WTS : CARDAS CABLE CROSSLINK II for Speaker + RCA second with Jack RCA Vampire Black!
Rgotogel Gelap.net 36Goal.com
Results 1 to 10 of 88
  • Short URL:  http://modifika.si/200156
    Ground Wire - Serpong
    2 Hrs 4 Mins 53 Secs
    Thumbs up WTS : CARDAS CABLE CROSSLINK II for Speaker + RCA second with Jack RCA Vampire Black!
    SALE beberapa set Kabel audio Speaker dan RCA high end SQ
    kondisi second 90% - READY to Use.
    semua berfungsi bagus.
    1. Kabel Speaker Cardas Crosslink isi 4
    ukuran kabel dalam @ 14 Awg
    Pembungkus Shield kabel luar warna Biru teflon
    warna kabel dalam : biru, hijau, kuning & merah.
    Tersedia ukuran kabel Speaker Pair sbb :
    A. 404 cm + 407 cm = Rp.1.300.000,- SOLD to MR ABC***
    B. 427 cm + 427,5 cm = Rp.1.370.000,-
    Semua ujung kabel sudah tersolder timah cardas untuk mencegah putusnya tembaga serabut.
    Koneksi ujung ke speaker Tweeter/Mid/Mid woofer langsung di solder dengan timah cardas juga untuk mendapatkan hasil maksimal.
    :smt050
    Gambar Cardas Crosslink II Speaker yang tersedia
    Crosslink is very flexible and light weight. Multi-gauge, Golden Section, Constant Q conductors are used. Crosslink has flame retardant EEA and cotton for the dielectric, with a PVC jacket, making it CL 2 rated. Crosslink is great for home theater, in-wall, automotive and small home audio systems.
    Outside Diameter: .365
    Dielectric Type: EEA and Cotton
    Q Factor: 10.6
    Inductance: .11 uh/ft/loop
    Capacitance: 55 pf/ft
    Bi Wire Option: Yes
    Discrete Conductors: 108
    Cable AWG: 11.5
    Conductor Type: Golden Ratio, Concentric, Cross layed, O.F.C.
    2. Kabel Cardas crosslink untuk signal audio RCA mono + Jack RCA Vampire Black Original
    Jack RCA Vampire bahan asli tembaga + gold plated
    Kabel RCA Cardas Crosslink II mono, solder with Timah Cardas
    Crosslink is very flexible and light weight. Multi-gauge, Golden Section, Constant Q conductors are used. TeflonŽ and cotton create the dielectric, with double shielding and a neoprene jacket. Crosslink is great for automotive installations and small home audio systems.
    Outside Diameter: .305
    Dielectric Type: TeflonŽ
    RCA Capacitance: 36.9 pf/ft
    XLR Capacitance: 22.8 pf/ft
    Discrete Conductors: 68
    Cable AWG: 20.5
    Shield Type: Double
    Conductor Type: Golden Ratio, Constant Q, Crossfield, Pure Copper Litz
    Ukuran kabel RCA mono dan jack Vampire ready tersedia sbb :
    a* 14 cm - 2 pcs = price @ Rp.235.000,-
    b* 34,5 cm - 2 pcs = price @ Rp.285.000,-
    c* 51 cm - 2 pcs = price @ Rp.320.000,-
    d* 87,5 cm - 1 pcs utk mono to stereo Power Monoblok Subw = price @ Rp.540.000,-
    (T connection treatment with aluminum foil and strengthen with surrounded Cardas tin)
    e* 52,5 cm - 1 pcs kabel polos New non Jack = price @ Rp.130.000,-
    :smt081
    Gambar penampakan masing2 sbb :
    a
    b
    c
    d
    e
    Gambar Jack RCA Vampire black yang dipakai
    Solder seluruh koneksi kabel dengan timah Cardas se merk.
