SALE 1 Pair of Wavecor WF182BD03-01 midbass driver's 7" kondisi BARU..........2jt
Results 1 to 8 of 8
  • Short URL:  http://modifika.si/210017
    Wink SALE 1 Pair of Wavecor WF182BD03-01 midbass driver's 7" kondisi BARU..........2jt
    SALE 1 Pair of Wavecor WF182BD03-01 midbass driver's 7", die cast alu, 120 mm ferrite, cu cap, 1" VC, 4 ohm kondisi BARU.....2jt
    Price $276.00
    The 7 transducers WF182BD03 (4 ohm) and WF182BD04 (8 ohm) were designed as high performance bass and midrange units for monitors and high-end hi-fi speakers. They offer outstanding deep bass performance and dynamic and detailed midrange..
    FEATURES
    * Balanced Drive motor structure for optimal drive force symmetry resulting in largely reduced 2nd order harmonic distortion
    * Copper cap on center pole to reduce voice coil inductance and to minimize variations in voice coil inductance as a function of voice coil position
    * Black coated semi-air-dried paper cone
    * Rigid die cast alu chassis with extensive venting for lower air flow speed reducing audible distortion
    * Vented voice coil former for reduced distortion and compression
    * Vented center pole with dual flares for reduced noise level at large cone excursions
    * Heavy-duty black fiber glass voice coil former to reduce mechanical losses resulting in better dynamic performance and low-level details
    * Large motor with 1 voice coil diameter for better control and power handling
    * Built-in alu field-stabilizing ring for reduced distortion at high levels
    * Low-loss suspension (high Qm) for better reproduction of details and dynamics
    * Black motor parts for better heat transfer to the surrounding air
    * Conex spider for better durability under extreme conditions
    * Gold plated terminals to ensure long-term trouble free connection
    Wavecor WF182BD03-01 (ea.) midbass driver's specifications
    Nominal size 7 [inch.]
    Nominal impedance 4 [ohm]
    Recommended max. upper frequency limit 3 [kHz]
    Sensitivity, 2.83V/1m (average SPL in range 300 - 1,000 Hz) 91 [dB]
    Power handling, continuous, IEC 268-5, no additional filtering 100 [W]
    Effective radiating area, Sd 131 [sq.cm]
    Resonance frequency (free air, no baffle), Fs 35 [Hz]
    Moving mass, incl. air (free air, no baffle), Mms 17 [g]
    Force factor, Bxl 6.5
    Suspension compliance, Cms 1.2 [mm/N]
    Equivalent air volume, Vas 29 [lit.]
    Mechanical Q, Qms 11.6
    Electrical Q, Qes 0.29
    Total Q, Qts 0.28
    Voice coil resistance, RDC 3.2 [ohm]
    Voice coil inductance, Le (measured at 10 kHz) 0.091 [mH]
    Voice coil inside diameter 39 [mm]
    Voice coil winding height 15 [mm]
    Air gap height 5 [mm]
    http://www.audiomania.com/shop/goods-11222.html
    3 Wks 1 Day 19 Hrs 18 Mins 26 Secs
    barang langka...
    btw, kl ini bagusnya buat sub or mid ya??
    buat SQL kayaknya cocok banget nii...
    UP dulu.. si Bozz lg on VACATION.. jd buyers harap bersabar dikit..
    thanks yach bos andry............
    UP UP UP UP UP
    UP UP UP...
    thanks yach bos andry.............
  1. For Sale Tweeter Wavecor Tw022WA04 low fs murah Rp 540rb Baru
    By FERNANDO in forum Speaker - SubWoofer
    Last Post: 6th April 2013, 17:53
