JUAL OLD SCHOOLS HU: ALPINE 7892E 4-Channel Digital Time Correction
Results 1 to 6 of 6
  • Short URL:  http://modifika.si/209054
    TB. SIMATUPANG - JAKTIM
    3 Days 11 Hrs 2 Mins 55 Secs
    JUAL 1,5jt OLD SCHOOLS HU khusus SQ ALPINE 7892E 4-Channel Digital Time Correction
    Jual cepet aja bos, ALPINE 7892E kondisi ok bgt
    Here are some of the features:
    Motorized Detachable Faceplate: The detachable faceplate is motorized for convenient access to the CD slot. Selectable Faceplate Angle: In addition to the standard faceplate position, there are three preset faceplate angles for you to choose from.
    Audio Level Display: You may choose from one audio signal level display pattern, or the audio signal level display may be turned off.
    Bass Engine Plus: Bass Engine functions provide control over your system, so you can tailor the sound to your personal tastes. Bass Engine Plus includes the following functions:
    4-Channel Digital Time Correction: The time correction feature allows you to create virtual speaker positions by delaying the signals being sent to the speakers closest to you. When the correct delay times have been entered for the front right, front left, rear right and rear left speakers, all sounds reach your ears at the same time, providing optimized imaging and frequency response.
    3-Position 12dB/Octave Crossover: An 80Hz/120Hz/160Hz low pass filter is available for the subwoofer outputs, and an 80Hz/120Hz/160Hz high pass filter is available for the front right, front left, rear right and rear left speaker and preamp outputs. Either, or both, filters may be turned off.
    MX (MediaXpander): The MediaXpander function makes vocals or instruments sound distinct by restoring sound quality typically lost during recording or transmission; this function helps restore audio information that becomes obscured when audio is compressed. The MX function can be applied to all sources, except AM radio. There are three expansion modes for each internal source (CD, FM), and each source can have its own setting. There are only one or two expansion modes available for external sources.
    Bass Center Frequency Control: To tailor bass response to your preference, you may select the bass control's center frequency. You may select from the following center frequencies: 60Hz, 70Hz, 80Hz, 90Hz, 100Hz, 130Hz, 150Hz, or 180Hz.
    Bass Width Control: You may choose from four band width (Q-Factor) settings for the bass control; the bass control can be set to affect a wide or narrow band of frequencies.
    Treble Center Frequency Control: To tailor treble response to your preference, you may select the treble control's center frequency. You may select from the following center frequencies: 10kHz, 12.5kHz, 15kHz, or 17.5kHz.
    Subwoofer Level Control: The level of the subwoofer preamp outputs can be adjusted to balance the output of your subwoofer with that of your other speakers.
    Subwoofer Phase Selector: The phase of the subwoofer outputs may be set to normal (0 degrees) or reverse (180 degrees); this function allows you to minimize phase cancellation of bass frequencies, for stronger bass response.
    Disc and Station Titling: Titles of up to 8 characters in length may be entered for up to 24 radio stations and 18 CDs.
    Wireless Remote: A wireless remote is included for convenient control of the head unit's most used functions (source selection, volume, disc transport functions, station seek and preset tuning, display angle selection).
    XM Radio Ready: An optional XM Satellite Radio tuner may be connected to, and controlled by, this unit. The optional tuner, along with an antenna and subscription, will allow you to receive XM Satellite Radio. XM Satellite Radio programming features up to 100 channels of digital-quality music, news, talk, sports, entertainment, and children's programming.
    4V Subwoofer Preamp Outputs: In addition to the 2V front and rear preamp outputs, this unit has a set of 4V subwoofer preamp outputs.
    Auxiliary Input Ready: With the addition of the optional KCA-121B Ai-NET/RCA interface cable, the KCA-801B auxiliary input adapter, or the KCA-410C Versatile-Link Terminal, the audio from an auxiliary source can be played through this unit. When the KCA-121B interface cable is used, a CD changer cannot be connected to the head unit; the KCA-801B auxiliary input adapter allows you to connect an auxiliary source and an Ai-NET changer to the head unit. The KCA-410C Versatile-Link Terminal allows you to feed audio from up to two auxiliary sources and two Ai-NET CD changers to the head unit.
    Changer Controls
    Compatibility: This unit is compatible with 6 and 12-disc Alpine Ai-NET CD changers; also, this unit can control Alpine Ai-NET CD/MP3 changers and DVD changers. Alpine M-Bus CD changers cannot be controlled by this unit.
    Multiple Changer Control: With the addition of an optional adapter, more than one CD changer can be controlled. One KCA-400C adapter will allow you to connect up to 4 CD changers, and two KCA-400C adapters will allow you to connect up to a total of 6 CD changers. The KCA-410C Versatile-Link Terminal can be used to connect up to two CD changers and two auxiliary audio sources.
    Text Display: When connected to a text capable changer, this unit can display text data from CD Text encoded CDs and MP3 CDs.
    Disc Titling: When connected to a CD changer with disc title memory, CD titles may be entered and displayed for discs played in the changer. The title length and title capacity varies depending on the model of CD changer used; titles cannot be input for MP3 discs.
    Clock Display Note
    Clock Operation: This unit allows you to choose "keyed" or "unit on" clock operation. When the clock has been given display priority and the unit is turned off, the clock will be displayed whenever the ignition key is in the "on" or "accessory" position. If the clock is not given display priority, the clock is not displayed when the unit is off.
    1,5jt
    harry 081802673735
    pic :http://img840.imageshack.us/img840/9962/img8950m.jpg
    uuuuuuuuupppppppp........
    Good morning sob...
    Central Java
    3 Hrs 23 Mins 9 Secs
    lokasi dmn?
    masi segel ga?
    Pasar rebo jaktim.. barang 2nd gak segel udah g segel bro
    Naikin doloooo... Uuuppppp
MBtech Venom 300x250
  1. WTA: TIme Correction
    By de'kampretz in forum Diskusi Head Unit & Processor
    Last Post: 22nd July 2008, 22:04
  2. time correction
    By c12 in forum Diskusi Head Unit & Processor
    Last Post: 20th November 2007, 01:42
  3. HOW TO ADJUST TIME CORRECTION IN ALPINE CDA-9887
    By gremer in forum Diskusi Instalasi
    Last Post: 29th October 2007, 19:38
  4. New 2006 HU From Alpine (Tanpa Time Correction ?????)
    By Spongebobs_NoPants in forum Diskusi Head Unit & Processor
    Last Post: 15th March 2007, 10:42
