FLAGSHIP Vintage Collector Item Nakamichi CR-7 (1986-1993)....................4,35jt
Results 1 to 6 of 6
  • Short URL:  http://modifika.si/212819
    Thumbs up FLAGSHIP Vintage Collector Item Nakamichi CR-7 (1986-1993)....................4,35jt
    FLAGSHIP Vintage Collector Item Nakamichi CR-7 (1986-1993)..........4,35jt
    Nakamichi CR-7, Discrete Head Cassette Deck of the world-class!
    Retail price in Germany in 1988 was: 4000,- DM
    Specifications:
    Manufacturer: Nakamichi, Tokyo Japan
    Heads: 3 (delete head x 1, recording x 1, playback head x 1)
    Motors: belt drive: brush-free, schliz-free, core-free DD FG servo motor (capstan drive) x 1, mechanics: DC motor (cam drive) x 1 DC-motor
    Voltage and frequency.: 120/220-240, 220 or 240 V AC, 50/60 Hz
    Power consumption: max. 45 W
    Tape speed: 4.8 cm/sec. + 0.5%
    Wow and flutter: less than + 0048% peak less than 0027% (RMS)
    Frequency response: 20 Hz - 20000 Hz + 3 dB
    Dolby: B, C
    THD: less than 0.8%
    Dimensions: 435 x 135 x 306 mm
    Weight: 9 kg
    Summary:
    The Nakamichi CR-7A is a marvel of audio engineering with superior sonic qualities. This cassette deck is very simple to use with its auto-azimuth fine tuning, auto-calibration of any tape formulation, easy to read, accurate flourescent meters, real-time tape counter, and excelent build quality. The sound you get from this machine is superior to the CD format, yes I said it, superior to CD in terms of depth of soundstage, inner detail, overall smoothness, ambience, and the ability to bring out every nuance of music on a recording. Add to that the wireless remote, which allows you to control the azimuth of the tape head from your armchair, and easy tape setup. Just insert a tape, press "auto cal," and after a few seconds, the ready light will tell you it's time to enjoy some good music. Some people say that the CR-7A sounds superior to the Dragon, and others say the opposite, but I think each deck has its own distinctive sound. I have owned the Dragon also, and I can tell you that the Dragon excels in the top-end of the frequency spectrum with its 20-22 kHZ response, whereas the CR-7A (20-21kHZ) excels more in a fuller, rounder bottom-end. Also, as I read in one article and experienced first-hand for myself, the Dragon's high-end frequency response sounds a bit softer and more delicate than the CR-7A's. Personally, I think it really comes down to which sound your ear prefers. I think there is a saying that goes, "doctors prefer CR-7A's, and lawyers prefer the Dragons." Whichever you choose, you obviously cannot go wrong because both machines will not dissapoint, and will leave a big smile on your face every time you turn them on. The bottom line here folks is, neither one stands head and shoulders above the other, instead, both decks are superb pieces of equipment with their own distinct merits that will not only give you pride of ownership, but tremendous musical enjoyment for many years to come. Enough said.
    * Discrete Head Cassette Deck
    * Head(s): '3'
    * Head type(s): 'R-3L, P2H-3L, E-4F'
    * Noise reduction: 'B, C'
    * Tape monitor
    * Meters: 'Fl24 segments'
    * Tape: 'EX, SX, ZX'
    * Counter: 'Digital, Real-time, 4 digits'
    * Motors: '4'
    * Direct drive
    * Double capstan
    * Pressure pad lifter
    * Capstan motor: 'Fg servo'
    * Playback head azimuth adjust: 'Manual'
    * Bias calibration: 'Auto'
    * Level calibration: 'Auto'
    * Output level adjust
    * Headphones
    * Master fader
    * Filter(s): 'Mpx/subsonic'
    * Record mute
    * Remote control: 'WIRELESS, RM-7C'
    * Connectors: 'Gold i/o'
    * Color: 'Black'
    * Usage: 'Home'
    * Dolby IC: 'TEA0652'
    * Connectivity
    o System Remote-Control Input
    o Wireless Remote Control
    o Headphones
    o RCA Input/Output Connectors
    o Wired Remote Control
    * Heads
    o 3 Head Design
    o Seperate Record and Playback Heads
    * Noise Reduction
    o Dolby-B Noise Reduction
    o Dolby-C Noise Reduction
    o MPX Filter
    o Subsonic Filter
    * Calibration
    o Auto Bias Calibration
    o Auto Level Calibration
    o Manual Playback Azimuth Correction
    o Auto Playback Azimuth Calibration
    * Preamplifier
    o Output-Level Control
    o Individual Input Level Controls
    o Master Record Level Control
    * Operation
    o Timer Recording/Playback
    o Auto-Fade
    o Memory Repeat
    o Memory Stop
    o Real-Time Tape Monitoring
    o Record Mute
    o Full Logic Transport Control
    o Electronic Master Fader
    * Transport
    o Pressure Pad Lifter
    o Dual-Capstan Transport
    o Slack-Tape Takeup
    o Direct Drive (Capstan)
    o Mechanical Tape Loading
    o Auto Shutoff (Full)
    * Special Finish
    o Gold Plated Input/Output Jacks
    * Display
    o 4-Digit Digital Counter
    o Linear Tape Counter
    o Peak Hold
    o Digital Peak-Reading Meters
    * Tape
    o Automatic Tape Equalization
    o 2-Position Equalization Selector
    o Chrome Tape Capability
    o Normal Tape Capability
    o Metal Tape Capability
    o Manual Tape Type Selection
    * Indicators
    o Cassette Back Light
    o Dolby B
    o Dolby C
    o Fast Forward
    o Play
    o Pause
    o Stop
    o Rewind
    o Chrome Tape
    o Metal Tape
    o Normal Tape
    o Fader Down
    o Fader Up
    o Record Mute
    o Source/Tape
    o MPX
    * Exterior
    o Front Loading
    o Orientation Left
    * General
    o Stereo
    Specifications can be found at http://www.vintagecassette.com/Nakamichi/CR-7.
    3 Wks 1 Day 9 Hrs 13 Mins 45 Secs
    UP buat home high end... ANALOG nii...
    thanks yach bos andry............
    up..................
    UP lg... pure analog...
NGK Busi GT Radial
  1. Collector Item NAKAMICHI EC-302 Kondisi NEW OLD STOCK !
    By MR.GASOLINE in forum Bursa Audio Lainnya
    Last Post: 26th May 2012, 22:59
  2. Wts Dac 100 Nakamichi NOS, lengkap dus, collector item.
    By ric_signature in forum Head Unit & Processor
    Last Post: 27th July 2010, 17:34
  3. Wts Dac 100 Nakamichi NOS, lengkap dus, collector item.
    Last Post: 25th July 2010, 20:25
