Eichmann eXpress 4 Speaker Cables........
  • Short URL:  http://modifika.si/204214
    Smile Eichmann eXpress 4 Speaker Cables........
    * Speaker cable designs optimised for Eichmann Bayonet Plug banana connectors.
    * Factory terminated with tellurium copper Bayonet Plugs.
    * eXpress 4 also available with gold flashed copper spades by special order.
    * Use of patented Eichmann Ratio in which the return conductors are larger in diameter than the signal conductors. This results in improved electron flow and better sound.
    * High purity oxygen free copper (OFC) solid core conductors configured in a true Litz arrangement.
    * Four conductors in the eXpress 4, all very precisely aligned and held rigidly in place. This provides an important measure of EMF control.
    * Custom lengths of eXpress 4, with either Eichmann Bayonet Plugs or spades are available by special order.
    * Designed and manufactured in Brisbane, Queensland, Australia.
    * Each pack contains a pair of cables.
    Eichmann eXpress 4 Speaker Cable Internal Construction.
    The eXpress 4 speaker cable uses the same technology as the matching eXpress 4 interconnect, but with increased mass to accept high current amplifier to speaker signals. The cable incorporates the Eichmann Ratio formula together with Litz construction to reproduce music's subtleties with honesty and detail. Nuance and musical shading are rendered with astounding clarity. The eXpress 4 speaker cable provides a clean, open sound with bass extension of real power and depth. There is an unmistakable sense of an 'untangling' of complex musical passages within a three dimensional sound stage. Available with high quality spade or Bayonet Plug termination, the eXpress 4 features Oxygen Free Copper (OFC) conductors, solid core technology, and FEP Teflon insulation.
    up..........................
  1. RCA & SPEAKER CABLES ( Wireworld, Nanotec, DH-Labs, Marigo)
    By gpaudio in forum Cables & Interconnects
    Last Post: 15th January 2013, 08:33
  2. Eichmann Express Six speaker cable
    By bj612 in forum Bursa Audio Lainnya
    Last Post: 20th July 2010, 00:21
  3. Replies: 29
    Last Post: 18th July 2010, 03:28
