Digital Design CM-1 AB Class Monoblock kondisi 100% BARU Grsi 1 tahun...3,6jt
  • Short URL:  http://modifika.si/211099
    Exclamation Digital Design CM-1 AB Class Monoblock kondisi 100% BARU Grsi 1 tahun...3,6jt
    DDCM1 - Amplifier
    The C Series amps are our Go-To amps for most daily driving applications. The C amps offer good sound quality, install friendly features and high-end cosmetics at price points normally associated with budget, entry level offerings. These high value amps feature stable and reliable class AB circuits which are ideal for driving either full range or subwoofer applications.
    The CM1 amplifier has a single mission in life; to make ones life better through the harmonious bass lines. Everyone needs some nice bass in their life and we set out to make it as easy as possible to add bass to virtually any system. The CM1 delivers 1000 watts of class AB power, enough tight, hard hitting bipolar power to drive a subwoofer enclosure to panel flexing volumes or power through a wicked 6 string bass line.
    The CM1 is designed for easy installations and easy setup. The subsonic filter and low pass filters are built in and set at 30Hz and 80Hz respectively. This makes installations with OEM head units safe and bullet-proof. There is a remote gain port included for an optional controller.
    System Design
    The preamp section gives flexible versatility to accommodate many installation needs. Each channel of the C amps can be set for low pass filtered operation; high pass filtered or full range operation. Single channel and 2 channel amps have sub-sonic filters added in order to band pass the subwoofer range. Two or three amps can be combined to run 2-way or 3-way setups. One amp can be band passed for the sub, a second amp to run mid/high speakers. More complex 3 way systems can be setup for band passing dedicated mid-bass drivers or midrange drivers.
    Each pair of channels also feature a 12dB bass boost at 40 Hz. Single channel and 2 channel amps add optional remote gain controls.
    Class AB Designs
    The C amps use high quality Class AB designs with parts chosen for smooth and reliable operation. The PCBs are double sided, high grade epoxy in order to move current efficiently with excellent thermal management. Properly sized power supplies matched to over-designed output sections deliver strong transient response and tight bass. The C amps are meant to be True To The Source, to make your music or vibratory experience as close to the source signal as possible, and perform like this for years to come.
    Thermal Management
    The heat sink design of the new DD amps yields maximum dissipation for a given amount of length. Horizontal and vertical fins allow convection cooling from multiple mounting angles. Extra heavy heat sink rails, built into the rail corners, are used to carry heat away from the Mosfets and transistors. The output devices are mounted on the upper rail, below the top surface where heat can expand to both top fins and side fins. The transistor bank is situated toward the center of the amp so heat can outflow equally to both sides. The end panels are also vented to allow heat buildup to escape the PCB cavity.
    Great All Purpose Amps
    Having to choose between good performance and good pricing is no longer a decision one has to make. The C amps are well designed, use high quality parts, deliver good performance and offer great system flexibility. The C amps were not designed by a marketing department, not designed to highlight LED research into non-operational cosmetic compulsive Vegas induced lightshows or to claim hydroelectric output capability from a handful of actual parts. These are amps designed for good performance, amps we are happy to use in our own cars, and amps that will serve you well for a long time.
    Features
    * Murdered-Out power & speaker terminal blocks
    * Power & Protection indicator LEDs
    * No-hassle, preset subsonic & lowpass filters
    * 5-way protection circuit
    SPECIFICATIONS
    Series C
    Input Sensitivity 0.2V - 5V
    Preset Subsonic Filter 30Hz
    Preset Low Pass Filter 80Hz
    Tested Voltage 14.4
    Tested THD 0.02%
    Model CM1
    Cont Power at 4 ohm 350W x 1ch
    Cont Power at 2 ohm 650W x 1ch
    Cont Power at 1 ohm 1000W x 1ch
    Damping Factor >150
    Dynamic Power 2000W
    Efficiency thru Output 65%
    Dimensions - mm 244.5W x 54.3H x 340.0L
    Dimensions - inches 9.63W x 2.14H x 13.39L
    Signal to Noise >100dB
    Shipping Weight 13 lbs
    up........................
  1. Replies: 14
    Last Post: 3rd November 2010, 19:43
  2. Replies: 4
    Last Post: 23rd October 2010, 13:58
  3. [FS] DIGITAL DESIGN M3 MONOBLOCK (SOLD)
    By b2okane in forum Power Amplifier
    Last Post: 15th May 2010, 08:26
