WTS = TURBO KIT EVO IV V VI VII VIII IX 500HP = WTS
Results 1 to 10 of 73
  • Short URL:  http://modifika.si/210270
    = RedSpinner = Vermont Parkland Blok G3/11 BSD City = 081389599688 = RACING PARTS PROFIDER =
    Thumbs up WTS = TURBO KIT EVO IV V VI VII VIII IX 500HP = WTS
    WTS = ATP TURBO GT30R STAGE III 500HP KIT = WTS
    !!!...BARANG SECOND...!!!
    TURBO KIT INCLUDE:
    - TURBO GARRETT GT30R
    - TIAL SPORT EXTERNAL WASTEGATE
    - OIL AND WATER LINE FITTING
    - V BAND CONNECTOR CLAMP
    - DOWN PIPE
    - MID PIPE
    CALL ONLY...!!! NO PM AND SMS
    ALDO 081389599688
    SUDAH PERNAH KALAHIN FERRARI 360 DENGAN TURBO INI
    GT30R Stage III turbo kit for the EVO8 (aka "Stealth kit") Version 2
    After months of testing and development with the EVO8 engine combination, we have devised an upgrade system that is both elegant and simplistic while accepting no compromises in power potential or reliability. With POWER and RELIABILITY being the two key criteria for the development of the EVO8 turbo upgrade kit, we set out to test every possible hardware combination available. In our kit, you will find a system that integrates a plethora of unique but well designed components that compliment each other to achieve those two things that you care about most. In addition, in an attempt to exceed the customers' expections we have added other features such as a "direct-bolt-up" housing that overcomes the "reverse-rotation" issue, v-band downpipe discharge, bolt-up oil/coolant kits, etc. in order to make the installation process as simple as possible. All this while retaining the appearance of a completely stock engine bay.
    The kit hardware will consist of the following:
    - Garrett Prototype GT Ball Bearing turbo w/ATP Proprietary Housing with GT inspired High-Flowing Valute
    - Bolt-in design retains stock manifold - Retains stock heatshield for OEM appearance
    - Steel braided lines and fittings for oil/coolant connections
    - Tial 44mm External Wastegate
    - Stainless wastegate discharge tube with downpipe re-route
    - All mounting hardware, gaskets and CNC machined fittings
    - 500+ crank HP utilizing the ultra efficient GT3037S
    - 3.0" Stainless steel downpipe w/stainless O2 housing
    = REDSPINNER = ATP TURBO AUTHORIZED DEALER =
    GARRETT TURBO AND TIAL SPORT RACING GOODS
  2. SbcAgent
    surabaya
    1 Wk 21 Hrs 18 Mins 35 Secs
    ugh...........
    barang bagus nih.........
    Quote Originally Posted by audi0.murah View Post
    ugh...........
    Silahkan di beli bos atau di tawarkan ke temannya
    1 Wk 6 Days 4 Hrs 55 Mins 42 Secs
    Ball-bearing turbo...Manteb, Do! :smt023
    Tapi kasian jeroan mesin gw kalo pake turbo beginian, pistonnya bisa remuk berkeping2...Hehehhee =D
    kota parahyangan
    15 Hrs 22 Mins 15 Secs
    Bantu sundul pak
    Quote Originally Posted by Turbo_inside View Post
    FYI turbo ini di pake dengan jeroan standar boost 2 bar untuk harian
    Sampe sekarang mobilnya perfectly fine....!!!!!
    Quote Originally Posted by jonky_KOG View Post
    Bantu sundul pak
    THX Bos....!!!!
    LA
    14 Hrs 41 Mins 29 Secs
    Ngilerrrrrr ..!!!
    bantu sundul ah
    Honoured Member
    MODIFIKASI.COM
    1 Wk 22 Hrs 22 Mins 32 Secs
    SEreM..........................
    mantap do, bantu up ya
  1. 500hp Toyota Kijang Innova Diesel by Rev Engineering
    Last Post: 17th July 2014, 16:33
  2. FS mesin H22 TURBO 500HP++
    By [speed'Z] in forum Jual Beli Mesin Lainnya
    Last Post: 18th July 2011, 12:12
  3. FOR SALE MITSUBISHI EVO 8 MR 2004 - 500HP
    By skytecmissions in forum Mitsubishi
    Last Post: 16th May 2011, 16:21
  4. Replies: 116
    Last Post: 6th March 2011, 09:28
  5. FOR SALE : MITSUBISHI EVO 8 MR 04 500HP - NETT PRICE 550JT
    Last Post: 4th February 2011, 04:21
