SALE Wavecor TS030TU02-01 30mm Silk Dome Black car tweeter kondisi BARU.....1jt
Results 1 to 10 of 12
  • Short URL:  http://modifika.si/210015
    Wink SALE Wavecor TS030TU02-01 30mm Silk Dome Black car tweeter kondisi BARU.....1jt
    SALE Wavecor TS030TU02-01 30mm Silk Dome Black car tweeter kondisi BARU..............1jt
    Price: $131.00
    TS030TU02-01 is a complete car tweeter set based on the 30mm Wavecor tweeter. It comes as two tweeters in one package complete with two different kinds of mounting and with wires.
    The tweeter is a high performance 30mm soft dome tweeter with high-stability ferro fluid in the air gap.
    The low resonance frequency and high power handling make this tweeter ideal for 2-way car speakers, where standard tweeters will not do.
    The usage of dual neodymium magnets as power house ensures high efficiency while still keeping size small.
    The low distortion and the smooth and extended frequency response combine extreme details and dynamics into making this tweeter the preferred choice for high-end car sound systems.
    The large heat sink and the ventilated angle house take care of keeping voice coil temperatures low - even at high power levels and under high ambient temperatures.
    Mounting parts in grey colour for easier matching with car interior.
    IDEAL as upgrade for existing car audio systems.
    Features
    * Precision-coated textile diaphragm for improved consistency and high-frequency extension
    * Vented voice coil former for reduced distortion and compression
    * Copper-clad aluminium voice coil wire offering lower moving mass for improved efficiency and transient response
    * Build-in cavities under dome/edge to equalize pressure for lower distortion and lower resonance frequency
    * Rear heat sink for increased power handling and reduced power compression
    * Dual neodymium magnets for improved efficiency and improved magnetic shielding for A/V applications
    * High-stability ferro fluid for increased heat transfer from the voice coil
    * Flexible lead wires for higher power handling and larger excursion
    * Black anodized magnet structure for increased power handling and reduced power compression
    * Gold plated terminals to prevent oxidation for long-term reliable connection
    * Delivered with EVA gasket attached for hassle-free mounting and secure cabinet sealing
    * Ventilated angle mount house to ensure free air flow for high power handling
    Wavecor TS030TU02-01 Silk Dome Black (2 pcs) car tweeter's specifications
    Tweeter TW030WA04, 30mm silk dome, neodymium
    Nominal impedance 4ohm
    Tweeter flush mounting hole diam. 62mm
    PACKAGE CONTENT
    * 2 pcs 30mm dome tweeters Wavecor TW030WA04 with grille attached
    * 2 pcs tweeter angle mounts
    * 2 pcs tweeter flush mounts
    * 2 pcs 1.5m dual connection wires
    * 4 pcs self-tapping screws
    * 2 pcs double sided tape for tweeter angel mount
    * 1 pc. drilling/cutting template
    http://www.audiomania.com/shop/goods-8617.html
    1 Day 10 Hrs 3 Mins 13 Secs
    Tweeter mantab nih
    Sudah ambil satu dan dipasangkan dengan vox altitude....bumi dan langit bedanya...
    thanks testinya yach bos hadi...
    barangnya tinggal 1 set lagi nich boss.....
    thanks........
    surabaya
    1 Wk 21 Hrs 18 Mins 35 Secs
    thanks........
    bos tolong pencerahan buat karakternya donk.....
    tukar tambah bisa g bos?
    sm minta CP donk bos.....
    contact aja bos ke 081388575788 yach bos,ok?
    thanks yach bos......
    3 Wks 5 Hrs 26 Mins 38 Secs
    UP buat tweeter langka...
    UP dulu.. si Bozz lg on VACATION.. jd buyers harap bersabar dikit..
    thanks yach bos andry............
    UP buat partner wavecor...
MBtech Venom 300x250
  1. [WTS] Tweeter Silk Dome Cliff Design
    By bassline in forum Speaker - SubWoofer
    Last Post: 12th June 2011, 12:14
  2. Midrange vs Fullrange vs Dome Silk Tweeter
    By andyanto_wibowo in forum Diskusi Speaker
    Last Post: 29th November 2009, 19:03
