2pcs JL Audio 10W1V2-4 10" 4-Ohms Subwoofer (sold,thanks modcom...)
Results 1 to 10 of 21
  • Short URL:  http://modifika.si/210012
    2pcs JL Audio 10W1V2-4 10" 4-Ohms Component Subwoofer kondisi muluuuus n original.......sold
    Description
    10" 4-ohm Component Subwoofer metallic-finish polypropylene cone with nitrile-butylene rubber surround,
    25-250 Hz frequency response,
    50-300 watts RMS power range
    Specifications
    Car Speaker Type Component, Subwoofer
    Car Speaker Size 10"
    Nominal Power 300 W, 10 W
    Passive Or Powered Passive Speaker
    Material Rubber - Surround
    Output Power 300 W (RMS) / 600 W (PMPO)
    Driver Type 1 x 10" Metallic-finish polypropylene cone Woofer
    Frequency Response 25 Hz to 250 Hz
    Product Series W1v2
    Rms Power 300 W
    Product Type Woofer
    Dimensions 10.50" Diameter, 13.25" Height x 18" Width x 13.50" Depth - Ported Enclosure, 13.50" Height x 16.50" Width x 7.75" Depth - Sealed Enclosure
    Weight 7.81 lb
    Impedance 4 Ohm Nominal
    Sensitivity 85 dB
    Brand Name JL Audio
    Product Model 10W1V2-4
    Pmpo Power 600 W
    indonesia
    9 Hrs 50 Mins 47 Secs
    1.5 sepasang ato 1 biji boss?
    Baru apa second?
    3 Wks 18 Hrs 37 Mins 15 Secs
    Quote Originally Posted by Ryaaann View Post
    Baru apa second?
    barang mulusssss...... TOP....... ayoooo dibeli gan.........
    gak nyesel.......
    1 Hr 55 Mins 11 Secs
    ini tipe suara sub nya gmana? empuk gag? hahaha.
    thanks yach bos andry...
    karakternya empuk bos blex..
    1,5jt sepasang bos ryann.......
    indonesia
    Ini baranya second yaah bos? Kalo barunya berapa yaa? Ada stock ngga?
    kalo di bandingin sama 1 w3v2 yang 12" sama ini 2 10", bagusan mana?
    =BANDUNG=
    14 Hrs 23 Mins 40 Secs
    Quote Originally Posted by blex290190 View Post
    Bantu jawab... Dr pengalaman enakan 1 W3v2 12"buat SQ ya...
    Ini 2nd tapi kondisi masih hampir spt baru bos,harga barunya sekitar 1,5jt per pc nya bos ryan..
    Kalau low nya bagusan w3v2 bos,tapi speed bagusan 10w1v2 ini bos,jadi tergantung butuhnya aja bos...
    Thanks yach bos brago sudah bantu jawab..
MBtech Mega Glodok Kemayoran
  1. wts: subwoofer JL AUDIO 10w1v2
    By leon9 in forum Speaker - SubWoofer
    Last Post: 9th July 2012, 00:08
  2. 2pcs TREO Engineering TSX 12 inch Dual 2 ohms subwoofer....
    Last Post: 23rd October 2010, 14:18
  3. Replies: 135
    Last Post: 8th August 2010, 08:22
