Review Kenwood DDX8036BT (2din DVD)
Results 1 to 10 of 31
  • Short URL:  http://modifika.si/196494
    =BANDUNG=
    14 Hrs 23 Mins 40 Secs
    mau review nih.. kebetulan baru ganti TV baru dari Alpine W202E ke Kenwood DDX8036BT.. Seperti kata suhu-suhu audio, Kenwood itu cupu buat audio mobil.. berarti ini termasuk downgrade...
    Spesifikasi teknis:
    __________________________________________________ ________________
    KENWOOD DDX8036BT
    General
    • 7.0 inch Wide VGA High Resolution Colour TFT Display with LED Backlight
    • Number of pixels: 1,152,000
    • Auto Slide & Removeable Face panel with reverse tilt mecha.
    • Touch Panel Control with 3D GUI and Touch Sensor Key
    • Background Customize
    • Variable Color Key LED
    • 2USB interface(Mass Strage, iPod Direct Cotrol)
    • SD Card Slot
    • Multi Language x 18 (Menu & Tag)
    - English, Turkish, Arabic, Simplified Chinese, Persian, Thai, Malaysian, Indonesian and Others
    Audio/Video
    • MOS-FET 50W x 4 AMPLIFER
    • 24bit DAC, 5.1ch DSP
    • MP3/WMA/AAC, MPEG 1/2/JPEG/DivX Playback
    • Dolby Digital, DTS w/Dolby Prologic II and SRS WOW
    • 4 Band Parametric EQ, 13 Band Graphical EQ
    • Dual Zone Source & Volume Control
    • X'Over w/HPF&LPF Cut Off Frequency
    • Time Alignment
    DVD/CD
    • DVD Video/ħR/RW/CD-DA/-R/RW/VCD
    • MP3/WMA/AAC
    • MPEG1/MPEG2/DivX
    USB & SD
    • MP3/WMA/AAC/WAV
    • MPEG1/MPEG2/MPEG4/WMV/H.264/JPEG
    Tuner
    • FM/MW 24 Station Presets (18FM, 6MW)
    Connection
    • USB Interface x 2
    • iPod USB Direct Connection with Optional cable (KCA-iP301V)
    • 5.1ch Gold Preouts with 5V Pre-output Level
    • 2 RCA AV Inputs
    • 1 RCA AV Output
    • Rear View Camera Input x 1
    • TV Ready with Optional TV Tuner Unit (KTC-V300P/N)
    • Advanced NAVI IF
    Bluetooth (2.1+EDR Certified) Built-in(HF/SMS/A2DP/AVRCP Profile)
    Accessories
    • Remote Controller (RC-DV340)
    • Handsfree Microphone
    Gambar:
    Review:
    Kelebihan:
    Layar 7 inch nya High Definition dan LED backlight, dengan jumlah pixel yang banyak dan layar 100kHz refresh rate dan contrast yang luar biasa, saat ini inilah TV 2 din yang paling bagus gambarnya, bahkan melebihi Sony XAV-W1 dan Alpine W502.
    TV terlihat manis dan hampir borderless, bagian casing sampingnya hanya selebar 1 mm
    Ada automatic back tilt, jadi tiap TV dinyalakan bisa otomatis angle bergerak ke angle yang kita set. Back angle berguna untuk dash 2 din yang tidak vertikal tetapi miring, sehingga kalo terkena sinar matahari bisa mengurangi kontrasnya. TV ini bisa mengurangi itu dengan bergerak backtilt 1 langkah sehingga posisi layar lebih vertikal. simple thing, huge different.
    Slot ekspansi paling lengkap dari seluruh TV 2 din ber merk. Tv tuner slot nya sendiri, ipod slot sendiri, 2 input AV, 1 input USB, GPS slot sendiri, Bluetooth sendiri, changer hingga 2 slot, SD card slot.
    LCD bisa dicopot (retract)- aman dari maling.
