JBL W10GTi 10" (250mm) Differential DriveŽ Design Subwoofer (sold,thanks modcom..)
Results 1 to 10 of 21
  • Short URL:  http://modifika.si/208909
    JBL W10GTi 10" (250mm) Differential DriveŽ Design Subwoofer..........sold
    JBL W10GTi
    If you are in search of the ultimate woofer, this is it! JBL has leveraged all engineering resources to develop quite simply the best subwoofer money can buy. Symmetrical Field Geometry ensures linear cone travel and low distortion at virtually any level by creating a uniform magnetic field around the coil. Die-Cast basket.
    Differential Drive Design (DDD) motor
    Die-cast vented basket
    KevlarŽ-impregnated paper woofer cone
    Nitrile-butylene surround
    Power handling RMS: 600 watts
    Power handling Peak: 3,000 watts
    Cut-out diameter: 9-3/16"
    Mounting depth: 9-1/8"
    Sensitivity: 90dB
    Dual 6-ohm voice coils
    these differential drive WGTI subs are absolutly amazing for SQ..
    with the way they perform and handle power they leave
    me thinking the coventional woofer design is obsolete...
    the bass is almost freakishly tight and detailed..with the way
    the differential drive works the more power you give them
    the tighter they sound..they make any sub I have ever owned
    or listened to sound inferior
    I know know why Team JBL has dominated the SQ/SQL comps
    Jak city
    4 Days 20 Hrs 37 Mins 29 Secs
    pertamaxxxxx..........
    klaten
    Sub nya ceyeeeeeeemmmmmmmm...........
    13 Hrs 35 Mins
    kalo make sub ini kayanya harus pake mono yg handal ya bos... harganya berapaan yah?....
    Thanks yach bos alvin...
    Bisa aja nich bos danny...
    Sub ini ga perlu pakai monoblock koq bos,pakai kelas ab 2ch juga ok bos...,pm sent bos badauku...
    Thanks...
    wah 600W RMS nih bos ya?
    bisikin net nya dong bos..
    Iya bos,pm sent yach bos,thanks..
    5 Hrs 56 Mins 20 Secs
    net nya brp bos??
    pm sent bos,thanks.......
    3 Hrs 49 Mins 34 Secs
    Wah... ini roket koq mirip subwoofer ya ?
    btw, berapa harganya boss ?
    trus berapa, dimensi tingginya, trus brapa liter kubikasi box-nya... maklum mobil kecil, space bagasi terbatas nih...
    thanks boss..
NGK Busi
  1. Replies: 3
    Last Post: 14th August 2014, 03:36
  2. Replies: 27
    Last Post: 15th May 2013, 08:14
  3. Subwoofer aktif HARMONIC DRIVE TECHNOLOGY (sold,thanks modcom...)
    Last Post: 17th February 2010, 17:00
  4. Replies: 17
    Last Post: 9th February 2010, 07:28
