Hi-end LUXMAN CM-2100 Highly Underated 2ch 2 x 100W Amplifier..................15jt
Results 1 to 10 of 15
  • Short URL:  http://modifika.si/212259
    Hi-end LUXMAN CM-2100 Highly Underated 2ch 2 x 100W Amplifier (sold,thanks modcom..)
    Hi-end LUXMAN CM-2100 Highly Underated 2ch 2 x 100W Amplifier.............sold
    New price $ 3.300
    CM-2100 equipped with automotive power amplifier adopting the ODNF method for the first time in the world
    さらばLUXMAN CM2100 そして・・・
    特濃オーディオネタです~
    私は約20年前から自作→ショップ→自作と何回か繰り返し
    約10年前にカーオーディオの限界を感じソコソコにし
    ホームオーディオの買換えを考えていた時に
    確か大阪オートメッセでこのアンプと出会いました!!
    それがLUXMAN CM2100(^^♪
    LUXMAN のデモカー(確かSPはKEF?)を聴いた瞬間(゜o゜)スゴイやん!!
    音離れが抜群で引き締まったベースがグイグイ迫ってくる感じ&
    ボーカルの色っぽいさやピアノのしなやかさ・・・アノ衝撃は今でも覚えています♪
    The CM-2100 was the first model of car audio power amplifiers equipped with the new ODNF feedback circuit after many years of research. The CM-2100 was accepted with some degrees of surprise as a product giving car accessory fields sound value similar to home audio units and is a reference model in many specialty shops and magazines.
    For sale A Limited Edition Crafted by Lux Corporation , Luxman CM 2100 dual mono 2x100 @ 4 ohm ( very under rated ). one of the most natural sounding car amplifier on planet !!!
    Luxman CM-2100
    2 x 100W @ 4 ohms (0.005% THD)
    Weight: 21.6 lb (9.8 kg)
    Specification
    # Continual effective ability: 100Wx2ch (4 ohms) 400Wx1ch (4 ohms and MONO) / 1600Wx1ch (1 ohms and MONO, instant maximum)
    # Input sensitivity impedance: NORMAL (LOW) 0.5V/20K ohms (HIGH) 2.0V/3.1K ohms DIRECT0.5V/25K ohms
    # signal-noise ratio (rated output): Above 110dB (IHF-A revision and input short circuit and DIRECT)
    # All the harmonic distortion factors: 0.005% or less (4 ohms, 1kHz and DIRECT) 0.008 or less (4 ohms, 20 - 20.0000Hz DIRECT)
    # Frequency characteristic: 20 - 20,000Hz (+0, −0.2dB and DIRECT) / 5 - 100,000Hz (+0, 0.2dB and DIRECT)
    # Damping factor: 100 or more (4 ohms, 1kHz and DIRECT)
    # Battery voltage: DC12V
    # Electric power consumption: 33.6W (2.8A, signal-less) / 354W (29.5A, 4 ohms and rated output)
    # Size: W480 x D302 x H76 mm
    Call
    081388575788
    JAKARTA
    1 Mth 3 Wks 3 Days 15 Hrs 49 Mins 9 Secs
    PERTAMAXXXXXX.... barang ajib niiihhh....
    PangkaL Paha
    2 Wks 5 Days 2 Hrs 7 Mins 58 Secs
    mantebbb pisan
    Jkt - Kisaran JakBar
    38 Mins 13 Secs
    Quote Originally Posted by b2okane View Post
    mantebbb pisan
    bentar lage bakalan nangkring di stream neh
    PangkaL Paha
    jiaah,,,, gosip aja nih si abang porno
    he.he.he.....,thanks yach bos nice,bos yulius n bos kane...
    up..........................
    sold,thanks modcom..............
    12 Hrs 32 Mins 7 Secs
    power mantab nih.
    udah sold ya.:eek::eek:
    cepet banget yak.
    pasti disikat om kane lg nih...
  1. Replies: 4
    Last Post: 4th May 2012, 03:49
