YANG PAKE MESIN HONDA ZC DOHC NGERUMPI DISINI YUUU..
Results 1 to 10 of 24
  • Short URL:  http://modifika.si/196214
    State of Qatar, Middle East
    12 Hrs 39 Mins 58 Secs
    Ini thread buat ente2 yg mesin mobilnya udh di swap ke mesin Honda seri ZC utk dipake Drag, sekedar kenceng buat harian atau emang bawaan mobilnya.. Daripada jadi anak tiri ngobrol di threadnya orang2 yg pake mesin seri B, F dan K mendingan kita ngerumpi disini aja ama sesama pencinta mesin ZC.. Mari kita berbagi info, tekhnik dan trik utk bikin mesin ZC kita makin yahud..
    Sebelumnya gw perkenalkan mobil gw dlu..
    Gw pake Honda Civic Si Gulf Spec karna gw tinggal di Qatar, ini foto2 mobil gw:
    http://www.facebook.com/album.php?ai...43712884&op=18
    Mobil udah pernah dipake gaul beberapa bulan, sekarang saatnya mo gw korek abis buat time attack..
    Ini sedikit info soal ZC dari berbagai sumber:
    ZC similar to D16Y4, D16A8, D16Z6, D16A1, D16A3, D16A6, D16A9 and D16Z5 engines
    A few D-series variants are labelled (Japanese: Honda ZC engine) (usually JDM), but they are not truly a different series.
    There are both SOHC and DOHC ZC engines.
    The non-VTEC SOHC ZC is similar to the D16A6 ('91 - '96) and D16Y4 ('96-2000) engine, but with more aggressive cam timing.
    The SOHC VTEC ZC is similar to the D16Z6 ('91 - '96).
    The DOHC ZC is similar to the D16A1, D16A3, D16A8, D16A9 and D16Z5 engines.
    DOHC ZC
    Found in 1986-1991 (JDM) Civic and CR-X
    Specs:
    Displacement : 1590 cmł
    Bore and Stroke : 75 mm X 90 mm
    1986-1987 Compression : 9.3:1 1988-1989 Compression : 9.5: 1
    1986-1987 Power : 113 hp (84.3 kW, 115 ps) @ 6250 rpm; Torque : 99 ft·lbf (13.7 kg/m, 134 Nm) @ 5500rpm (US)
    1988-1989 Power : 118 hp (88.0 kW, 120 ps) @ 6500 rpm; Torque : 103 ft·lbf (14.0 kg/m, 137 Nm) @ 5500rpm (US)
    1988-1991 Power : 130 hp (96.9 kW, 132 ps) @ 6800 rpm; Torque : 106 ft·lbf (14.7 kg/m, 144 Nm) @ 5700 (JDM)
    Valvetrain : DOHC
    Piston Code 1986-'87 : PG6
    Piston Code 1988-'89 : PM7
    Fuel Control : OBD-0 MPFI
    Euro Mk1 ('85-'87) 1.6 CRX's are fitted with an engine designated "ZC1" which is a higher spec 130 hp (96.9 kW, 132 ps) version of the D16A1. Which were later to be switched out with the D16A8 or B16A depending on which model.
    1st Gen ZC Identified by: External coil, small distributor, dual butterfly TB, cam cover bolts on top, brown/gold cam cover. Large cam pulleys. +3cc PG6B pistons, non-pent roof combustion chamber. As a ZC it appeared in JDM AV Integra Si and JDM E-AT Civic/CR-X Si. Commonly produced at the time but now over 20 years old and getting harder to find. D-series version D16A1 '86-'87
    2nd Gen ZC (rarest) Identified by: Internal coil, large distributor, single butterfly TB mounted on slight angle forward, bolts on top of cam cover, black cam cover, large cam pulleys. +7cc PM7 pistons, 43 cc Pent roof combustion chamber. As a ZC appeared in JDM facelift AV bodied Integra Si did not appear in Civic or CR-X, rarest ZC only produced for less than one year. D-series version D16A1 '88-'89 (sometimes +7cc P29 pistons)
    3rd Gen ZC Identified by: Internal coil, large distributor, single butterfly TB. Black cam cover. Cam cover bolts on the sides. Small cam pulleys. Inlet Manifold stamped PM7. +7cc PM7 pistons, 43 cc Pent roof combustion chamber. As a ZC appeared in JDM EF3 civic and EF7 CR-X, did not appear in an Integra body. Most commonly produced ZC, manufactured in Japan from end of '87 through to early '91 D-series version D16A8/9 (Euro Civic Si) (sometimes +7cc P29 pistons)
    4th Gen ZC Identified by: Internal coil. OBD1 EFi system (grey plug). No cam angle sensor on exhaust cam, now located in distributor. Rubber plug where cam angle sensor would mount. Black cam cover. No PGM-EFi plate on the inlet manifold, replaced with three ribs instead. P29 stamped on inlet manifold. MAP sensor on TB. +7cc PM7 pistons, pent roof combustion chamber. As a ZC only appeared in EG5 Civic bodies, no Integra or CRX received this engine. Reasonably common produced from '92 to '94. (20th Anniversary edition & Japanese car of the year) D-series version D16A8/9 (Euro & Australia Civic Si & NZ Civic Gti) (sometimes +7cc P29 pistons)
    The ZC will bolt right in to the 88-91 CRX/CIVIC no fabricating or welding is needed
    The swap can use your existing wiring harness if you have an SI, if you have a DX then minor modification is necessary.You can use the SI or DX transmissions, they both bolt up. You can also use the SI or DX flywheel.
