Sheer Wire 14 AWG x 4 High Resolution OFC Speaker Cable........
Results 1 to 10 of 17
  • Short URL:  http://modifika.si/204217
    Smile Sheer Wire 14 AWG x 4 High Resolution OFC Speaker Cable........
    Sheer Wire™ audio cables provide the transparent interconnect solution for line- level and amplified signal formats in high-resolution audio reproduction systems. Through premium-grade compounds, high-purity copper conductors and precision tolerances, Sheer Wire minimizes attenuation, noise and external interference to deliver exceptional signal transfer, imaging and system response.
    High Purity Copper
    Exceptionally pure, densely stranded copper yields maximum conductivity.
    Low Noise and Attenuation
    Premium materials and tight tolerances achieve wide frequency response and low noise.
    Easy to Terminate & Install
    Unique compounds are easy to strip, terminate with connectors, and pull through walls or conduit.
    Footage Markers
    Incremental footage markers allow installers to easily identify the amount of cable installed or remaining.
    UL Rated
    Most Sheer WireT audio cables are UL rated, enabling them to be permanently installed.
    High Resolution Speaker Cable: OFC Oxygen-Free
    Speaker Cable: Low Loss OFC
    FEATURES & BENEFITS
    * 99.999% OFC Copper
    * Wide Frequency Response
    * Direct Burial and Sunlight Resistant
    * Two- and Four-Conductor Versions
    * UL Rated for Permanent Installation
    Specifications of 144OFC105
    number of conductor : 4
    nominal OD : .312"
    conductor (type/DCR) : 14 AWG (105x34) Oxygen-free BC / 2.5 Ω/Mft
    insulation (Type, Wall Thick, Color Code) : PVC, .012" Black, White, Red, Green
    jacket (Type, Color) : PVC, Blue
    UL type : CL3/PLTC
    Approx.Weight : 89 lbs/Mft
  2. Autopro
    3 Wks 39 Mins 15 Secs
    up up up up up
    thanks yach bos andry........
    cakep ya kabel nya...
    UP lg yaa.....
    UP dulu.. si Bozz lg on VACATION.. jd buyers harap bersabar dikit..
    thanks yach bos andry............
    up..........................
    Still in Earth
    3 Hrs 8 Mins 5 Secs
    Tolong PM harganya ya pak Chris ...
  10. 30th October 2010, 13:58
    Reason
    spam
  11. #9
    pm sent bos edhi,thanks...
  12. #10
    5 Days 14 Hrs 44 Mins 51 Secs
    Pm donk harga per meternya?
Venom 300x250 MBtech
  1. Replies: 52
    Last Post: 16th February 2014, 16:06
  2. MONSTER CABLE 16 AWG BLACK speaker WIRE
    By ood_cute in forum Cables & Interconnects
    Last Post: 23rd May 2011, 07:11
  3. Replies: 8
    Last Post: 27th April 2010, 23:47
