wts power rockford 2ch n sub treo sepasang
Results 1 to 5 of 5
  • Short URL:  http://modifika.si/213921
    Central Java
    3 Hrs 23 Mins 9 Secs
    jual sub 10 in sepasang treo single coil 4ohm
    spek nya
    The Treo Series improved subwoofers offer world-class sound quality with a wide spectrum of musical styles. High efficiency means maximum sound even with little amplifier power. The Treo Series improved subwoofers were designed with the same principles and technologies as our competition woofers. At Treo Engineering we never settle.
    The Treo Series improved subwoofers come into 2004 with a host of improvements. The 2004 models feature new cosmetics with siler powder-coated baskets, a new wrap-around concealer gasket with an embedded TREO logo. The speaker has also been upgraded with a new spider with integrated tinsel leads and a former ring that reinforces the critical cone-spider-former joint.
    Features:
    Available in 10, 12, and 15 inch diameters.
    Precision CNC-machined low-carbon steel motor structure (114oz on TSi10.x & TSi12.x, 226oz on TSi15.x)
    Powerful and durable Strontium ferrite magnet with a protective magnet jacket
    Durable and attractive black oxide-treated motor structure
    Bumped back plate and high-flow large diameter pole vent keeps it cool
    High excursion motor structure and suspension design
    Wide three-layer UV-treated foam surround
    Resin-impregnated poly-cotton spider for increased cone control
    Cold-rolled stamped steel basket with rolled edges
    Mica-impregnated polypropylene cone and dustcap
    2.0 inch high-temperature Aluminum voice coil with integral heatsink on TSi10.x & TSi12.x
    3.0 inch high-temperature Aluminum voice coil with integral heatsink on TSi15.x
    200 Watts RMS Power Handling on TSi10.x & TSi12.x
    350 Watts RMS Power Handling on TSi15.x
    Available with single 4 and 8 Ohm voice coils for maximum installation flexibility
    Optimized for very small to medium sealed, vented, and bandpass enclosures
    Built by hand in the United States from domestic and imported components
    foto
    SOLD to bos deni
    power rockford fosgate 150s
    2ch
    * Stereo or bridged mono output
    * Tri-Way capable
    * 37.5 watts RMS x 2 at 4 ohms
    * 75 watts RMS x 2 at 2 ohms
    * 150 watts RMS x 1 at 4 ohms in bridged mode
    * MOSFET power supply and output devices
    * 80 Hz low-pass/120 Hz high-pass crossover, 12 dB/octave
    * TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise between the head unit and the amp
    * NOMAD advanced protection circuitry monitors temperature, voltage, current and impedence, and provides "intelligent" shut-down protection without limiting system performance
    * TRANS•ana circuit designs keep voltages low and signal paths simple in the pre-amp section, for minimum distortion and maximum musicality
    * Switchable Punch Bass (0,+6,+12 dB boost) at 45 Hz
    * Speaker- and preamp-level inputs
    * Dimensions: 10-3/8"W (6-11/16" without endcaps) x 2-7/16"H x 9-7/8"D
    brgnya mulus ,cm aksesoris sayapnya ilang
    pending dl
    berminat hub 08174151010
    ym mummy_son_ica@yahoo.com
    Central Java
    up
    up
    up
    up
    up
    Central Java
    up
    up
    up
    up
    klaten
    bantu sundul boss
    Central Java
    bantu sundul boss
    thankss bos danny
MBtech Venom 300x250
  1. Replies: 5
    Last Post: 6th December 2011, 22:22
  2. Replies: 4
    Last Post: 26th November 2011, 00:00
  3. Replies: 7
    Last Post: 10th February 2011, 13:23
  4. HELP ME!!! Pilih sub apa nih?? Rainbow,Treo,Rockford???
    By Hepi3friend in forum Diskusi Subwoofer
    Last Post: 14th December 2010, 18:04
  5. wts sub treo sepasang dan power rockford
    By Eka_Hadinata in forum Speaker - SubWoofer
    Last Post: 17th September 2010, 23:37