    The engine only adds about twenty-five pounds to the front of the car, so your steering and suspension should be the same. If you are still concerned about the added weight, move your battery to your trunk.
    Identification:
    1st Gen ZC
    Identified by:
    External coil, small dizzy, dual butterfly TB, cam cover bolts on top, brown/gold cam cover. Large cam pullys.
    As a ZC it appeared in JDM AV integra Si and JDM E-AT civic/crx Si. Commonly produced at the time but now over 20 years old and getting harder to find.
    D-series version D16a1 86-87
    2nd Gen ZC (rarest)
    Identified by:
    Internal coil, large dizzy, single butterfly TB mounted on slight angle forward, bolts on top of cam cover, black cam cover, large cam pullies.
    +7cc PM7 pistons, 43cc Pent roof combustion chamber.
    As a ZC appeared in JDM facelift AV bodied integra Si did not appear in civic or CRX, rarest ZC only produced for less than one year.
    D-series version D16a1 88 - 89 (somtimes +7cc P29 pistons)
    3rd Gen ZC
    Identified by:
    Internal coil, large dizzy, single butterfly TB. Black cam cover. Cam cover bolts on the sides. Small cam pullies. Inlet Manifold stamped PM7.
    As a ZC appeared in JDM EF3 civic and EF7 crx, did not appear in an integra body. Most commonly produced ZC, manufactured in Japan from end of 87 through to early '91
    D-series version D16a8/9 (euro civic Si) (somtimes +7cc P29 pistons)
    4th Gen ZC
    Identified by:
    Internal coil. OBD1 efi system (grey plug). No cam angle sensor on exhaust cam, now located in Dizzy. Rubber plug where cam angle sensor would mount. Black cam cover. No PGM-EFi plate on the inlet manifold, replaced with three ribs instead. P29 stamped on inlet manifold. MAP sensor on TB.
    As a ZC only appeared in EG5 civic bodies, no integra or CRX received this engine. Reasonably common produced from 92 to 94. (20th Anniversary edition & japanese car of the year)
    D-series version D16a8/9 (Euro & Australia civic Si & NZ civic Gti) (somtimes +7cc P29 pistons)
    Technical data
    1.6L (1590 cc) DOHC
    130-135 hp @ 6800 rpm
    Bore 75.0
    Stroke 90.0
    C.R. 9.5:1 I can find no evidence of it being any higher than this.
    91 octane. Some have reported no problems with 87, but the specified gas is 95 and/or 96 RON, which is equal to 91-92 'pump octane' available in the US.
    idle -730rpm manual-700rpm auto
    static timing 16 deg BTDC manual and auto
    compression measure at 250rpm and wot----nominal 192psi(1,324kPa, 13.5kgcm2)
    minimum
    135psi(932kPa, 9.5kgcm2)
    maximum variation
    28psi(196kPa, 2kgcm2)
    cylinder head warpage limit 0.05mm(0.002")
    height 131.95-132.05mm
    valve clearances inlet 0.13-0.17mm(0.005"-0.007")
    exhaust 0.15-0.19mm(0.006"-0.008")
    stem to guide clearance in 0.02-0.05mm(0.001"-0.002") limit
    0.08mm(0.003")
    ex 0.05-0.08mm(0.002"-0.003") limit
    0.12mm(0.005")
    valve seat width ex&in 1.25mm-1.55mm(0.049"-0.061") limit 2.0mm(0.08")
    fuel - 96+ octane unleaded
    Parts list - Maintenance:
    Ignition/ timing parts
    OBD1 distributor
    TD43U
    OBDO Distributor
    TD03U 88-89 Integra .