    Anti-theft code security
    iPhone GUI, sliding dengan jari
    5.1 DTS dolby nya jalan, dan ada digital time alignment (prosesor internal)
    Suaranya enak
    Remote luar biasa lengkap dan mudah
    Packagingnya lengkap; dapet Tv tuner kenwood antena dalam, bluetooth mic, kabel usb dan ipod, pembersih.
    _____
    Kekurangan:
    GUI nya merepotkan... Sampah banget deh.. User friendly tapi nggak responsif sama sekali. Fitur stereoscopic saya matikan agar nggak tambah merepotkan
    DTA nya maksimal jarak ruang cuma 170cm, dan ketelitiannya cuma 1 sekon, (PXA 0,1 ms)
    Cuman 2 itu sih...
    Result: PUASSSS!!!
    CMIIW ya.. mohon maaf newbie ini...
    4 Hrs 24 Mins 18 Secs
    Keren Reviewnya bro :smt023
    Dapet harga berapa nih? Bisa Playback film HD gak?
    =BANDUNG=
    harganya sekitaran 12an bro...
    untuk playback nya cuma MPEG1/MPEG2/MPEG4/WMV/H.264/JPEG, kalo MkV sama M2S belum bisa bro.. tapi untuk playback nya bisa nerima video sampe resolusi 720i dengan screen 16:9 bro.. saya sudah coba.. kalo 720p belum coba..
    Emang HU mantap nih....!!! Saya pakai seri di bawahnya: DDX7036BT. Tadinya kepikiran antara DDX8036BT atau DDX7036BT, tapi berhub. gak butuh features yg jadi perbedaanya dan bisa menghemat 2jt, jadinya ambil seri di bawahnya aja.
    Quote Originally Posted by entut View Post
    Kelebihan:
    Lebih tepat istilahnya bukan back tilt, tapi Reverse Tilt. Ini kelebihan HU double DIN monitor Kenwood dari seri2 terdahulu, yaitu sudut kemiringan bisa diset menunduk. Cocok buat penempatan HU di dashboard yg posisi aslinya mendongak ke atas, krn bisa mengurangi efek sinar matahari langsung. HU monitor double DIN merek lain kebanyakan justru cuma bisa diset kemiringan ke arah makin mendongak ke atas, bukan menunduk.
    Dgn Reverse Tilt, layar tetap terlihat walau ada sinar terang dari atas
    Setau saya Kenwood seri ini gak bisa dicolok DVD/CD changer lagi (CMIIW). Yg ada juga DDX8036BT punya 2 colokan USB, satu utk mass storage, satunya lagi utk iPod direct control (kalo DDX7036BT berhub. cuma 1 USB, jd hrs gantian antara buat mass storage atau iPod).
    5.1 processor ini salah satu yg ngebedain DDX8036BT dgn DDX7036BT. Berhub gak niat pasang center speaker, makanya ambil seri di bawahnya aja (walau tanpa center speaker beneran katanya tetap bisa dibikin semacam phantom center channel).
    Suaranya enak
    Gak diragukan lagi emang suaranya oke... Saya aja cuma pake speaker OEM bawaan mobil. Abis selesai di-install, hilang niat buat ganti speaker.
    Kekurangan:
    Cuman 2 itu sih...
    Result: PUASSSS!!!
    Nah... Sama juga nih... Walau puas tapi sayang masih ada sisi kekurangannya.
    Emang response GUI nya lemot banget. Response utk kebanyakan menu setelah di-touch screen-nya kelewat lambat, kadang bisa sampe 3 detik gitu. Jadi sering ngira bhw touch-nya gak kena/gak bener dan diulang lagi, pdhl yg pertama udah kena tapi lambat aja response-nya.
    Tambahan:
    HU generasi 2010 Kenwood ini punya kekurangan lain yaitu suka nge-reset settings-nya tanpa ada sebab. Emang bisa tinggal di-recall krn hampir seluruh settings-nya bisa di-memory. Tapi rese aja kalo baru nyalain mobil tiba2 minta initial settings lagi (tandanya HU tsb baru nge-reset sendiri).
