Kenwood KVT-M700 multimedia system 7" motorised TFT video screen with touch sensitive
  • Short URL:  http://modifika.si/201609
    Arrow Kenwood KVT-M700 multimedia system 7" motorised TFT video screen with touch sensitive
    Kenwood KVT-M700 multimedia system 7" motorised TFT video screen with touch sensitive control. 1.45jt
    key features
    * 7 inch motorised TFT video screen with touch sensitive control
    * Screen size 154 x 87mm (336,960 pixels)
    * Fully automatic open / close with motorised tilt / angle adjustment
    * MASK and MASK-Key theft protection
    * Dual CD/DVD/MP3 changer control capability
    * Two RCA AV inputs (PAL/NTSC automatic selection)
    * One RCA AV output (PAL/NTSC according to the source)
    * RGB input for compatible navigation systems
    * Red or green switchable control button illumination
    * Infra-red remote controller included
    * Display of CD text information from compatible CD changer. Display scrolls if necessary
    * Disc Name Preset allows names to be assigned to discs in optional compatible CD changer. When disc is selected the name will appear on the radios display
    * Disc Name Preset Play allows you to select by name any disc in optional compatible CD changer
    * RDS (radio data system) & EON (extended other networks) tuner
    * DAB tuner can be added as an option for Digital Audio Broadcasting reception
    * TV tuner can be added as an option for television reception
    * Full coverage of LW / MW / FM wavebands
    * 4 x 47 Watts max power (MOSFET)
    * System Q-EX sound control
    * System E+ provides high-pass filter and bass boost with phase inversion for improved bass frequencies. Front and rear speakers can be individually adjusted
    BMS external amplifier control
    * Switchable dual-zone allows playing different sources to front and rear speakers simultaneously
    * Three gold plated RCA preouts (4.5 volt) for connecting external amplifier
    * Display auto-dims when vehicle's side lights turned on
    * 24 hour clock display
    * Two way telephone mute
    * Automatic turn off (after selectable delay of 20, 40 or 60 minutes)
    * Complete with full fitting and operating guide
    SuRoBoYo
    4 Days 10 Hrs 48 Mins 33 Secs
    Pm nettnya gan... tq
    pm sent bos david,thanks....
  1. WTS: (used) Kenwood KVT-839DVD motorized touch screen
    By misel in forum Head Unit & Processor
    Last Post: 6th September 2010, 14:14
  2. [WTS]MONITOR 7" INDASH KENWOOD KVT-M700 + TV TUNER KENWOOD KTC-V500P 2ND ORI JAPAN
    By sentra service car audio in forum Head Unit & Processor
    Last Post: 25th November 2009, 16:29
  3. Replies: 6
    Last Post: 4th November 2009, 03:57
  4. Replies: 10
    Last Post: 27th August 2009, 20:30