    _________
    OBDO Distributor Cap
    30102-PM7-305 88-91 CRX Si/88-89 Integra OEM .
    . JP936 . WELLS .
    . 44-9620 . VALUCRAFT .
    . JP936G . GOLD .
    . 8290 . MSD w/Coil Bypass .
    _________
    Distributor Cap gasket
    OEM # 30132-PM5-A02
    Rotor Button
    88-91 Civic/CRX // 88-89 Integra
    Brand—–Part#
    OEM - 30103-PM5-A05
    WELLS - JP923
    VALUCRAFT - 33-8220
    Spark plug wires
    88-89 Acura Integra
    Brand—–Part#
    OEM -
    MSD - 32339
    MAGNECOR - 45125
    NGK - NGK-HE48
    NOLOGY - 011014011
    **If not going for High performance wires USE OEM all others are inferior except for performance wires.**
    Spark Plugs
    Dont waste your money on platinums or iridiums
    NGK is standard from Honda. If your Boosting the motor choose your type carefully as a standard plug is not for you, you will need a colder plug.
    88-91 Civic/CRX si 1.6L // 88-89 Integra
    Brand—–Part#
    NGK V-POWER - BCPR6E-11
    Spark plug tube seals
    86-89 Integra
    OEM # 12342-PT2-000
    Distributor O- ring and CPS O-ring
    88-89 Integra
    OEM # 30110-PA1-732
    Water Pump
    88-91 CRX/Civic
    Brand—–Part#
    ___________
    OEM - 19200-P01-003 or 19200-P01-004
    Water Pump Gasket
    *If your gasket is leaking You might as well get a new pump and it will come with the gasket*
    ___________
    Oil Pump
    88-91 Civic/CRX
    OEM # 15100-P06-A01
    Timing Belt
    1988 Prelude 2.0 Si.
    Brand—–Part#
    OEM - 14400-pk2-004
    NOTE:I have heard people get part #14400-pk2-003
    they should be the same
    Timing belt tensioner
    OEM part # 14510-PM7-004
    Gaskets and head parts
    Cylinder Head Gasket
    1988 & 89 Integra
    Brand—–Part#
    OEM - 12251-PM7-003
    FELPRO - 9451PT-1
    HKS BEAD - 2302-RH001 (0.7mm Thick/76mm Bore/9.9 CR)
    HKS GROMMET - 2301-RH010 (0.6mm Thick/76mm Bore/10 CR)
    _____________
    Head Studs ARP
    tunertoys.com sells the zc studs get them from their site
    http://tunertoys.zoovy.com/product/2...C_engines.html
    ___________
    Intake Manifold Gasket
    1988 & ‘89 Integra
    Brand—–Part#
    OEM - 17105-PG6-S00
    FELPRO - MS93362
    Exhaust Manifold Gasket
    1988 & ‘89 Integra
    Brand—–Part#
    OEM - 18110-PG6-003
    FELPRO - MS93363
    Header
    88 - 91 CRX/Civic Headers will fit. The ports are off just a tad but the bolt pattern is money. Nothing a little grinding can’t fix.
