NAKAMICHI 100TD kondisi muluus.......(sold,thanks modcom...)
  • Short URL:  http://modifika.si/207154
    NAKAMICHI 100TD kondisi muluus..............sold
    HEAD UNIT SPECIFICATIONS
    Cassette Deck
    Tape Speed 1-7/8 ips / 4.8 cm/s
    Wow-and-flutter Less than 0.05% (WTD RMS)
    Frequency Response 20 Hz - 22kHz
    Signal-to-Noise Ratio 71 dB (Dolby C NR On)
    67 dB (Dolby B NR On)
    Channel Separation Better than 35 dB
    Crosstalk Better than 60 dB
    Fast-wind Time Approx. 75 seconds (with C-60 cassette)
    FM Tuner
    Frequency Range 87.5 - 108 MHz (in 100-kHz steps)
    Sensitivity Less than 25 dBf
    50-dB Quicting Sensitivity Less than 25 dBf
    Signal-to-Noise Ratio Better than 65 dB
    Stereo Separation Better than 30 dB (1 kHz)
    Antenna Input 75 ohms
    AM Tuner
    Frequency Range 531-1602 kHz (in 9-kHz steps)
    Sensitivity 32 dBµ
    Preamplifier
    Frequency Response 30 Hz - 50 kHz ± 3 dB
    Output Level/Impedance 1 V / 1k ohm
    Aux Input Level/Impedance 0.5 V / 10k ohm
    Total Harmonic Distortion Less than 0.018%
    Tone Controls 20 Hz ± 12dB (Bass)
    200 Hz ± 10dB (Mid)
    20 Hz ± 6dB (Treble)
    General
    Power Source 14.4 V DC, negative ground (10.8 V to 15.6 V allowable)
    Current Consumption Max. 6.5 A
    Dimensions (w x h x d) 7" x 1-15/16" x 6-1/2"
    Approximate Weight 1.9 kg/4 lbs. 3 oz.
  2. Ysbjaya88
    3 Wks 10 Hrs 44 Mins 56 Secs
    UP dulu.. si Bozz lg on VACATION.. jd buyers harap bersabar dikit..
    thanks yach bos andry............
NGK Busi Mitsubishi
  1. Replies: 4
    Last Post: 4th March 2010, 16:27
  2. Replies: 2
    Last Post: 4th March 2010, 06:14
  3. Replies: 34
    Last Post: 17th January 2010, 21:41
  4. NAKAMICHI EC-302 kondisi muluus.........sold,thanks modcom......
    By MR.GASOLINE in forum Bursa Audio Lainnya
    Last Post: 12th January 2010, 06:01
  5. Replies: 20
    Last Post: 18th June 2009, 06:08
