[WTS] KENWOOD KAC-M845 Max. 720W (kondisi 99,99%) MURAH & MANTAPPP
Results 1 to 7 of 7
  • Short URL:  http://modifika.si/198114
    FOR SALE
    KENWOOD KAC-M845 4/3/2 ch. Power Amplifier dengan Spesifikasi sbb.:
    Kondisi 99,99% (baru buka boks aja, blum pernah dipasang)
    Kelengkapan komplit plit
    Dijual karena beli ngga jadi dipake, dah pake power amp. yang lain
    - 720W Maximum Power Output
    - 60W RMS x 4 at 4 ohms (20-20kHz 1.0% THD)
    - 90W RMS x 4 at 2 ohms (1kHz 1.0% THD)
    - 180W RMS x2 at Bridged 4 ohms (1kHz 1.0%THD)
    - Aluminum Die Cast Heat Sink
    - Power MOS-FET Switching Power Supply
    - Speaker Level Input
    - Built-in Variable Low-pass Filter 50-200Hz (12dB/oct) Bch
    - Built-in Fixed High-pass Filter 80Hz (12dB/oct) Ach
    - 2-ohms Load Capability
    - Gold Plated Power & Speaker Terminal
    - Cooling Fan
    - Size: W 330.0mm x H 59.0mm x D 230.0mm
    Harga : Rp 1.900.000 nett
    COD dimana aja daerah JakSel
    Buat yang minat serius Call/SMS 0838 96 1000 82
    bumppppp....
    bump...bump...bump
    up..up..upp
    sunduuullll lagiii....
    up...up..up
    sundul lagi ah..dah lama
Tekiro NGK Busi
  1. Kenwood DPX-MP6110U (Second Kondisi Mulus)
    By cliport in forum Head Unit & Processor
    Last Post: 28th August 2012, 21:26
  2. Bracket Speaker Mantappp murah!!!!
    By jlu_mike in forum Bursa Audio Lainnya
    Last Post: 25th July 2011, 08:57
  3. Replies: 6
    Last Post: 17th January 2011, 15:50
  4. Replies: 20
    Last Post: 22nd April 2010, 21:26
  5. WTS : 2 DIN KENWOOD CD KONDISI OK ....solddddddddddddd
    Last Post: 11th July 2009, 08:54
