JUAL MURAH> MSD-6AL-2 Ignition Control < BARU
Results 1 to 10 of 11
  • Short URL:  http://modifika.si/208394
    PERMISI..MINTA IJIN BUKA LAPAK
    Mau jualan control pengapian MSD 6AL..!!!!
    Kondisi masih baru gres bin kinyis-kinyis alias New In Box (Segel Dus).
    So pasti lengkap...kap..kap..!!
    Harga sih dijamin nego lah buat temen" semua dengan bukaan Rp 2 juta ajah. Mohon dengan rendah hati, nego jangan sadis yak..
    Buat yang lagi bangun mesin kenceng atau sekadar memperbaiki sistem pengapian di mesin mobil kesayangan, produk MSD 6AL dari Amerika ini udah nggak perlu diragukan lagi deh..
    OK deh, langsung aja liat penampakannya atau kalau mau hubungi gw bisa ke 0856 33 11 616
    Mau COD juga bisa tapi seputaran surabaya dan sekitar nya..
    berikut fotonya..
    minat : sms/telp : 0856 33 11 616
    terima kasih
    link detail product :
    [IMG][/IMG]
    MSD is excited to announce the next generation of 6-Series ignition controls the 6AL-2! The all new ignition control combines a new housing, new digital controls and more power in a sleek package. Inside the new cast aluminum housing you'll find an advanced micro-controller that manages the timing and rpm of the ignition. The spark output of the new box has been turned up to 535 volts of primary voltage with spark energy reaching up to 135millijoules! The multiple sparks of the 6AL-2 burn in the cylinder for 20 degrees of crankshaft rotation to ensure complete combustion.Two more great features are the rev limits! There are two rev limiters; one for high end overrev protection and another you can activate off a clutch or transbrake to set a launch limit. This feature will help your car blast off the starting line! Adjustments are made via four rotary dials for 100 rpm increment control!The all new capacitive discharge ignition will easily connect to nearly any 12-volt negative ground distributor system
    OPERATING SPECIFICATIONS
    Spark Energy: 135 mJ per spark
    Primary Voltage: 535 Volts
    Secondary Voltage: 45,000 Volts
    Spark Series Duration: 20 degree Crankshaft Rotation
    RPM Range: 12,500 RPM with 14.4 Volts
    Voltage Required: 12-18 Volts, Negative Ground
    Current Draw: .7 Amp per 1,000 RPM
    Weight and Size 3 lbs.,7"L x 4"W x 2"H
    3 Wks 5 Hrs 50 Mins 40 Secs
    PM nett bro..
    btw, 6AL ato 6AL-2?
    2 Wks 5 Days 52 Mins 41 Secs
    yang dijual 6AL ato 6AL-2 si???
    binun..
    Quote Originally Posted by michael_andry_s View Post
    PM nett bro..
    btw, 6AL ato 6AL-2?
    6AL aja gan...
    maaf kmrin salah tulis judul nya
    binun..
    6AL aja pak..maaf salah tulis judul
    silahkan sms ke 0856 33 11 616 untuk lebih jelas nya..
    harga di jamin murah.
    asli dari usa.
    100% original
    upp...respont cepat langsung sms ke 0856 33 11 616
    trims
    1 Mth 1 Wk 5 Days 13 Hrs 36 Mins 33 Secs
    emang bedanya apa AL sama AL 2 ?
    1 Day 6 Hrs 51 Mins 36 Secs
    sama kaya yg di ats emang bedanya apa AL sama AL 2 ?
    makasih
    SMG
    5 Hrs 56 Mins 54 Secs
    pm me donk
    masi ada gak
Venom 300x250 MBtech
  1. Mercedes Benz W140 Ignition Control Unit - Part no.0145452332
    By KJS_MOTORSPORT in forum Jual Beli Mesin Lainnya
    Last Post: 10th February 2013, 10:46
  2. wts : MSD Digital Ignition Control 6AL-2
    By bin fauzan in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 20th July 2012, 09:40
  3. WTS: MSD Adjustable Ignition/Timing Control
    By rakhanaufal in forum Jual Beli Mesin Lainnya
    Last Post: 2nd December 2011, 15:47
  4. ******FS MSD 7 AL-3 IGNITION CONTROL******
    By theansoracing in forum Jual Beli Mesin Lainnya
    Last Post: 25th December 2010, 07:51
