality
    * Switchable Punch Bass (0,+6,+12 dB boost) at 45 Hz
    * Speaker- and preamp-level inputs
    * Dimensions: 10-3/8"W (6-11/16" without endcaps) x 2-7/16"H x 9-7/8"D
    brgnya mulus,cm aksesoris sayapnya ilang<lambang rfnya aja masi diplastik,sudah perna servis ganti power supply,skr sdh nda ada mslh
    SOLD
    berminat hub 08174151010
    ym mummy_son_ica@yahoo.com
    Central Java
    up
    up
    up
    up
    Central Java
    up
    up
    up
    up
    SuRoBoYo
    3 Days 14 Hrs 33 Mins 37 Secs
    bantu up gan......
    Central Java
    ao power bagus harga murah
    Central Java
    up
    up
    up
    up
    Central Java
    up
    upup
    up
    Central Java
    up
    up
    up
    up
    up
    up
    Central Java
    up
    up
    up
    up
    Central Java
    up
    upup
    up
    up
  1. WTS : ROCKFORD FOSGATE PUNCH 250aII
    By boni82 in forum Power Amplifier
    Last Post: 19th May 2012, 09:08
  2. WTS : ROCKFORD FOSGATE PUNCH 301 (900 WATTS)
    Last Post: 28th March 2012, 12:59
  3. WTS: Rockford Fosgate Punch 360.6
    By noldie in forum Power Amplifier
    Last Post: 12th June 2010, 16:44
  4. FS: Rockford Fosgate 12' SUB Punch P1 + Box SOLD !!!
    By coal_nete in forum Speaker - SubWoofer
    Last Post: 12th June 2009, 13:58
  5. mau nanya ttg rockford fosgate (punch) ????
    By chediska in forum Diskusi Subwoofer
    Last Post: 28th July 2006, 21:52
