Hi-end LUXMAN CM-2100 Highly Underated 2ch 2 x 100W Amplifier...(sold,thanks modcom)
Results 1 to 10 of 16
  • Short URL:  http://modifika.si/212273
    Hi-end LUXMAN CM-2100 Highly Underated 2ch 2 x 100W Amplifier.................sold
    New price $ 3.300
    CM-2100 equipped with automotive power amplifier adopting the ODNF method for the first time in the world
    さらばLUXMAN CM2100 そして・・・
    特濃オーディオネタです~
    私は約20年前から自作→ショップ→自作と何回か繰り返し
    約10年前にカーオーディオの限界を感じソコソコにし
    ホームオーディオの買換えを考えていた時に
    確か大阪オートメッセでこのアンプと出会いました!!
    それがLUXMAN CM2100(^^♪
    LUXMAN のデモカー(確かSPはKEF?)を聴いた瞬間(゜o゜)スゴイやん!!
    音離れが抜群で引き締まったベースがグイグイ迫ってくる感じ&
    ボーカルの色っぽいさやピアノのしなやかさ・・・アノ衝撃は今でも覚えています♪
    The CM-2100 was the first model of car audio power amplifiers equipped with the new ODNF feedback circuit after many years of research. The CM-2100 was accepted with some degrees of surprise as a product giving car accessory fields sound value similar to home audio units and is a reference model in many specialty shops and magazines.
    For sale A Limited Edition Crafted by Lux Corporation , Luxman CM 2100 dual mono 2x100 @ 4 ohm ( very under rated ). one of the most natural sounding car amplifier on planet !!!
    Luxman CM-2100
    2 x 100W @ 4 ohms (0.005% THD)
    Weight: 21.6 lb (9.8 kg)
    Specification
    # Continual effective ability: 100Wx2ch (4 ohms) 400Wx1ch (4 ohms and MONO) / 1600Wx1ch (1 ohms and MONO, instant maximum)
    # Input sensitivity impedance: NORMAL (LOW) 0.5V/20K ohms (HIGH) 2.0V/3.1K ohms DIRECT0.5V/25K ohms
    # signal-noise ratio (rated output): Above 110dB (IHF-A revision and input short circuit and DIRECT)
    # All the harmonic distortion factors: 0.005% or less (4 ohms, 1kHz and DIRECT) 0.008 or less (4 ohms, 20 - 20.0000Hz DIRECT)
    # Frequency characteristic: 20 - 20,000Hz (+0, −0.2dB and DIRECT) / 5 - 100,000Hz (+0, 0.2dB and DIRECT)
    # Damping factor: 100 or more (4 ohms, 1kHz and DIRECT)
    # Battery voltage: DC12V
    # Electric power consumption: 33.6W (2.8A, signal-less) / 354W (29.5A, 4 ohms and rated output)
    # Size: W480 x D302 x H76 mm
    Call
    081388575788
    klaten
    wuuiiihh...mantafff skali......
    Honoured Member
    Specnya bagus banget.....! Mantabz
    thanks banget yach bos danny n bro wendo........
    3 Wks 1 Day 19 Hrs 18 Mins 26 Secs
    mantappssssss............ UP lg buat high end.............
    UP dulu.. si Bozz lg on VACATION.. jd buyers harap bersabar dikit..
    thanks yach bos andry............
    UP lg......
    picture uploaded n sold...................
GT Radial NGK Busi
  1. Replies: 4
    Last Post: 4th May 2012, 03:49
  2. Replies: 14
    Last Post: 1st October 2010, 07:01