    The vast majority of solders in the world are slurries or mixtures such as 60/40 tin lead solder. They go through a slurry stage as they solidify wherein one component solidifies first and then another. The result is a solder connection rather than a joint. Eutectic solders such as Kesters Ultra pure Tin/lead Silver are in fact excellent because they solidify at a temperature lower than any of the component parts thus they form a solder joint rather than a connection - the key here is the eutectic formula which must be very precise - the solders are obviously different in that they set up with a mirror finish rather than a dull finish, the reason they do this is because they solidify as a unit. The week link in the solders is contamination - the molten solder easily dissolves other metals, this is no problem if you are soldering to a metal that is part of the eutectic mixture (such as tin or lead) you will get contiguous flow right in to the joint (easy to see) but if you solder to a dissimilar metal (such as copper or silver) you will see an obvious dulling at the connection where the eutectic formula fails and and the continuous joint becomes a connection. Cardas Quad Eutectic is tin, lead silver, copper, eutectic. The results are obvious. Most highend products use this solder and other cable manufactures have been using it for over a decade - to them it represents good sound and absolute reliability. - George
    Gambar Timah Cardas yg dipakai
    Rasanya udah lengkap and jelas ya gan....keterangan di atas....
    Performance Suaranya, uenak, bening, gesit, warm and open. Tanya aja yg pernah pakai.
    HARGA sesuai yg tertera di masing2 spek ukuran di atas
    LOKASI : JAKARTA
    no afgan please... :smt072
    NO SMS, just call :eek:
    SERIUS buyer = PM me or call me at
    021-70918188 / 0816.911811
    email : sg2003w@gmail.com :smt117
    Thanks to ModCom and Modcomers.:smt038
    END.
    2 Days 10 Hrs 9 Mins 32 Secs
    pertamax boss..
    sesama pemakai cardas juga..
    Talking
    Quote Originally Posted by RiEEE View Post
    pertamax boss..
    Heheheee......thanks bro....
    kasi testi dong gimana hasilnya pake tu cardas biar pada tau
    tar kalo ane dikira gak fair sbg penjual nya ... hehehee..... :smt020
    Talking Booked
    Bump UP UP siang2 ....
    uda ada yg booked
    1 Mth 3 Wks 4 Days 12 Hrs 11 Mins 37 Secs
    Bantu up buat boss alam sutera.kekekkekekek
    Quote Originally Posted by ABCdef123 View Post
    bisa aja bro... ane mah cuman tkg sayur di sini kok .... heheee...... laen yg juragan GDS kan ....
    UP minggu ahh....
    Thumbs up Sold ukuran kabel spk A aja
    Update SOLD only Cardas SPEAKER cable yg (A) ukuran 404+407 cm SOLD to Boz ABC*** today
    Cable yg laen masih ada kok
    Thanks Boz "ABC***"....tinggal nunggu testinya neh ..... heheee....
    semoga puass n berasa uenak ya.... :smt023
    btw jgn lupa undang kalo uda beress semua pasangnya ya....
    thanks to Modcom juga n modcomers ....:smt033 :smt055
    malem2 absen lapak ... UP
    UP
    UP UP UP
    UP UP UP UP
    UP UP UP UP UP
    UP UP UP UP UP UP
    UP UP UP UP UP UP UP
    UP UP UP UP
    UP UP UP UP
    UP UP UP UP
    UP UP UP UP
    UP UP UP UP
    UP UP UP UP
    UP UP UP UP
    UP UP UP UP
    UP UP UP UP
    UP UP UP UP
  1. WTS : Interconnect & Speaker Cable - Cardas, Kimber, QED, Rapport
    By adelphi in forum Cables & Interconnects
    Last Post: 27th September 2012, 22:32
  2. Cardas Crosslink Interconnect with Vermouth RCA Connector
    By vermouth_audio in forum Cables & Interconnects
    Last Post: 20th July 2012, 21:31
  3. WTS : Kabel speaker Cardas Crosslink 2x2meter (biwire)
    By ABCdef123 in forum Bursa Audio Lainnya
    Last Post: 29th February 2012, 14:58
  4. WTS : Kabel Speaker Cardas Crosslink Biwire (2x 1,5m)
    Last Post: 23rd September 2011, 08:50
  5. Jual kabel speaker "Cardas Crosslink" (SOLD!!!)
    By william_bintoro in forum Bursa Audio Lainnya
    Last Post: 4th October 2009, 17:03
