WTS : ARC Audio FD 4100 HARGA BAGUS!!! (Stock Hanya 1pcs)
Results 1 to 10 of 36
  • Short URL:  http://modifika.si/196451
    www.cliport-audio.com
    1 Wk 4 Days 1 Hr 13 Mins 22 Secs
    ARC Audio FD 4100 barang baru berhubung stock nya tinggal 1pcs kita kasih harga bagus Rp 3,230,000 nett (diluar ongkos kirim)
    Description:
    Independant front and rear 12dB stereo crossover 55Hz to 5.5KHz
    Seperate front and rear high/low/full range select switch
    4 channel/2 channel or 2 channel with bass select
    Seperate front and rear mono/stereo/bridged select feature
    18dB bass control at 45Hz select feature
    Protection against: reverse voltage, over voltage, speaker short, and thermal overload
    Heavy duty construction
    Specifications:
    Output power: 50x4 @4 ohms, 90x4 @2 ohms, & 180x2 @4 ohms bridged
    Transient distortion: <0.1% @4ohms
    Frequency response: 20Hz-20Khz
    S/N ratio (A wtg): >95dB
    Bass boost: +18dB@45Hz
    Input sensitivity: 250mV - 2.5V
    Crossover: 55Hz variable 12dB
    Fuse: 40A x1
    Dimensions: 10 3/8" x 17 3/4" x 2 3/8"
    FD 4100 - ARC Audio 4 Channel 360 Watt Amplifier FD4100 FD-4100
    Cliport Car Audio Division
    Adress : Jl. Sumbawa No 60 (BANDUNG)
    Office Number : (022) 73404522
    Rikky : 081221420030
    PIN : 21FE62AA
    Customer Support@Cliport Car Audio
    YM : cliportaudio_cs
    Malang - Jakarta
    2 Days 6 Hrs 7 Mins 50 Secs
    pm nett nya bro..
    Uda pake brp lama? Pernah servis nda y?
    Quote Originally Posted by f&y View Post
    pm nett nya bro..
    Barang baru bos, harga udah nett
    Up up up up up up up up up up up up up up up up up up up up
    up up up up up up up up up up up up up up up up up up up up up up up
    up up up up up up up up up up up up up up up up up up up up....................
GT Radial NGK Busi
  1. WTS: LM AUDIO 4ch 4100.4 cooper series
    By Yotto in forum Power Amplifier
    Last Post: 29th December 2012, 14:20
  2. WTB Genesis Four channel / ARC SE 4100 & Dyna Audio 17 WLQ
    By dragonid in forum Power Amplifier
    Last Post: 1st June 2012, 14:21
  3. audio fullset: 2 power , speaker 3 way , sub. HARGA BAGUS
    By gd8owner in forum Speaker - SubWoofer
    Last Post: 1st March 2012, 01:47
  4. WTB ARC Audio 4100 SE
    By newbieaudio88 in forum Power Amplifier
    Last Post: 23rd November 2011, 07:38
