wts alpine9857 garansi
Results 1 to 10 of 10
  • Short URL:  http://modifika.si/209789
    Central Java
    3 Hrs 23 Mins 9 Secs
    wts alpine9857 garansi,clarion 9255exl limited n alpine 9815
    alpine 9857 pembelian akhir april
    kartu garansi masi kosong jd mau bikin 12 bln jg bisa
    kondisi overall mulus,dus buku lengkap,di layar ada baret2 halus dikit
    brg masi nempel di mobil saya bs test
    spek
    * CD player with built-in amplifier (18 watts RMS/50 peak x 4 channels)
    * flip-down, detachable face with 2-line BioLite display
    * plays audio CDs, CD-Rs, and CD-RWs (including discs loaded with MP3 and WMA music files)
    * Bass Engine (bass center frequency, width, and level, plus treble center frequency and level adjustments)
    * BBE processing
    * Source Tone Memory
    * three sets of preamp outputs
    * HD Radio-ready
    * controls for an optional XM or SIRIUS satellite radio tuner
    * compatible with an iPod using Alpine's Full Speed controls
    * CD changer controls
    * remote control
    * clock
    * CEA-2006 compliant amplifier
    * CD frequency response: 5-20,000 Hz
    * CD signal-to-noise ratio: 105 dB
    * FM sensitivity: 9.3 dBf
    open price 1,550 nego alus
    clarion 9255 exl limited price 2,85nego
    made in japan
    20bit dac independent,cd player analog, dus lengkap masi segel brgnya pemakaian +-3thn,brg masi mulus
    bos neusounds sy quote ya
    [QUOTE=NeuSounds;1517905]gini :
    9255exl itu lanjutan dari seri 9255 sebelum nya yg booming karena clarion meluncurkan HXD1 yg menurut orang2 indonesia gagal, ga enak suara nya...
    nah seri ini cukup terkenal karena pendahulu nya, kalo sekilas emang ga ada beda nya dengan pendahulu nya, tapi kalo di perhati kan, benar kata bro Rimba, 9255 lebih enak di banding 9255exl, lebih tebal kesan vocal nya...
    9255 maupun 9255exl ga ada fitur apa2, bahkan baca mp3, cdrw aja ga bisa, cuma cd player biasa aja, tapi dual 20bit...ada optik out nya...fitur nya cuma balance, fader , bass dan treble...preout cuma front , rear, ga ada aux in
    jadi bisa di bilang 9255 ini cikal bakal nya HXD2.... dibandingkan dgn 956mc yg uda 24bit, nah suara masih di bawah 9255, karena 9255 itu dual 20bit....
    jadi kalo emang lo cari suara analog, tanpa mo maen TA segala, suara lebih natural, yah pake lah 9255...
    alpine 9815 price 2jt nego
    brg hu+remote aja ,dus ilang wkt pindahan rmh, kondisi mulus,perna buka segel 1x krn wkt itu motorized agak lemot,uda dibenerin skr lancar n mulus jalannya
    ada fitur time alignment
    kalo suara sm 9835/9855/9887
    9815 paling enak suara lebih lembut n halus
    foto asli menyusul
    dijamin mulus
    Sharp looks and sharp sounds — Alpine's CDA-9815 CD receiver is a complete car audio package! It will play your MP3 and Windows Media (WMA) files on CD-R and CD-RW with excellent detail and clarity. Navigating through folders and files is a breeze, thanks to the 2-line color display that reads out CD and MP3 text information.
    The V-Drive™ MOSFET hybrid internal amplifier pumps out an astounding 27 watts RMS of continuous 4-channel power. Bass Engine® Pro allows you to tweak the sound to perfection with its 5-band parametric equalizer, 6-channel digital time correction, and 6-position crossover (with variable slope, and subwoofer level and phase adjustment). The Media Xpander™ rejuvenates compressed musical formats like MP3 and WMA files, as well as radio broadcasts and your regular audio CDs.
    Alpine's exclusive i-Personalize™ feature allows you to create customized, vehicle-specific Bass Engine setups on Alpine's website, burn them to a disc, and upload them onto the CDA-9815. You can even type in a 3-line text greeting to display when you fire up the unit.