    Throttle Body
    88 - 91 Civic/CRX Si 1.6L
    Throttle Body Gasket
    88-91 Civic/CRX Si 1.6L only
    Brand—–Part#
    OEM - 16176-PM6-S00 or 16176-PM6-000
    Radiator Hoses
    *Upper: 88-89 Integra
    *Lower: 88-91 Civic/CRX
    Brand—–Part#
    OEM Lower Hose - 19502-PM3-000
    OEM Upper Hose -
    Valve cover Gasket
    86-89 Integra
    Brand—–Part#
    OEM - 12341-PM7-000
    Valve cover stud Grommets
    90-93 Integra 1.8L
    **OEM part # 90442-PR3-000
    Thermostat
    88-91 CRX/Civic
    Brand—–Part#
    Stant OEM TEMP - 45878
    Prestone OEM TEMP - 392180
    Fuel Injectors
    88 - 91 CRX/Civic Si / 86-89 Integra
    Fuel Injector
    Brand—–Part#
    OEM - 06164-PK2-010
    silinoids and electronic parts
    IACV (Intake Air controll valve)
    88-91 Civic/CRX
    oem # 36455-PT3-A01
    CPS (Cylinder Position Sensor)
    1988 & 89 Integra 1.6l
    Brand—–Part#
    OEM - 37841-PG7-006
    Alternator
    88-91 CRX/Civic
    Alternator:
    Get a NAPA if you must use other than OEM, but try to stay OEM here if you can. Advance and Autozone and most other parts stores Have VERY LOW quality replacements…**Why do you think they have to offer a lifetime warranty??..( a little something to make you think)
    Brand—–Part#
    OEM - 31100-PM8-A03RM or 31100-PM8-A03RMD
    Bottom End Components
    Rear Main Seal
    1988 & 89 Integra
    Brand—–Part#
    OEM - 91214-PH1-013
    Oil Pan
    88-89 Integra -the Integra pan will only work if you also use the Integra oil pump pickup
    88-91 CRX/Civic -the 88-91 CRX/Civic Si D16A6 oil pan works without changing the pickup
    the D16A1 pan is slightly deeper than the D16A6 and requires 1/2 quart more oil
    Brand—–Part#
    OEM #
    Oil Pan Gasket
    Brand—–Part#
    OEM - 11251-P01-004
    FELPRO - OS30542R
    ROL - OS5725
    _________
    Oil Filter
    The S2000 OEM Filters will work also and are made by a reputable company in Japan that makes high performance oil filters, but you will pay more for them.
    MY Suggestion…Get OEM Its only a couple bucks so why buy others when you can have a OEM filter for mostly the same price.
    Brand—–Part#
    OEM -
    STP - S2808
    FRAM - PH6811
    K&N - HP-1004
    MOBIL - M1-104
    ______________
    Connecting rods
    But any D-series 1.6L rods will work for upgrading.
    ______________
    Pistons
    88-89 Integra OEM
    the std bore on a zc is 75mm so anything with that bore would work. a6,z6.ect. will work as long as it's a 75mm. but it depends on the compression you want to run.
    There are many companies that offer ZC specific Pistons now, so Aftermarket is there.
    ______________
    Main & Rod bearings and thrust washer bearings
    ______________
    Piston Rings
    88-91 Civic/CRX // 86-89 Integra
    ______________
    Engine and tranmission Mounts
    1988 - 1991 CRX/Civic (All trim levels)
    Brand—–Part#
    OEM - 50810-SH3-040 (Rear, Firewall Mount)
    OEM - 50805-SH3-040 (Transmission Mount)
    OEM - 50821-SH3-040 (Side Mount, By Timing Belt)
    OEM - 50840-SH3-000 (Front Mount)
    __________________
    Click here to go to the store!!!
    !!click here to customize shirts!!
    Remove Advertisements Sponsored Links
    D-series.org
    Advertisement
    05-28-2008, 07:15 PM #2 (permalink)
    panda
    wise in the ways of the D
    Modifications:
    Throttle body:
    is the same as the 88-91 CRX/CIVIC SI D16A6..... 55mm
    b18b 58mm throttle body on a obd1 zc, it bolts right up but you need to port match the manifold to the throttle body
    camshaft:
    HKS makes cams for the ZC, here are the specs, 256 degrees intake and exhaust duration, 5.95mm Intake lift, 5.3 mm exhaust lift, they are ground from new billets.
    headers/exhaust manifold:
    The exhaust manifold for Greddy Turbo kit for the 92-95 Civic, was originally designed for the ZC. Greddy modified the casting tool for the D16 ports, so there is plenty of material to safely port it back out to ZC sized ports. However, the guys at greddy say don't bother until you are running over 7 psi.
    " The scoop on the headers, is that while the bolt pattern for the Civic SOHC engines and the ZC engines are identical, the port pattern is not. The ZC engine has the ports shifted almost 3 mm (appx 1/8"). In real terms, this means that when you use the SOHC header, the ports do not align properly. The exiting exhaust gases literally run into one edge of the misaligned header flange. You can see this by holding the steel exhaust gasket from the ZC engine up to the DC header.
