Sub Hi End
Results 1 to 10 of 11
Thread: Sub Hi End
  • Short URL:  http://modifika.si/207947
    PIN: 28C74CA7 HP:08112509829
    2 Days 22 Hrs 30 Mins 11 Secs
    Sub Hi End
    High End sub Hertz ML3000
    Seri paling tinggi Hertz
    Kondisi NOS....price list $900
    Jual 7,2jt aja
    Nego Call/SMS 08112509829
    Powerful from the lowest octaves of the audio range. The Hertz ML subs set a new benchmark for low frequency reproduction with the impact, dynamics and pressure that only a reference component can achieve. Power and harmony in the anti-resonant aluminium alloy basket design, self-standing low incidence five-spokes structure, Front-Back Gasket, magnet protection. Ultimate technology in every detail: V-cone with Polypropylene membrane stiffened with mineral dusts, high excursion surrounds, extended pole piece, dual layer mobile voice coil with copper covered aluminium wire (CCAW), oversize motor assembly with an exclusive forced ventilation circuit. A harder, deeper and more controlled bass for a unique enthralling experience.
    Technical Specifications
    Component Subwoofer
    Size mm 300 (12"")
    Power peak 1500
    Handling cont. program 750
    (Watt)
    Impedance Ohm 4
    Frequency Hz 25 900
    response
    Sensitivity dB/SPL 89
    Outer mm 318
    diameter
    Mounting mm 284
    hole diameter
    Total depth mm 207
    Mounting mm 179
    depth
    Total driver l 3,1
    displacement
    Weight of one kb 12,8
    component
    Voice coil mm 65
    diameter
    Magnet Double magnet high density flux ferrite
    Cone Polypropylene with Talco injection
    Xmech* mm 28
    klaten
    weleh2, ono sub ajib ki. Nemu di mana bos?
    2 Days 10 Hrs 9 Mins 32 Secs
    wah,dpt aja boss vian brng ky gn..
    Quote Originally Posted by RiEEE View Post
    ayooo buruan...cuma 1 aja loh
    bisa request barang lain
    Ground Wire - Serpong
    2 Hrs 4 Mins 53 Secs
    wuihh....... ajib nih.....brg antik ...... bantuin up deh bozz vian
    Quote Originally Posted by indosg View Post
    makasih om
    u p
    u p
    u p
    Quote Originally Posted by vian11 View Post
    Gaaan.... request sub 15" bisaaa gaaak?
    Hehehehehe.... sekalian upp...
