Fountek FR88EX fullrange cuman 700 ribu!!!
Page 1 of 5 12345 LastLast
Results 1 to 10 of 44
  • Short URL:  http://modifika.si/193493
    jakarta selatan
    3 Days 2 Hrs 6 Mins 55 Secs
    Jual cepet aja Fountek FR88EX cukup 700 ribu aja lg bth duit nihhh kondisi dustcap kepencet dikit tapi "SAMA SEKALI TIDAK BERPENGARUH KE SUARA" again cuman fisik aja
    By jlu_mike at 2010-03-05
    ayo cuman 700 ribu aja udah nett!!boleh cek harga barunya hampir 2 juta
    sms ke 0817 917 3357
    Feature
    * Low distortion, long linear excursion
    * Die cast chassis, aluminum cone
    * 25 mm voice coil, copper ribbon on aluminum former
    * Underhung voice coil
    General description
    Overall Dimensions 88.4X52.4mm
    Net. Weight 0.58Kg
    Nominal Power Handlng 15 W rms
    Nominal Impedance 8 Ohms
    Sensitivity 1W/1M 84.4dB
    Frequency Response 95-32,000Hz
    Resonant frequency 95Hz
    Magnet System
    Magnet system type Neodymium
    Magnetic Gap Height 10mm
    B Flux Density 0.88T
    Bl Product 3.313Tm
    Max Linear Excursion 3mm +/-
    Voice Coil
    Voice Coil Diameter 25mm
    Voice Coil Height 4.0mm
    Voice Coil Former aluminum
    Voice Coil Wire Copper ribbon
    Number of Layers 1
    DC Resistance 6.0 Ohms
    Levc @1KHz 45uh
    T/S Parameter
    Cms 1.212mm/N
    Sd 27.34cm^2
    Vas 1.286L
    Mmd 2.182gm
    Mms 2.264gm
    Qms 2.346
    Qes 0.722
    Qts 0.552
    Suggested box (for fullrange use):
    0.75 liter (46 cubic inches) sealed and stuffed for an F3 of 150Hz
    1.5 liter vented (92 cubic inches), stuffing, 1" diameter vent x 3" long, F3 90Hz
    Jkt - Kisaran JakBar
    38 Mins 13 Secs
    70K, Mika
    kabur ah, sblm disambit bata
    jakarta selatan
    Talking
    Quote Originally Posted by Wellman78 View Post
    70K, Mika
    awkakakakakak 70 g kasi grillnye aj deh bro,
    jakarta selatan
    Lego Brg Ga kepake nih ad 2 buah kabel RCA 5 Meterrr penampakannya ky gni
    By jlu_mike at 2010-06-09
    -Finest End Audio Grade LGC (Long Grain Cooper)
    -100% Shield Coverage Mylar Alumunium Wrap
    -Natural Cotton Suspension
    -Low Capitance Flexible Polipropylene
    -Superb Suounding Gold Plated Connectors
    This Feature Will Brings More Clarity, Detail, Imaging, Sound-Staging, Accuracy and Musicality to your System
    Kontak ke 0817 917 3357
    CUMAN 200 RIBU AJA SIAPA CEPAT DIA DAPAT!!!!!
    jakarta selatan
    Expert Series Audio Interconnects
    Directed Audio Essentials Expert Series offers the ultimate in high-end signal transfer, with black chrome metal ends, black chrome splitters and the finest twisted pair construction.
    • 99.9 percent pure oxygen-free copper stranded cable
    • Twisted pair signal path construction
    • Directional coaxial drain shield design
    • Shunts induced noise to ground
    • Provides maximum noise reduction
    By jlu_mike at 2010-07-21
    Cukup ditebus dengan 325 Ribu aja NETT!!!
    Panjangnya 5 meter barang cuman ada 2 pcs
    hub ke 0817 917 3357
    jakarta selatan
    Jual ampli Keren Dan Mantapppp U Dimension GLOW Series (220W/2ch)
    Pemakaian Baru 3 bulanan brg masih Mulusssss abissss
    By jlu_mike at 2010-06-28
    Barang Aslinya
    Spoiler for GLOW: Show
    Keterangan Lebih Lanjut bisa meluncur ke websitenya
    http://www.u-dimension.com/com/glow_glow2075.htm
    Barunya 2.5 JUTA gua jual cuman 1.4 juta aja siapa cepat dia dapat!!!
    HUB 0817 917 3357
    jakarta selatan
    uppppppppppppppppppppppppppppppppp
    4 Days 9 Hrs 9 Mins 52 Secs
    GPL 400k gan
    jakarta selatan
    Quote Originally Posted by ROCKFORD FOSGATE View Post
    GPL 400k gan
    ga dpt gan
    jakarta selatan
  1. ((( JUAL ))) FULLRANGE FOUNTEK FR89EX
    By mulyadi in forum Speaker - SubWoofer
    Last Post: 25th September 2012, 01:10
  2. WTS : Speaker Fullrange 3" Fountek FR88EX 2nd
    By cipto_ng in forum Speaker - SubWoofer
    Last Post: 8th December 2011, 16:44
  3. WTS : Speaker Fullrange Fountek FR88EX
    Last Post: 22nd September 2011, 16:44
  4. fountek fullrange vs domination futura
    By yudhi_cassanova in forum Diskusi Speaker
    Last Post: 13th June 2011, 13:49
  5. Fountek FR88EX
    By jlu_mike in forum Speaker - SubWoofer
    Last Post: 14th May 2010, 07:19
