RR // TiAL MV 38mm & TURBOSMART External Wastegate
Page 1 of 29 12345 ... LastLast
Results 1 to 10 of 282
  • Short URL:  http://modifika.si/209374
    1 Wk 2 Days 7 Hrs 59 Mins 4 Secs
    RR // External Wastegate (TiAL MV-S & TurboSmart)
    EXTERNAL WASTEGATE - Replica
    Need better response or bigger boost pressure..? Then you will need an External Wastegate..
    TiAL MV-S WASTEGATE
    Ukuran : 38mm
    Boost Range (Recommended) : 7psi (0,5 Bar) up to 21psi (1,5 Bar)
    Pilihan Warna : Blue only
    Kit dalam 1 Set TiAL MV-S External Wastegate:
    - MV-S Body Assy
    - V-Band Clamp
    - Bolts & Fittings
    Harga : Rp. 1.400.000
    TURBOSMART ULTRA GATE WASTEGATE
    DESCRIPTION: 38mm external wastegate. Small and lightweight, the Ultra-Gate38 provides high-end features and build quality at an entry-level price.
    APPLICATION: Suitable for all turbocharged vehicles with an external wastegate turbo system. Street and racing applications. Flanges suit 1.50” outside diameter pipe.
    SUPPLIED WITH: 7 psi spring (fitted), valve seat, 2 x stainless steel gaskets, mounting bolts and 2 x 1/8 NPT vacuum fittings. Kit Builder Packs available to customer specifications.
    Harga : Rp. 1.600.000
    Kontak : AGUS
    Hp : 0858 1488 7905
    BB Pin : 217E9C90
    Syarat Dan Ketentuan Pembelian :
    1. Pembelian HANYA dapat dilakukan secara ONLINE
    2. TIDAK melayani COD
    3. Pilih barang yang diinginkan
    4. Harga BELUM termasuk ongkos kirim
    5. Konfirmasi melalui SMS / Telpon untuk jumlah total barang belanja
    6. Transfer total pembelian yang telah disepakati ke rekening Bank yang ditunjuk
    7. SMS nama dan alamat lengkap untuk pengiriman
    8. Setelah pembayaran diterima barang pesanan anda akan dikirim SEGERA dan nomor resi pengiriman akan diberitahukan via SMS
    RACINGrepublic
    Kontak : Agus
    HP/WA : 0857 1417 7725
    BB Pin : D534E597
    RACING REPUBLIC/ONLINE STORE
    RACINGrepublic
    Kontak : Agus
    BB Pin : D534E597
    RACINGrepublic
    Kontak : Agus
    BB Pin : D534E597
    RACINGrepublic
    Kontak : Agus
    BB Pin : D534E597
    RACINGrepublic
    Kontak : Agus
    BB Pin : D534E597
    RACINGrepublic
    Kontak : Agus
    BB Pin : D534E597
    RACINGrepublic
    Kontak : Agus
    BB Pin : D534E597
    RACINGrepublic
    Kontak : Agus
    BB Pin : D534E597
    RACINGrepublic
    Kontak : Agus
    BB Pin : D534E597
    RACINGrepublic
    Kontak : Agus
    BB Pin : D534E597
  1. - H.P - TIAL Wastegate 38mm
    By Hydra Performance in forum Jual Beli Mesin Lainnya
    Last Post: 5th December 2011, 14:07
  2. RR // TiAL MV 38mm External Wastegate - replica
    By RacingRepublic in forum Jual Beli Mesin Lainnya
    Last Post: 22nd August 2010, 00:27
  3. Replies: 28
    Last Post: 24th February 2010, 22:41
