3-way Speaker System BOSTON PRO Series 6.53x kondisi NOS (sold,thanks modcom...)
Results 1 to 5 of 5
  • Short URL:  http://modifika.si/208003
    3-way Speaker System BOSTON PRO Series 6.53x kondisi NOS (100% BARU) MADE IN USA..........sold
    NEW PRICE $750.00
    # 6-1/2" ProSeries 3-way Component System
    # Power Handling:
    * Peak: 500 watts
    * RMS: 250 watts
    # Woofer Specifications:
    * Copolymer cone woofer
    * Butyl rubber surround
    * Rigid die-cast aluminum basket protects the motor assembly, maintaining perfect alignment of all essential moving parts
    * Precision machined pole plate
    * High effeciency voice coil
    * Integrated terminal block with gold-plated terminals
    * Fits 6" (160mm or 165mm) locations
    # 4.5" Midrange Specifications:
    * Copolymer midrange cone
    * Ferrofluid-cooled voice coil
    * Neodymium magnet structure
    * Gold-plated terminals
    * Fits standard 4" locations
    # Tweeter Specifications:
    * 1" Rigid aluminum dome tweeter
    * 1" Voice coil
    * Flush, surface, and angle mounting options
    * Patented AMD acoustic filter flattens the tweeter's output and smooths high end response
    # Crossover Specifications:
    * Designed specifically for this system
    * Audiophile-grade bypass capacitors and high-current inductors
    * Adjustable settings to fine tune sound depending on tweeter installation
    * Shielded corrosion-proof gold terminals
    * Low-pass and high-pass inputs could be bridged or separated
    # 3 ohms impedance
    # Top-mount depth: 2-3/8"
    Speaker Specifications
    Speaker Size 6-1/2"
    Design 3-way
    Tweeter Design Dome
    Tweeter Composition Aluminum
    Woofer Composition Copolymer
    Woofer Surround Butyl Rubber
    Peak Power Handling 500 watts
    RMS Power Handling 250 watts
    Sensitivity 90 dB
    Frequency Response 50 - 22000 Hz
    Impedance (per voice coil) 3 ohms
    Top Mount Depth 2-3/8"
    Bottom-mount depth N/A
    Cutout Dimensions 5"
    MADE IN USA
    klaten
    ck ck ck....ngeri ah dagangannya.... top dah pokoknya
    he..he..he.,bisa aja nich bos danny.......
    thanks yach bos..........
    3 Wks 20 Hrs 42 Mins 1 Sec
    jadi kepikiran 3 way nii... hahahaha......
    he..he..he..,bisa aja nich bos andry.....
Mega Glodok Kemayoran
