PHASS DM52 kondisi 100% BARU garansi resmi 1 tahun (sold,thanks modcom..)
Results 1 to 5 of 5
  • Short URL:  http://modifika.si/205849
    PHASS DM52 kondisi 100% BARU garansi resmi 1 tahun...............sold
    PHASS DM52
    Price 379.00
    Phass DM 52 mid range It's a unique mid range unit equipped with the 52 mm large diameter voice coil and the silk fabric diaphragm with special coating and the large diameter neodymium magnet in a stylish plastic housing. DM52 can reach the optimal mid range speaker can perform the dense and detailed sounds with holding the harmonious connection with a mid bass and a tweeter efficiently.
    Phass DM 52 52 mm mid range specifications:
    Music power: 60 W;
    Sensitivity: 88 dB;
    Frequency response: 450-8,000 Hz;
    Outer dimension: 100 mm;
    Fixing hole: 82 mm;
    Installing depth: 58 mm;
    Impedance: 4 ohm
    Made in Japan
    2 Wks 5 Days 1 Hr 5 Mins 45 Secs
    Barang mantapz...
    Bantu up boss chris...
    Thanks a lot nich bos Rudy,sering2 main ke toko yach bos biar rame,he.he.he...
    3 Wks 5 Hrs 26 Mins 38 Secs
    UP UP UP...
    thanks yach bos andry.............
  1. Replies: 40
    Last Post: 17th March 2010, 05:39
  2. Replies: 28
    Last Post: 5th February 2010, 04:18
