Pioneer XDV P9 - DVD changer..........sold
If having a DVD player is great, what about a 6-disc DVD/CD changer? OK, it's outrageous, but whose car is it, anyway? The XDV-P9 is controlled by a number of Pioneer units or works alone with a remote, and connects to add-on displays. And it's Dolby Digital/DTS-ready, so you can have your own theater on four wheels. "Date movie" will take on a whole new meaning. Presenting a 6-disc changer unlike any other - the XDV-P9. In addition to playing standard audio CD/CDRs, it can handle DVD-video and video-CD discs. Combine it with a Pioneer A/V master unit and you can select and play either audio or video discs. A digital optical output provides Dolby Digital and DTS multi-channel surround when connected with the AVM-P9000R. For further flexibility you can connect the included Remote Eye and use it with a rear-passenger video system. Versatility is this unit's middle name.
Pioneer XDV P9 - DVD changer specifications
* General
* Product Type DVD changer
* Width 10.8 in
* Depth 8.0 in
* Height 3.5 in
* Weight 6.4 lbs
* Localization English
* System
* Product Type:Form Factor External
* System Control Bus IP-Bus
* Parental lock Yes
* Digital audio format DTS digital output , Dolby Digital output
* Features:Additional Features On-screen menu , CD text
* DVD
* Type DVD changer - External
* Media load type Magazine
* DVD changer capacity 6.0
* Media type DVD , CD , CD-R , DVD-R , CD-RW , Video CD , DVD-RW
* Audio D/A converter 24bit / 96kHz
* Dynamic Range 97.0 dB
* Signal-To-Noise Ratio 96.0 dB
* Response Bandwidth -43995.0 Hz
* Total Harmonic Distortion 0.003%
* DVD repeat modes Chapter , All , Title
* Multi-Camera Angle Select Yes
* Multi-Language Select Yes
* Remote Control
* Remote control type Remote control
* Remote control technology Infrared
* Remote Control (2nd)
* Remote control (2nd) type None
* Miscellaneous
* Included Accessories:Included Car AV Accessories IR remote control receiver , Cable kit
* Cables Included Video cable - 10.0 ft , IP-Bus cable - 19.7 ft
* Connections
* Connector Type DVD changer : 2.0 x Composite video output ( TOSLINK ) - Rear , DVD changer : 1.0 x SPDIF output ( RCA phono x 2 ) - Rear , DVD changer : 2.0 x IP-Bus ( RCA phono ) - Rear , DVD changer : 1.0 x Rear channel output - Rear
