Pivot 3 Drive Throttle Controller Flat
  • Short URL:  http://modifika.si/209387
    11 Hrs 41 Mins 1 Sec
    Pivot 3 Drive Throttle Controller (New model Flat).
    Harness untuk Toyota Innova/Fortuner dan Honda only.
    Harness 1A Engine Toyota:
    1 or 2 TR-FE
    1 or 2 KD-FTV
    Harrier : 1 MZ-FE
    Harness 7A Honda All New Jazz (tinggal yg modelbiasa bukan yg flat)
    Engine : L15/13A
    Hub : PM untuk more info n price.
    Ultra-thin
    Controller
    Our 14mm FLAT model can be installed just about anywhere without interfering with the your interior design.
    Mode
    Memory
    The "Same as Last" mode allows you to re-start your engine in the same mode as last time.
    If you wish to start the engine in "Normal" mode, wiring can be done to IGN.
    3 Modes
    Possible to change between three modes: SPORTS mode for higher acceleration response, ECO-mode for lower response and NORMAL mode for standard response.
    12 steps
    In the SPORTS mode, seven step ECO mode is a detailed adjustment of 12 all steps of five steps.
    Acceleration
    Monitor
    Open times of the accelerator (amount of depressing) are displayed and it is convenient for the eco-driving etc.
    Easy
    Installation
    Easy installation using car model specific coupling harness.
    Initial
    Settings
    Inisital settings can be made for each type of car making it compatible with a wide range of models.
    Digital
    Circuitry
    The high-speed circuitry signal output is not affected by temperature or noise and hence guards against troubles and failures.
    Normal Control when in Reverse
    When the vehicle is put into reverse it will automatically return to normal acceleration (wiring where necessary). However, usually when using reverse the degree of acceleration is at most about 10%; in this range there is hardly any change so it is not necessary to wire for using reverse.
    Safety System
    The acceleration mode will automatically be returned to "Normal" if the product should break or fail, or if the two signals should separate.
    1 Day 7 Hrs 5 Mins 26 Secs
    Bos, untuk freed ada ga ? Berapaan bos ma harnestnya ma pasang ? Ini model yg terbaru khan original japan ?
    1 Day 11 Hrs 46 Mins 57 Secs
    Smsin harganya donk innova diesel di 08128081987
    (tomang, jakbar)
    20 Hrs 31 Mins 4 Secs
    yg flat ga aada?
  1. WTS : PIVOT 3-DRIVE FLAT THROTTLE CONTROLLER
    By Bill9 in forum Jual Beli Mesin Lainnya
    Last Post: 23rd March 2012, 12:41
  2. WTS : PIVOT 3-DRIVE FLAT THROTTLE CONTROLLER
    By mike_d in forum Jual Beli Mesin Lainnya
    Last Post: 3rd June 2011, 11:07
  3. WTS : PIVOT 3 DRIVE THROTTLE CONTROLLER (FLAT MODEL)
    Last Post: 6th April 2011, 15:45
  4. Pivot 3 Drive Throttle Controller (Flat)
    By pipin in forum Jual Beli Mesin Lainnya
    Last Post: 25th August 2010, 19:49
