Alpine KCA-410C Ai-Net Multi Changer/Versatile Link Adapter-2 Chgr lengkap dus n segel Alpine Indonesia (Made in Japan)........sold
This is for an Alpine KCA410C Ai-Net Multi-Changer/Versatile Link Adapter. This magnificent accessory is in excellent condition! There are no dings or dents to be found on it! There some very light scuffs and scratches that can be seen on all six sides, though. There is also some velcro tape on the bottom that could probably be removed if needed and the mounting ears are slightly bent. Talk about versatile with this remarkable source adapter you can add up to two pieces of Alpine gear and gain two auxiliary inputs. That means You can access four separate sources (satellite radio, MP3 player, Bluetooth phone, etc.) through one Alpine in-dash stereo, potentially building any kind of stereo system you want. It connects to any 2001 or newer Alpine Ai-NET model receiver. The side of the adapter has an AI-Net output, Changer 1 and Changer 2 AI-Net inputs, AUX 1 and AUX 2 stereo RCA inputs, and IN-INT Audio interrupt, which is typically used with navigation systems. The top of the unit has external input level adjustments for AUX 1 and AUX 2. This outstanding adapter is just what you need to bring out the full potential of your car stereo system!
