Subwoofer Intersys SW826 20Cm Likenew!! Lengkap kabel2,bracket,dus,manual Jarang pake
Results 1 to 10 of 19
  • Short URL:  http://modifika.si/207570
    Subwoofer Intersys SW826 20cm Fullset Like new
    Built in amplifier
    Variable Low Pass Filter
    Phase Switch 0/180 Degrees
    RCA and Speaker Level Inputs
    Kondisi lengkap dan siapp pasang tinggal culuk or sambung kabel ke head unit agan2
    Mau jual nih ga kepake lagi, soalnya ga mau ngubah2 audio di biem ane
    Subwoofer Intersys SW826 160watt, dah built in amplifier
    Muluss bangett dech seperti baru, dulu belinya 1.2jt
    Technical Specifications:
    - Maximum Output Power : 140W(70W+70W)
    - Rated Power : 80W(40W+40W)
    - Output Impedance : 2ohm + 2ohm
    - Frequency : 30-160Hz
    - S/N(A) : 92db
    - Maximum Current Consumption : 12A
    - Sensitivity (Distortion level 1%) : RCA input 82mV, Speaker input 0.8V
    - Voltage : 14.4V (10.5V-16V)
    - Size : 348x232x69mm
    - Weight (inluding accessories) : 5.1kg
    Kelengkapan
    - Unit Subwoofer
    - Bracket
    - Baut2
    - Manual book
    - Kabel2 : positive wire, speaker signal input wire, power control wire
    - Socket input wire 5557-2x5P
    Kondisi normal dan pas dipasang pun jarang dipake
    Harga : SOLD
    Lg jarang online kl minat silahkan lgsg call/sms 081932007467
    trims agan2 semua
    numpang lapak
    [WTS] Pioneer AVX 7650 LCD Mulusss banget
    http://www.modifikasi.com/showthread.php?t=195645
  2. Bandargua
    up up up up
    ap ap ap ap
    :o:rolleyes:
    up up up up
    ap ap ap ap
    :o:rolleyes:
    up up up up up
    ap ap ap pa ap
    :o:rolleyes:
    up up up up
    ap ap ap ap
    :o:rolleyes:
    up up up up
    ap ap ap ap
    up up up up
    ap ap ap ap
    :o:rolleyes:
    up up up up
    ap ap ap ap
    :o:rolleyes:
    up up up up
    ap ap ap ap
    :o:rolleyes:
    up up up up
    ap ap ap ap
    :o:rolleyes:
Venom 300x250 Vkool
  1. Replies: 9
    Last Post: 5th October 2011, 02:59
  2. [WTS] Subwoofer Intersys SW826 Fullset Like new murrahhh
    By mrdreamer in forum Speaker - SubWoofer
    Last Post: 14th August 2010, 12:07
  3. Replies: 10
    Last Post: 11th March 2010, 23:16
  4. Replies: 6
    Last Post: 22nd June 2009, 06:39
