Scanspeak 9800 textile dome tweeter..(sold,thanks modcom...)
  • Short URL:  http://modifika.si/203682
    Scanspeak 9800 textile dome tweeter kondisi muluuus,lengkap dus..sold
    ScanSpeak D2904/9800 28 mm aluminum Dome Tweeter
    price $412.00
    *** Special Order Item - Please allow 6-8 weeks for delivery from time of purchase ***
    The Scan-speak D2904/9800 is a high-end 1" aluminum dome tweeter. The magnet system uses the Symmetric Drive technology that almost eliminates electrical phase shift. The specially designed chamber reduces air noise and compression. The geometry of the dome causes the "break-up" to appear beyond the audible range. A specially designed diffusor is used to equalize the response in the upper octave. The tweeter has a very clear and open sound.
    Driver Highlights: 1" aluminium dome, SD-2 motor, low compression design, non resonant chamber
    TECHNICAL DATA:
    Sensitivity 2.83V/1M 90dB
    Free air resonance Fs 500 Hz
    DC resistance 3.5 ohm
    V.C. inductance 0.01 mH
    Power 12dB@Hz 160W@2.8K
    Effective cone area 8.5 cm2
    V.C. diameter 28 mm
    V.C. height -
    Air gap height -
    Lin. & max. excursion 0.1 / 1.5 mm
    Air gap flux density -
    Force factor BL Product 2.8 Tm
    Moving mass incl. air 0.50 g
    Net weight 0.7 k
    Outside diameter: 104.5mm
    Cut out: 74mm
    Depth: 43mm
    25.4mm = 1" = 2.54cm
    1 Day 1 Hr 43 Mins 47 Secs
    brapa boss?
    pm sent bos,thanks.......
    up..........................
MBtech Venom 300x250
  1. [WTB]ScanSpeak D2905/9700 28 mm Dome Tweeter
    By euodia in forum Speaker - SubWoofer
    Last Post: 1st February 2010, 12:41
  2. Replies: 3
    Last Post: 31st December 2009, 05:34
  3. Replies: 54
    Last Post: 14th November 2009, 05:32