    The easiest and best solution is to use the ZC gasket as a template and mark the misalignment. Using an air grinder, with a small stone "port" the header to match the ZC port configuration. While you're at it clean up the entry point of the header a little so that the whole port on the header is slightly larger than the ZC port. It is an old, but proven trick that the larger header port decreases the chance of exhaust gas reversing flow and re-entering the still open exhaust valves. It is better to have the port larger than to have them matched identical. Do not under any circumstances grind the port on the head to match the header though. This gives poor results."
    adjustable cam gears
    you can use B-series cam gears on the DOHC ZC, however, the marks for aligning the camshafts on the B-series gears are not the same as on the ZC gears - the B-series gears have 16 teeth between the teeth with the marks, on both the top and bottom of the gear - the ZC gears have 15 teeth between the teeth with the marks on the top side of the gear and 17 teeth between the teeth with marks on the bottom side of the gear - to use the B-series gears on the ZC, the mark on the left side of the gear for the intake cam is o.k., but the mark on the right side of the gear for the exhaust cam is one tooth off - you need to scribe a new mark on the next tooth above the tooth with the mark for the B-series and use that new mark for lining up the camshafts - here is where the new mark goes:
    ZC Swap Links
    links are from fourth Gen Hatch all these wright ups are made by that dude.. ive used them and know they work. he has alot of good tips aswell.
    Mpfi swap
    http://www.fourthgenhatch.net/mpfi.html
    Dohc Swap
    http://www.fourthgenhatch.net/zc.html
    3G ZC Swap
    You need an 87 Integra parts to run an 87 F.I. ZC motor:
    ECU
    Axles
    Distributor
    tranny (waayyy better than a 87 ZC tranny (longer gearing))
    tranny mount
    shift linkage
    hub & spindle assembly.
    If you can get a Japanese ZC ECU get it!! I had it, it runs good at
    idle. The 86-87 ECU tends to run a little rich at idle (stinky fumes
    emmitted), the ZC ECU fixes that
    & runs a bit smoother (way less fumes).
    89 Integra valve seals DO FIT a ZC
    almost all Integras have the same size valve stems dia. approx 6.6mm. My Helm book for 89 Integra confirms this, it says 6.56mm-6.52mm. My other Helm book for the 91 Civic says that the SOHC engines have 5.46mm-5.42mm valve stems.
    I removed my exhaust manifold (again) and stuck a pair of dividers in the port to get a measurement. I did not use the most exact method because my dividers had straight legs instead of the ones where the tips curve in (wouldn't fit in the port). I then measured them with my calipers and got 6.5mm! I would say that that is pretty close.
    I also got to thinking, if it was thought that the Teg had the 5.5mm valves, somebody would have noticed that when the valve seals were being installed. I'm sure that the machine shop would have given me a call to let me know that I got the wrong seals, that is quite a bit of slop for a "seal". So after all this, the 89 Teg valve seals DO fit a ZC.
    Transmissions:
    4 speed 88-91
    5 speed DX 88-91
    5 speed Si 88-91
    5 speed ZC 88-91
    ZC Pressure Plate:-----1989 Civic DX
    ZC Clutch Disk:-----1989 Civic DX
    the 89 DX and the 89,90,91 CRX use the same size shaft and same number of splines on the
    transmission. The 89 DX clutch disk and pressure plate is smaller in diameter by about one inch than the CRX Si. Although the flywheel is the same diameter on both. As long as you stay with one or the other it should work fine.
    I know these have been asked before, and I know they will be asked again,
    but here are a few ZC tranny questions.
    Questions
    Q-1.) For axles, I use the ZC halfshafts, 90-93 teg axles, and the 90-93
    axles fit on all the 4G hubs?
    Q-2.) Which clutch, preassure plate, and flywheel do I need? 90-91?
    Q-3.) Does Quaife make a limited slip that would fit the ZC tranny? Are
    the diffs in the ZC the same as in the other 4G's?
    Answers
    A-1) A better choice of axle would be two 88-91 Civic/CRX DX/Si right
    hand axles with 90-93 Integra inner joints. If you have a CRX HF or
    Civic Standard model a custom job is called for. OR you can use 88-91 DXSi knuckles and hubs and make your life simpler.
    A-2) The clutch should match the year of the transmission you have, 88
    if it is an 88 and your choice of 89 or 90-91 if the transmission is
    89 or later.
    A-3) Yes they do, I have one, it is not available through Autotech
    though.
    If the tranny is an 89 or later you may use a 90 91 clutch, pressure
    plate and flywheel.
    transmission gearing
    ZC: Si:
    1st: 3.250........ 3.250
    2nd: 1.944........ 1.894
    3rd: 1.346........ 1.259
    4th: 1.033........ .937
    5th: .878........ .771
    final 3.888........ 4.250
    __________________
    Mobil gw sendiri pake ZC generasi ke 4..
