Promo : New Product Power Amplifier AUDIOSYSTEM mosconi dan X-ion
  • Short URL:  http://modifika.si/199011
    www.cliport-audio.com
    1 Wk 4 Days 1 Hr 13 Mins 22 Secs
    AUDIOSYSTEM MOSCONI AS 100.4
    Technical Features
    Stereo power RMS @4ohm: 4 x 105 Watt
    Stereo power RMS @2ohm: 4 x 160 Watt
    Bridge power RMS @4ohm: 2 x 320 Watt
    Bridge power RMS @2ohm: 2 x 480 Watt
    Input sensitivity range: V 0.2 - 5
    High pass filter range (switchable): 20 - 175 Hz 12 dB/Oct
    Low pass filter range (switchable): 50 - 300 Hz 12 dB/Oct
    Band pass filter: available
    Internal fuse: 80A
    Dimensions (mm): 350 x 200 x 50
    AUDIOSYSTEM MOSCONI AS 100.2
    Technical Features
    Stereo power RMS @4ohm: 2 x 100 Watt
    Stereo power RMS @2ohm: 2 x 165 Watt
    Bridge power RMS @4ohm: 1 x 330 Watt
    Bridge power RMS @2ohm: 1 x 500 Watt
    Internal fuse: 40A
    Dimensions (mm): 215 x 200 x 50
    AUDIOSYSTEM X-Ion 70.4
    Technical Features
    4-Channel High Power Class-AB amplifier with SMD technology
    MOSFET PWM Power Supply
    Stable into 2 ohm stereo per channel and 4 ohm bridged mode
    Input Sensitivity: variable 200 mV maximum to 8 V minimum
    Multi-Way-Protection-Circuitry
    Operating Voltage: DC 10 ~ 16 V power input
    Massiv heavy aluminium-heatsink with fan cooling
    4x 70 Watt 4 Ohm
    4x 90 Watt 4 Ohm
    2 x 180 Watt 2 Ohm
    Dimensions: 234 x 180 x 58 mm
    AUDIOSYSTEM X-Ion 100.2
    Technical Features
    2-Channel High Power Class-AB amplifier with SMD technology
    2x 100 Watt 4Ohm
    1x 500 Watt Mono 2Ohm
    Cliport Car Audio Division
    Adress : Jl. Sumbawa No 60 (BANDUNG)
    Office Number : (022) 73404522
    Rikky : 081221420030
    PIN : 21FE62AA
    Customer Support@Cliport Car Audio
    YM : cliportaudio_cs
    Up up up up up up up up
NGK Busi GT Radial
  1. New Product Amplifier AUDIOSYSTEM X-ion 70.4
    By cliport in forum Diskusi Power Amplifier
    Last Post: 12th August 2010, 00:50
  2. Replies: 6
    Last Post: 9th July 2010, 15:33
