Helix Cap 33 - Noise suppressor for generator.........450rb
Results 1 to 10 of 10
  • Short URL:  http://modifika.si/196756
    Smile Helix Cap 33 - Noise suppressor for generator.........450rb
    If you are having problems with noise from your car hi-fi, specifically irritating alternator whines that comes and goes or permanently haunts your music enjoyment, I may have a remedy for you.
    Causes of alternator whines or locally termed "aeroplane noise" are bad wiring (running signal cables and wire cables together), a weak battery or charging sytem, bad grounding or ground loops and in many cases cheap amplifiers that are prone to a high noise floor.
    If you are haunted with alternator whine and additional grounding does not fix it then you might want to consider this gadget. Unlike the suppressors you see being used by low end installers, this really works without actually limiting the current flow or in layman's term supressing the power.
    The Cap 33 works like a small capacitor and is only rated at 33,000 (μF) microfarad. You basically connect it between your car's battery and it's alternator.
  2. SbcAgent
    28 Mins 1 Sec
    apa bedanya ama capbank boss? baru ato 2nd? pm dong boss nettnya? kalo bs si d sms 081371788485...thx
    sms sent bos,thanks.....
    2 Wks 6 Days 23 Hrs 25 Mins 59 Secs
    UP dulu.. si Bozz lg on VACATION.. jd buyers harap bersabar dikit..
    thanks yach bos andry............
    up..........................
    3 Wks 3 Days 15 Hrs 48 Mins 42 Secs
    up..buat barang yang jarang di liat orang..
    hehehe,thanks yach bro....
    tanya
    Ini gunanya apa? gmana cara pasangnya?
    kalau ini untuk menghilangkan noise bos rudy,pemasangannya di dekat accu atau alternator bos rudy.....
  1. POWER HELIX 4 CHANNEL HELIX B4 PRECISION. MURAH AJA GAN....
    By tandy suhendra in forum Power Amplifier
    Last Post: 1st September 2010, 02:11
  2. Generator Hidrogen
    By Trackdancer in forum Diskusi Otomotif Lain-Lainnya
    Last Post: 22nd July 2009, 10:32
  3. WTB: Vortex generator buat evo 7,8,9
    By killer7 in forum Bursa Eksterior Lainnya
    Last Post: 5th June 2009, 01:43
  4. Replies: 97
    Last Post: 18th March 2009, 12:20
