Ada yg tau ini additive?
Results 1 to 9 of 9
  • Short URL:  http://modifika.si/19487
    BROQUET 70rb ASLI 100%!!!
    11 Hrs 23 Mins 8 Secs
    Apakah barang2 dibawah ini bisa menggantikan "racun" diesel?
    ANTI-BACTERIAL ADDITIVE
    Liqui Moly Anti-Bacterial Diesel Additive contains a highly active biocide with a wide activity spectrum against bacteria, yeasts and moulds. The biocide does not form any corrosive combustion products and has been tested by leading engine manufacturers.
    SYSTEM CARE-DIESEL
    Protects the components of the fuel system (especially Common Rail Diesel) against wear, corrosion and deposits. Increases the lubricating action of Diesel fuel.
    DIESEL ANTI-KNOCK
    Contains Cetane boosters and special lubricants to give Diesel engines improved combustion, smoother performance and more economical operation. Reduces maintenance costs and pollution. Cleans the injection system and protects from contamination and corrosion. Improves the lubrication action of diesel fuel and protects injector pumps from wear.
  2. clickbet88.com
    1 Day 19 Hrs 38 Mins 25 Secs
    sori bos ini maksudnya jualan apa nanya apa ngasih info?
    thanks..
    nanya nih, siapa tau ada yg tau infonya bisa kasih tau saya
    siapa tau bisa gantiin racun diesel gitu (additive solar)
    wah ternyata ga ada yg tau
    tariikk...
    1 Mth 5 Days 6 Hrs 5 Mins 57 Secs
    Kl dari terjemahan nya sih 3 barang tersebut aditive, hanya berbeda sifat nya aja..
    makanya bingung... apa ini bisa gantiin racun yg buat solar?
    more info?
Datsun 300x250 MBtech
  1. Campuran Additive BBM
    By acadia in forum Diskusi Mesin
    Last Post: 27th August 2008, 23:57
  2. Best oil additive...
    By Aerio_standard in forum Diskusi Otomotif Lain-Lainnya
    Last Post: 21st May 2006, 05:28
  3. Oil additive
    By andreas in forum Diskusi Mesin
    Last Post: 7th October 2005, 12:00
