CRESCENDO Opus 3 (best seller of crescendo opus speaker)....(sold,thanks modcom...)
  • Short URL:  http://modifika.si/210014
    CRESCENDO Opus 3 (best seller of crescendo opus speaker)..........sold
    Brand: CRESCENDO
    Category: Speaker Set
    Series: 2 ways speaker
    Powerful midbass kick makes Opus 3 suitable for all kind of music including trance, hip-hop, and rock. Moreover, Opus 3 is so efficient that it can be driven by head unit’s internal amplifier. Sold at moderate price, it surely is the best value for money.
    Composition:
    1. Tweeter: T1RP
    2. Mid-woofer: MS-6
    3. Passive crossover: X3
    Tweeter features:
    1. 1 inch soft fabric dome with special coating for warm and detailed sound.
    2. Newly developed low resonance plastic housing for clear and smooth highs.
    3. Embossed Crescendo logo as a proof of originality.
    4. Two curvy bars grill to minimize grill distortion and enhance its elegant expression.
    5. Complimentary 10 centimeters Harmonic Harmony ‘Interlude’ cable for fine tuning of sound.
    Mid-woofer features:
    1. Polypropylene cone for perfect balance between sound, appearance, and durability.
    2. Aluminium die cast chassis for clean and un-distorted sound.
    3. Gold plated terminal for best connection.
    4. 7 inch size for deep midbass.
    5. Inverted dust cap for stronger cone structure and to avoid premature damage.
    Passive crossover features:
    1. Designed in car with tweeter above the dashboard and mid-woofer at door panel for optimum sound at the actual condition.
    2. L-pad attenuation for less-colored sound and uniform attenuation level.
    3. 3 positions switch to adjust tweeter level and Q factor at the same time for smooth blending.
    4. Capacitor for tweeter is Jantzen Z-Standard Cap (Made in Denmark) for warm and high resolution sound.
    5. Main resistor for tweeter is Mills (Made in USA) for open, sharp, and smooth high.
    6. Inductor for mid-woofer is using metal core for power efficiency so that Opus 3 can be driven by head unit’s internal amplifier.
    Sound Characteristics:
    1. Clear articulation and smooth high.
    2. Natural, warm, and liquid midrange.
    3. High impact and tight midbass.
    4. Rhythmical and a lot of fun for any music from classical to hard rock.
    5. Focused and realistic imaging.
    Specifications:
    1. System nominal impedance: 4 ohms.
    2. Crossover point: 3.5 kHz.
    3. Frequency response +/- 3db at 30 degree off axis: 63 Hz – 20 kHz.
    4. Power handling: 30 – 60 Watts RMS (without High Pass crossover) and 30 – 100 Watts RMS (with High Pass crossover at 63 Hz).
    BATAM
    1 Day 17 Hrs 53 Mins 54 Secs
    pm super nett boss
    pm sent bos,thanks...
    up..........................
MBtech Venom 300x250
  1. WTS: SQ Speaker 3 way Crescendo opus 9.9.
    By Erick'Eternity' in forum Speaker - SubWoofer
    Last Post: 14th July 2012, 00:39
  2. WTS : Speaker Crescendo Opus 8.9b Rp 1.900.000(SOLD)
    By *123# in forum Speaker - SubWoofer
    Last Post: 21st June 2010, 02:41
  3. 3 way CRESCENDO OPUS 8.9B (sold,thanks modcom...)
    Last Post: 15th October 2009, 06:11
