Promo : New Product Amplifier REVOLUTIONARY from AUDIOSYSTEM (MOSCONI & X-Ion)
Results 1 to 7 of 7
  • Short URL:  http://modifika.si/198311
    www.cliport-audio.com
    1 Wk 3 Days 22 Hrs 14 Mins 7 Secs
    AUDIOSYSTEM MOSCONI AS 100.4
    Technical Features
    Stereo power RMS @4ohm: 4 x 105 Watt
    Stereo power RMS @2ohm: 4 x 160 Watt
    Bridge power RMS @4ohm: 2 x 320 Watt
    Bridge power RMS @2ohm: 2 x 480 Watt
    Input sensitivity range: V 0.2 - 5
    High pass filter range (switchable): 20 - 175 Hz 12 dB/Oct
    Low pass filter range (switchable): 50 - 300 Hz 12 dB/Oct
    Band pass filter: available
    Internal fuse: 80A
    Dimensions (mm): 350 x 200 x 50
    AUDIOSYSTEM MOSCONI AS 100.2
    Technical Features
    Stereo power RMS @4ohm: 2 x 100 Watt
    Stereo power RMS @2ohm: 2 x 165 Watt
    Bridge power RMS @4ohm: 1 x 330 Watt
    Bridge power RMS @2ohm: 1 x 500 Watt
    Internal fuse: 40A
    Dimensions (mm): 215 x 200 x 50
    AUDIOSYSTEM X-Ion 70.4
    Technical Features
    4-Channel High Power Class-AB amplifier with SMD technology
    MOSFET PWM Power Supply
    Stable into 2 ohm stereo per channel and 4 ohm bridged mode
    Input Sensitivity: variable 200 mV maximum to 8 V minimum
    Multi-Way-Protection-Circuitry
    Operating Voltage: DC 10 ~ 16 V power input
    Massiv heavy aluminium-heatsink with fan cooling
    4x 70 Watt 4 Ohm
    4x 90 Watt 4 Ohm
    2 x 180 Watt 2 Ohm
    Dimensions: 234 x 180 x 58 mm
    AUDIOSYSTEM X-Ion 100.2
    Technical Features
    2-Channel High Power Class-AB amplifier with SMD technology
    2x 100 Watt 4Ohm
    1x 500 Watt Mono 2Ohm
    Cliport Car Audio Division
    Adress : Jl. Sumbawa No 60 (BANDUNG)
    Office Number : (022) 73404522
    Rikky : 081221420030
    PIN : 21FE62AA
    Customer Support@Cliport Car Audio
    YM : cliportaudio_cs
  2. Hokinusa
    7 Hrs 32 Mins 41 Secs
    Mantabs nih boss...
    Quote Originally Posted by jabrickz View Post
    Mantabs nih boss...
    Pastinya mas budi
    up........................
    up.............................
    up up up up up up up up up up
    Up up up up.........
Venom 300x250 MBtech
  1. New Product Amplifier AUDIOSYSTEM X-ion 70.4
    By cliport in forum Diskusi Power Amplifier
    Last Post: 11th August 2010, 23:50
  2. Replies: 1
    Last Post: 4th July 2010, 22:22
