SALE 1 Pair of Wavecor WF166TU02-01 6" car midwoofer kondisi BARU............1,5JT
Results 1 to 10 of 10
  • Short URL:  http://modifika.si/210016
    Wink SALE 1 Pair of Wavecor WF166TU02-01 6" car midwoofer kondisi BARU............1,5JT
    SALE 1 Pair of Wavecor WF166TU02-01 6", die cast, 90mm ferrite, 1" VC, 4 ohm car midwoofer kondisi BARU............1,5JT
    Price: $204.00
    WF166TU02 is a mid/woofer designed for demanding bass and midrange applications. It works equally well for most applications but is designed especially for automotive high-end sound. The very rigid die cast alu chassis follows the common standard dimensions for easy installation in cars WF166TU02 is powered by a large 90 mm magnet structure that ensures good efficiency and optimized T/S parameters. The large 32 mm voice coil ensures high power handling - thermally and mechanically The optimized paper cone ensures wide bandwidth and low distortion. Distortion is further reduced by efficient venting and a separate alu field-stabilizing ring.
    WF166TU02 is a good choice for 2-way car speaker systems.
    Features
    * Very rigid die cast alu chassis
    * Built-in alu field stabilizing ring for reduced high-level distortion
    * Vented voice coil former for reduced distortion and compression
    * Vented chassis for lower air flow speed reducing audible distortion
    * Heavy-duty black fiber glass voice coil bobbin to increase power handling and reduce mechanical losses resulting in better dynamic performance and low-level details
    * Large motor system with 1 voice coil diameter and large 90 mm magnet for better control and efficiency
    * Linear suspension with specially designed CONEX damper (spider) for long durability under extreme operating conditions
    * Gold plated terminals to prevent oxidation for long-term reliable connection - important in a car environment
    Wavecor WF166TU02-01 (ea.) car midwoofer's specifications
    Nominal size 6 [inch.]
    Nominal impedance 4 [ohm]
    Recommended max. upper frequency limit 3.5 [kHz]
    Sensitivity, 2.83V/1m (average SPL in range 400 - 1,000 Hz) 91 [dB]
    Power handling, continuous, IEC 268-5, no additional filtering 60 [W]
    Effective radiating area, Sd 139 [sq.cm]
    Resonance frequency (free air, no baffle), Fs 50 [Hz]
    Moving mass, incl. air (free air, no baffle), Mms 12.5 [g]
    Force factor, Bxl 5.0
    Suspension compliance, Cms 0.81 [mm/N]
    Equivalent air volume, Vas 22.3 [lit.]
    Mechanical Q, Qms 9.8
    Electrical Q, Qes 0.50
    Total Q, Qts 0.48
    Voice coil resistance, RDC 3.2 [ohm]
    Voice coil inductance, Le (measured at 10 kHz) 0.23 [mH]
    Voice coil inside diameter 32 [mm]
    Voice coil winding height 11 [mm]
    Air gap height 5 [mm]
    Magnet weight 400 [g]
    Total unit net weight excl. packaging 1.15 [kg]
    http://audiomania.com/shop/goods-11860.html
  2. Bandargua
    2 Wks 6 Days 18 Hrs 16 Mins 48 Secs
    UP UP UP.... pertamaxxx......
    thanks yach bos andry.........
    baru nyadar.. ada wavecor, ada wave aj.. hahaha... yg beda harganya... hehehe...
    hehehe,iya bos andry,kan ada beda corenya bos,hehehe.....
    up..............
    up up up...
    thanks yach bos andry...........
    UP UP UP...
    thanks yach bos andry.............
Mitsubishi Venom 300x250
  1. For Sale Tweeter Wavecor Tw022WA04 low fs murah Rp 540rb Baru
    By FERNANDO in forum Speaker - SubWoofer
    Last Post: 6th April 2013, 18:53
  2. HUSTLER AUDIO INC LAUNCH NEW "X6" MIDWOOFER
    By BadakSinga in forum Diskusi Speaker
    Last Post: 12th November 2008, 18:12
