Toyota INNOVA/FORTUNER D-4D "EGR Deletion Kit"
Results 1 to 5 of 5
  • Short URL:  http://modifika.si/204023
    11 Hrs 49 Mins 46 Secs
    TOYOTA D-4D "EGR Deletion Kit"
    Dikutip dari WIKIPEDIA,
    "EGR deletion in diesel engines is considered justifiable by a wide range of people. Although removing the EGR system results in increased NOx emissions, it will reduce engine out emission of hydrocarbon emissions, particulates and carbon monoxide. Exhaust gas recirculated back into the cylinder does increase engine wear as carbon particulate wash past the rings and into the oil..."
    "... a fair number of car owners disconnected their EGR systems in an attempt for better performance and some still do. The belief is either EGR reduces power output, causes a build-up in the intake manifold, or believe that the environmental impact of EGR outweighs the Nitrous Oxide emission reductions. Disconnecting an EGR system is usually as simple as unplugging an electrically operated valve or inserting a ball bearing into the vacuum line in a vacuum-operated EGR valve."
    "Adding EGR to a diesel reduces the specific heat ratio of the combustion gases in the power stroke. This reduces the amount of power that can be extracted by the piston. EGR also tends to reduce the amount of fuel burned in the power stroke. This is evident by the increase in particulate emissions that corresponds to an increase in EGR. Particulate matter (mainly carbon) that is not burned in the power stroke is wasted energy."
    EGR dalam kondisi terpasang,
    EGR dalam kondisi terlepas,
    Cover terpasang di EGR Valve,
    Cover terpasang di EGR exhaust,
    EGR Cover - Laser Cut 2mm Stainless Steel - Sand Blasted,
    Apabila ada yang tertarik untuk mencoba, please PM me..
    Thx..
    2 Days 19 Hrs 3 Mins 53 Secs
    bro mobil gw pake EGR tapi bensin,, kalo dilepas EGR valve nya ada efek samping nya gak bro??
    soalnya gw sempet baca2 juga artikel di internet bahas EGR ini dan banyak pro kontra nya...
    Black Espero '97
    13 Hrs 51 Mins 45 Secs
    Bro..g bisa minta no telp lo?pm aja ya
    2 Hrs 15 Mins 31 Secs
    Bro emank jual brp egr delete kitnya? PM ya
    medan
    1 Wk 5 Days 17 Hrs 28 Mins 44 Secs
    Apa fungsi deletion kit ni bro?? Maaf gaptek hehehe
MBtech Venom 300x250
  1. Toyota Fortuner "D 1230 M" warna Beige *BANDUNG*
    By siung_js in forum Informasi Kehilangan Kendaraan
    Last Post: 7th May 2013, 15:59
  2. TOYOTA CUCI GUDANG " FORTUNER AND YARIS "
    By musaliektoyotasales in forum Toyota
    Last Post: 6th October 2011, 16:00
  3. Toyota INNOVA/FORTUNER D-4D "EGR Deletion Kit"
    By dazz in forum Diskusi Mesin
    Last Post: 29th July 2010, 11:11
  4. FS: TOYOTA MR2 ...two doors....merah-(new PIC)
    By ngisup in forum Merk Lainnya
    Last Post: 5th March 2009, 18:03
