Fusion EN-PK 112+PP-CM65 (Sub,power,box+Speaker Split)
Results 1 to 10 of 13
  • Short URL:  http://modifika.si/199059
    1 Wk 8 Hrs 34 Mins 1 Sec
    Jual Fusion Sub 12+Box, Power 2 channel, n Speaker Split
    Harga Semuanya 2JT
    EN-PK112
    Barang seken
    Terdiri dari Box Fusion,Sub 12inc,Power 2Channel
    Minus : Kabel2 instalasi dan kawan2nya dah nggak ada
    Spek :
    Fusion Encounter 12" Bass Pack
    For ultimate bass, and everything you need to install it.
    The Encounter 12 Bass Pack includes;
    - Encounter 12 Loaded Enclosure (400 Watts Max)
    - Encounter 2 Channel Amplifier (EN-AM3002 300 Watts Max)
    Loaded Enclosure Features
    Heavy Duty Construction
    High quality, heavy duty board creates a solid enclosure, which is lined with acoustic dampening material to produce extreme bass
    Heavy Duty Terminal Cups
    Ensures a secure bond and efficient signal flow from your amplifier to your subwoofer in order to deliver clean sound
    Unique Encounter Detailing
    The two 3 aero ports and chromed side panel design feature unique Encounter detailing, ensuring your vehicle will always leave an impression
    Amplifier Features
    Multi-Function System Management Panel
    Enables you to easily tailor the characteristics of the signal to your audio preferences
    Integrated End Caps
    Stylish end caps fit seamlessly to protect connections, terminals and the heat sink against alien objects and create clean lines for clean installations
    Screw Down Connectors
    Efficient screw down connections ensure a secure bond between components in the audio system
    Thermally Dynamic Heat Sink
    Thermally efficient heat sink structure designed to keep components within accepted heat tolerances
    Product Specifications
    Loaded Enclosure
    Power Rating: 400 Watts (Max)
    Woofer Size: 1 x 12"
    Voice Coil: 2" Kapton Four Layer Voice Coil
    Impedance: 4 Ohm
    Box Dimensions: (H) 375mm x (W) 423.4mm x (L) 524 mm
    Amplfier Specifications
    Maximum Power: 300 Watts
    RMS Power Output: 92 Watts RMS per Channel @ 2 Ohms
    180 Watts RMS Bridged Channels @ 4 Ohms
    Frequency Response: 10Hz - 40kHz
    Low-Pass Crossover: 40Hz - 160 Hz
    High-Pass Crossover: 40Hz - 600Hz
    PP-CM65
    Barang Seken.
    Spek :
    PowerPlant 6.5" Component Speaker System
    Detailed Light-Weight Polypropylene Cone
    Rigid, light-weight cone for accurate reproduction of mid bass frequencies.
    Industrial Cast Basket
    Provides maximum structural stability enhancing sound quality
    Moulded Terminal Wire Connector
    Ensuring fluid connectivity and consistent sound through specifically moulded terminal wire connections
    Sound Dispersing Tweeter Housing
    The PowerPlant tweeter housing disperses high frequency sound, expanding the sound stage.
    Gold Plated Connectors
    High end componentary and gold plated wire screw connectors ensure fluid connectivity
    Max Power Rating: 180 Watts
    RMS Power Rating: 60 Watts
    Compliance (Cms): 676.3
    Cone Area (Sd): 13.68
    D.C. Coil Resistance (Re): 3.3
    Electrical Q (Qes): 0.733
    Force Factor (Bl): 4.48
    Free Air Resonance (Fs): 55
    Frequency Response:52Hz - 21kHz
    Impedance (Nominal): 4
    Mechanical Excursion (mm): 12
    Mechanical Q (Qms): 7.04
    Sensitivity (dB) (1W/1M): 91
    Total Loudspeaker Q (Qts): 0.66
    Magnet Structure (Oz): 12.6
    Gambar :
    EN-PK112
    Kiri kanan sama gan ada plat besinya gitu
    PP-CM65
    Call :
    021-99683542
    081311382505
    COD : Pejaten
    Tanks B4
    :eek::eek::eek:
    17 Hrs 26 Mins 3 Secs
    up.............
    Quote Originally Posted by rin_dix View Post
    up.............
    MUAKASIHHHHHHHHHHHHHHHHHH gannnnnnnnnnnnnnnnnnn....
    Makasar,Jak-Tim
    2 Mths 6 Days 21 Hrs 9 Mins 46 Secs
    Thumbs up
    mantaf,...
    Bantu Up,......
    Quote Originally Posted by tsgwinahyu View Post
    mantaf,...
    Bantu Up,......
    Makasiii pa bossssss.......
    :eek::eek::eek::eek::eek::eek:
    :o:o:o:o:o:o:o:o:o:o:o:o
    :smt115:smt115:smt115:smt115:smt115:smt115:smt115: smt115:smt115
    :o:o:o:o:o
Venom 300x250 GT Radial
  1. Power, Monoblok, speaker, sub Fusion SPL kuenceng
    By coolz in forum Speaker - SubWoofer
    Last Post: 20th May 2013, 16:44
  2. Power, Monoblok, speaker, sub Fusion SPL kuenceng
    By coolz in forum Power Amplifier
    Last Post: 19th August 2010, 16:58
  3. Fusion PP-CM65 / JL Audio XR650-Csi / Morel Hybrid 1
    By Jodz.comunity in forum Diskusi Speaker
    Last Post: 30th July 2010, 22:00
  4. Replies: 77
    Last Post: 10th June 2010, 20:51
  5. Speaker Fusion 6,5" inch (Split 2 way)
    By kecoa_yuckfou in forum Speaker - SubWoofer
    Last Post: 4th March 2010, 11:55
