FS **** SCANSPEAK 23 W **** SOLDDDDD
  • Short URL:  http://modifika.si/198653
    BAndunG
    1 Mth 1 Wk 3 Days 2 Hrs 2 Mins 38 Secs
    The Scan-speak 23W/4557T is a very high end subwoofer, designed to be used with a passive radiator in a small enclosure. This sub has a very rigid aluminum cone, low loss rubber surround and cast frame. The passive radiator is similar, but with a weight attached to the bass of the cone. The 23W/4557T is using the SD-1 motor system. There are gold plated binding posts and the woofer is covered by a decorative rubber cap.
    Frequency response with the passive is down to 25Hz. One cubic foot sealed has an F3 of 33Hz.
    TECHNICAL DATA:
    Sensitivity 2.83V/1M 82 dB
    Free air resonance Fs 20.5 Hz
    DC resistance 3.45 ohm
    V.C. inductance 0.45 mH
    Power 225 W
    Effective cone area 232 cm2
    V.C. diameter 50 mm
    VC height -
    Air gap -
    Lin. & max. excursion 13 / 20 mm
    Air gap flux density -
    Force factor BL Product 9.3 Tm
    Moving mass incl. air 101 g
    Net weight 4.6 kg
    Vas 45.6 ltrs
    Qms 4.8
    Qes 0.52
    Qts 0.47
    Outside diameter: 255mm
    Cut out: 225mm
    Depth: 135mm
    25.4mm = 1" = 2.54cm
    Mint Conditions
    SOLDDD 2,5 mio
    Call / sms only 0855 21888 18
    WhatsApp *0855 21888 18*
  2. Autopro
    PangkaL Paha
    2 Wks 5 Days 1 Hr 8 Mins 45 Secs
    pertamax barang cihui
    bandunk
    20 Hrs 16 Mins 30 Secs
    mantep deh
    BAndunG
    SOLDDDDDDDDDDDDDDDDDDDD
  1. Dijual Scanspeak R7000 + Scanspeak 18W
    By asawendo in forum Speaker - SubWoofer
    Last Post: 9th November 2012, 00:44
  2. Replies: 11
    Last Post: 9th October 2012, 11:32
  3. Power 4 Chanel or 5 Chanel For Scanspeak R 7000 + Scanspeak 15 W
    By xsmxl in forum Diskusi Power Amplifier
    Last Post: 9th February 2012, 11:03
  4. SOLDDDDD
    By f3lix_lie in forum Merk Lainnya
    Last Post: 20th January 2010, 08:06
  5. SOLDDDDD!!
    By anakrave in forum Merk Lainnya
    Last Post: 21st May 2009, 20:19