    Sekarang buat yg pake ZC juga ayo dong pada tunjukin mobilnya atau hasil korekannya..
    Gw juga lagi ngebangun Civic ZC buat time attack nih, dan gw lagi pusing nyari camshaft racing en intake karbu 4 barrel utk mesin ZC. Klo ada yg mau jual kabarin gw ya..
    20 Hrs 52 Mins 42 Secs
    Wah, kek na di indo mesin kek gini jarang de bos.
    Cm kurang tau jg y.
    Mesin ne lumayan bos setau sy temen da ikut drag pake mesin ne jg 201m dapet 10 kecil di body crx.
    Mesin na std ja, cm gnti koil luar.
    Sukses bos ma project na.
    2 Wks 2 Days 24 Mins 18 Secs
    wah zc dohc jarang bgt di indo..
    btw genio 2 doors yg di film the fast and furious 1 yg bajak trailer itu zc dohc yak? seinget gw genio 2 doors di amrik sering dibuat drag race baik resmi ato ilegal dan klo ga salah pake zc dohc
    Iya, banyak yg dipake balap liar.. Soalnya klo yg VTEC sayang klo VTECnya mesti dibunuh buat bisa pake cam derajat tinggi.. Tapi gw liat di modcom ada juga beberapa orang yg pake mesin ini deh, terutama yg main gaya JDM..
    Quote Originally Posted by Mas Seto View Post
    biasanya di indo zc yg sohc pak bukan yg dohc..TS nya kan bahas zc dohc
    klo zc indo sih kan dpasangin head p08 biasanya
    Palembang.
    6 Days 10 Hrs 51 Mins 52 Secs
    Dlu temen ada pake di genio, gw bengong waktu dia bilang baru gnti mesin honda 1600 DOHC NON VTEC!
    Eh baru tau gw zc non vtec ada yg DOHC ehehehe
    Waltu itu spec mesin cuma modif stage 1.
    Tenaganya lumayan kok
    Emg si kayaknya di indo nyari barang2 kompetisinya dikit
    Tp kalo diluar smestinya banyak.
    Si bos gk coba cari info2 disana?
    Soalnya gw nonton di utube ada lumayan bnyk mbl2 honda disana yg kenceng2.
    di amerika sampe ada kelas khusus zc hehe
    pernah gw liat mtv ada cewe' dibedah rumahnya sama cowo2 tuh cowo' kaget liat tuh cewe punya genio or eg9 2 doors zc engine buat balap liar dsana
    yog "all around" ya
    1 Day 12 Hrs 5 Mins 33 Secs
    ni mesin asoy lho....pernah nyoba zc dohc gen 2 std abis pake karbu maestro buat harian enak bgt....klo gak salah yg jd inceran tuch gearbox nya seri L3 klo g salah,mainin d final 4.4 dah sip...tp y itu spare part racing nya susah beeng....org2 mending pake SOHC or malah naik Bseries skalian....kir2 bgtu....
    final gear civic jdm kan 4.4
    kpn hari ada yg jual di bursa 2.5 jt klo ga salah
    yog "all around" ya
    Quote Originally Posted by Uber Alles View Post
    jdm blm tentu final 4.4.....tp yg d cari tuch ratio gigi 1-3 jdm d padu ama final 4.4....yg pnya rtio bags y gearbox ini zc dohc,utk ukuran standar....CMIIW
GT Radial MBtech
  1. yang pake stiker bom share foto2nya disini yuk
    By andre_squad in forum Diskusi Otomotif Lain-Lainnya
    Last Post: 28th October 2012, 16:42
  2. Yang Pake Solunashare disini ya...
    By sayasurya in forum Automotive
    Last Post: 28th February 2011, 15:59
  3. FS MESIN HONDA ZC DOHC S.E.
    By jero in forum Jual Beli Mesin Lainnya
    Last Post: 18th November 2010, 11:07
  4. FS mesin Honda ZC 1.6 DOHC
    By hendrabezita in forum Jual Beli Mesin Lainnya
    Last Post: 14th December 2008, 23:18
  5. yang pake Kuda kita sharing disini
    By tiesto888 in forum Diskusi Otomotif Lain-Lainnya
    Last Post: 3rd November 2007, 22:02
