Scanspeak 18W revelator midbass driver (sold,thanks modcom..)
Results 1 to 6 of 6
  • Short URL:  http://modifika.si/203681
    Scanspeak 18W revelator midbass driver kond muluuus,lengkap dus...sold
    ScanSpeak 18W/4531G 7" Revelator 4 ohm
    The Scan-speak 18W/4531G-00 is a 7" Revelator mid/woofer. It features a non-resonant cone and dust cap structure, dynamic linear suspension, SD-1 magnet system, "Grasshopper" cast chassis with maximized air flow and resonance terminating mounting system. Less resonance in all structures, lower compression and higher linearity, faster termination of excess energy and higher sound pressure capability. The 18W/4531G should have an F3 of about 65Hz sealed and 40Hz vented. Also an excellent choice for high end autosound applications.
    TECHNICAL DATA:
    Sensitivity 2.83V/1M 90dB
    Free air resonance Fs 33 Hz
    DC resistance 3.4 ohm
    V.C. inductance 0.3 mH
    Power 70W
    Effective cone area 150 cm2
    V.C. diameter 38 mm
    VC height -
    Air gap -
    Lin. & max. excursion 6.5 / 11 mm
    Air gap flux density -
    Force factor BL Product 5.7 Tm
    Moving mass incl. air 17.5 g
    Net weight 1.75 kg
    Vas 42 ltrs
    Qms 5.2
    Qes 0.38
    Qts 0.35
    Outside diameter: 182mm
    Cut out: 156mm
    Depth: 77mm
    25.4mm = 1" = 2.54cm
  2. Jayapoker
    berapa nih ... lagi nyari midb
    Maaf bos alf,barangnya sudah dibooked bos...
    1 Day 19 Hrs 55 Mins 52 Secs
    Mantappppp.....cpt bgt lakunya. Laris trs dagangan bos Christ
    Bexazi ..
    udah sold yah
    kebetulan aja koq bos agus,he..he...he....
    thanks yach bos agus...
    iya bos lebay,udah laku nich bos,thanks yach bos.....
  1. WTB - Midbass Scanspeak 18W Revelator
    By buya0811 in forum Speaker - SubWoofer
    Last Post: 20th March 2011, 10:19
  2. Replies: 1
    Last Post: 11th November 2009, 03:13
  3. For Sale: Scanspeak 15W Revelator Midbass
    By cerebro in forum Speaker - SubWoofer
    Last Post: 18th September 2009, 02:17
  4. hi-end scanspeak 23w revelator subwoofer.....(sold,thanks modcom....)
    Last Post: 17th September 2009, 06:05
  5. scanspeak revelator 15w/4531-G00 (sold,thanks modcom....)
    Last Post: 30th July 2009, 05:39