    Want even more musical options? Put 6 or 12 discs at your command by adding an Alpine CD changer, or use the optional adapter to convert the changer port to an auxiliary input. Add Alpine's XM Satellite Radio tuner and an XM antenna, activate your XM service, and groove to over 100 channels of digital music, sports, news, and entertainment.
    Three 4-volt preamp outputs deliver ultra-clean signal to any component amps and subs you choose to add to your system. A wireless remote control is included for your safety.
    Important Note: The powerful output of Alpine's V-Drive internal amplifier requires a direct fused connection to your vehicle's battery! We recommend that you purchase a 10-gauge amp wiring kit.
    Details:
    * detachable, fold-down face
    * 2-line color display with spectrum analyzer
    * blue button illumination
    * plays CDs, CD-Rs, and CD-RWs
    * plays MP3 and Windows Media (WMA) files
    * displays MP3 text
    * CD Text with scroll
    * 0-bit mute (mutes output when no audio signal is detected)
    * MaxTune SQ tuner
    * 12 FM/6 AM presets
    * station title memory
    * V-Drive hybrid MOSFET60 internal amp — high-current draw requires direct fused connection to your battery
    * Bass Engine Pro (5-band parametric EQ, 6-channel digital time correction, 6-position crossover with variable slope, plus subwoofer phase and level controls)
    * Media Xpander
    * i-Personalize — create customized Bass Engine setups and text greetings
    * XM Satellite Radio controls (XM Radio subscription, tuner, antenna required to receive the satellite radio signal.) — service is available only in the lower 48 states, not available in Alaska, Hawaii, or U.S. territories
    * CD changer controls for Alpine Ai-NET changers only
    * optional auxiliary input
    * 4-volt front, rear, and subwoofer preamp outputs
    * wireless remote
    * clock
    * 27 watts RMS/60 peak x 4 channels
    * CD frequency response 5-20,000 Hz
    * CD signal-to-noise ratio 105 dB
    * FM sensitivity 9.3 dBf
    saya lokasi di semarang
    cp:08174151010 (eka)
    ym:mummy_son_ica
    [QUOTE=coyanakbaik;184043086]barang bagus gan mantap..............
    bisnis ma agan g ribet...........
    mkasih ya gan.............
    Quote Originally Posted by kin9dom View Post
    barang dah sampe gan..........mntabbssss gan..sumpah..yang tadinya gw ragu sma ni earphone..cz modelnya g suka...awalnya nyoba punya temen merk sonic gear dipakenya sakit..pas pake yg pr 20 enak bgt deh....ilang deh rasa RAGU....barang masih ok bgt...walaupun gw bnyak nanya ttp diladenin....org sabr...heehhehehehhe
    pokoknyarecomennded seller deh...
    thanks gan
    :recsel
    Quote Originally Posted by sakuralobz View Post
    brg dha diterima gan
    dha di post jg di rekber nya
    thx yha
    recommended seller nih
    sabar, baek
    he3...
    pdhal gw bawel bgt
    ttp aja baek
    mantap dha
    sukses yha
    Quote Originally Posted by andiajikristian View Post
    Gan dopod udah keterima dengan kondisi yang super mantap abis gan .... Mulussssss hampir ga kelihatan kalo second gan ... pokok nya barang mulus abis kayak paha bayi baru lahir heheheheheh ,,, Puas habis gan ,, meski nunggu dulu sehari buat kirim nya ... Keren dah .. testing testing dulu ni gan .. lagi pengen upgrade ke WM 6.5 ...
    Agan satu ini super RECOMENDED SELLER :ilovekaskus :iloveindonesia
  2. clickbet88.com
    8 Hrs 6 Mins 26 Secs
    pm super nett lah bos^^
    Central Java
    up
    up
    up
    up
    uda di pm bos
    PM g msk bos....
    pm ulang coba
    Central Java
    Quote Originally Posted by Little_jazz View Post
    PM g msk bos....
    pm ulang coba
    uda bos
    cek pm
    Central Java
    up
    up
    up
    up
    Central Java
    up
    up
    up
    up
    Central Java
    up
    up
    up
    up
    Central Java
    up
    up
    up
    up
    Central Java
    upupupup
    up
GT Radial MBtech
  1. Replies: 39
    Last Post: 7th October 2010, 07:30
  2. bedanya garansi sama garansi resmi apa sih?
    By gerly in forum HID Provision
    Last Post: 4th June 2008, 04:58
