FS: New Okuyama Carbing for GE8 All new jazz (Rear frame brace + Rear Lower arm bar)
Results 1 to 5 of 5
  • Short URL:  http://modifika.si/193134
    1 Wk 3 Days 12 Hrs 43 Mins 28 Secs
    FIT GE8 Frame Brace / Rear
    By davinelika at 2010-05-31
    ・Hatchback vehicle, combining the weak side of the rigid rear opening. Occur when changing lanes and insecurity in a deep rut, and reduce the feeling of lightheadedness occur when inches up.
    ・Shapes together by welding a bar and bracket, and further pursuit of weight and strength.
    ・Mounting bolt is.
    After installation, all interior undo.
    Material・STEEL, use a high torsional rigidity Obarushafuto. (Diameter pipe ends 20mm 40mm) white color, is scratch resistant baked粉黛.
    FIT GE8 Lower Arm Bar / rear
    ・Arm bar connects the left and right, provide rigidity and structure of the bracket by welding together.
    Hold the twist of the suspension member・cornering, reducing the change in alignment.
    ・The pipe ends are used Obarushafuto high torsional rigidity. (Diameter pipe ends 20mm 40mm)・
    The material is steel, white color, is scratch resistant baked粉黛.[hr]
    Tinggal ada 1 set nih.. UTK GE8 Aja ya .... dijual sepasang ya.. rp 2.500.000
    kalau berminat bisa kontak DAVIN di 081932574323
    Racechip Indonesia / Elika Automotive Performance / Simota Racing Sport/ EP Tune
    Jalan Taman Sari raya, komplek ruko 56 blok B no 97
    upppppppppppppppppppppp
    upupupupuupppppppp
    Bintaro,Tangerang
    3 Wks 8 Hrs 6 Mins 35 Secs
    carbing frontsturbarnye sabtu yah,vin...dagangan lo serem2dah,vin,,heheheh
    dibeli dong dra... hehehehehe
MBtech Mega Glodok Kemayoran
  1. Replies: 8
    Last Post: 20th September 2012, 09:57
  2. EG Estilo Genio JDM rear down brace Carbing
    By D21FT in forum Bursa Kaki Lainnya
    Last Post: 7th April 2012, 09:11
  3. WTS: Okuyama Carbing Front Lower Arm ORI Japan !!
    By AndreNCP91 in forum Bursa Kaki Lainnya
    Last Post: 23rd June 2011, 14:35
  4. For Sale: Okuyama Carbing Front Lower Arm ORI Japan !!
    Last Post: 16th June 2011, 20:44
  5. WTS:: FRAME BRACE,LOWER ARM BAR CARBING UNTUK SUZUKI SWIFT
    By usernamee in forum Per & Shockbreaker
    Last Post: 6th April 2011, 19:29
