[WTS] Crossover MTX LSX2 .........lelang aja (update foto) S O L D!!!
Results 1 to 10 of 11
  • Short URL:  http://modifika.si/196747
    udah di jakarta lagi
    1 Mth 1 Wk 2 Days 3 Hrs 55 Mins 13 Secs
    lengkap dus,manual, external bass control jg lengkap dengan dusnya
    gambar seperti ini:
    spec:
    Spoiler for spec: Show
    LSX2 Features
    * 2-channel, 3-way or 4-channel, 2-way
    * Dual high pass outputs with multiplier switch (front continuously adjustable on a scale of 30-400Hz or 600-8000Hz; Rear continuously variable from 30-400Hz)
    * Low pass continuously variable from 20-200Hz
    * Front and rear speaker level inputs
    * Phase reversal switch (180)
    * Up to 8 volt RMS input signal for integration with high voltage output source units
    * 18dB/octave slope for greater protection of mid-ranges and tweeters
    * Continuously adjustable crossover points
    * Wire harnesses for speaker level input allow easier integration with OEM systems
    * 1 Meg Ohm Isolation maintained between the Signal Ground and Power Supply Ground (eliminates ground loop noise)
    * External Bass Control (EBC) port connects to optional, dash-mountable EBC unit
    dijual dengan penawaran tertinggi...
    temen nawar 200rb..waktu ketemuan kumpul2, tp masukin modcom dulu ah..
    please posting disini penawaran biar gak hoax n semua bs baca, thx all
    bid:
    Quote Originally Posted by adi_coy View Post
    seratus lima puluh ribu rupiah
    Quote Originally Posted by vidya.prasta View Post
    bid : 200 gan
    dibid lg sm bro vidya:
    bid : 225 gan
    di kaskus udah dibid 250rb by Lidyamanda/makassar
    http://www.kaskus.us/showthread.php?p=230810219#post230810219
    ada lg???
    uuuuuuuuuuuup
    18 Hrs 3 Mins 2 Secs
    coy, kok malah diturunin...
    jogjakarta
    18 Hrs 51 Mins 12 Secs
    bid : 200 gan
    last bid 200 bro vidya, ada lg??
    jogjakarta
    bid : 225 gan
    up..............
    update foto gan
MBtech Venom 300x250
  1. foto kenangan GD3 (update)
    By deps in forum Honda
    Last Post: 12th March 2013, 04:05
  2. Replies: 427
    Last Post: 16th February 2013, 15:59
  3. 206 '01 standar :) (update foto: 25 Jul '10)
    By dhaninugraha in forum Peugeot
    Last Post: 18th January 2011, 12:42