    Kabar baiknya (semoga)i...
    Barusan saya ngubek2 online, ada firmware tebaru buat bbrp tipe HU Kenwood generasi 2010. Seri DDX7036BT dan DDX8036BT termasuk di dalamnya (baca keterangan ini).
    Mau saya cross check dulu dgn firmware yg ada skrg di mobil, siapa tau beda, jadi emang kudu upgrade. Mudah2an ada perbaikan dari sisi response dan masalah nge-reset ini.
    =BANDUNG=
    Quote Originally Posted by aidil View Post
    Berhubung saya bangun mobil dengan konsep car theater sehingga adanya prosesor 5.1 sangat krusial buat saya. Oiya dan saya rasa perbedaan 2 juta itu reasonable yah.. banyak sekali perbedaannya; DSP vs 5.1, 5 pEQ vs 13 pEQ, preout 3v vs 5v, slot usb 2, av 2...
    Ho ho.. iya2 bener reverse tilt... betul2.. ini fitur kecil tapi sangat berguna...
    wah di all new city ya.. kreatif juga pake wallpaper Honda
    Bisa bro, ada slot switch box buat ngontrol dvd changer, nah kalo saya berhubung dipake di car theater, saya butuh ekspansi untuk multimedia, jadi hampir semua lubangnya saya pake, TV tuner biasa, AV1 TV digital, AV2 GPS AVT, iPod Video, USB, Bluetooth, yang nggak dipake adalah slot GPS kenwood, karena mahall.. hihihi
    Betul.. kalo masih speaker standar ya nggak perlu 5.1.... nah repotnya kalau nanti mau upgrade audio jadi car theater..
    Betul2.. GUI nya sampah abis... ga habis pikir saya, fitur melimpah tapi hal kecil paling krusial nggak dipikirin. malah memaksakan tampilan 3D dan touch sensor.. sama seperti kita beli mobil mewah, inden 4 bulan, setelah dapat interiornya abu-abu butek kotak-kotak.. padahal kita tinggal di dalam interiornya... :mad:
    Tambahan:
    Bro saya nggak tau di seri 7, tapi di punya saya ada 4 channel buat nge-save settingan di audio control... jadi nggak pernah nge-reset... mungkin settingan anada belum di save...
    CMIIW :cool:
    Soal firmware, cek posting ini bro:
    http://modifikasi.com/showthread.php?t=196598
    =BANDUNG=
    Makasih infonya bro.. i appreciated it
    Honoured Member
    Thumbs up
    Mantabz reviewnya nich baik Bro Entut dan Bro Aidil dua-duanya very informative thank you thank you..
    By the way berapaan sich harganya? Tertarik juga melihat fiturnya yang cocok untuk dijadikan Car & Multimedia Theater...
    Best Regards
    Wendo
    =BANDUNG=
    kalo saya di seri DDX8036BT harganya sekitaran 12an pak bos wendo...
    Honoured Member
    Ok thank you thank you, gambar positif lebih baik dari Sony XAV yaa sesuai hasil review?!
MBtech Tekiro
  1. SALE: KENWOOD 2DIN DDX 7039 + GPS KENWOOD KNA G430
    By Eri69 in forum Head Unit & Processor
    Last Post: 15th June 2012, 16:48
  2. [WTS] HU Kenwood DDX8036BT
    By dodoes in forum Head Unit & Processor
    Last Post: 25th April 2012, 08:50
  3. fs:hu kenwood DDX8036bt
    By erwin_ongko in forum Head Unit & Processor
    Last Post: 19th April 2012, 15:22
  4. cari &tanya harga kenwood ddx8036BT
    By rubben in forum Diskusi Head Unit & Processor
    Last Post: 11th August 2011, 07:42
  5. Replies: 7
    Last Post: 14th December 2009, 23:19
