MRAF350 - Alpine MRA F350 5 Ch 50W x 5 RMS Digital Processor Theater Amplifier..sold
Retail Price : $549.99
Features:
* 5-channel Digital Theater amplifier
* 50 watts RMS x 5 at 4 ohms
* Dolby Digital, DTS, and Dolby Pro Logic II processing built-in
* optical digital input
* connects to compatible Alpine navigation systems
* MOSFET power supply
* CEA-2006 compliant
* Bass Engine® features:
o variable center-channel high-pass crossover (20-400 Hz in 1/3 octave steps, 6/12/18/24 dB per octave)
o variable front left and right high-pass crossovers (20-200 Hz in 1/3 octave steps, 6/12/18/24 dB per octave)
o variable rear left and right high-pass crossovers (20-200 Hz in 1/3 octave steps, 6/12/18/24 dB per octave)
o sub channel preamp output (20-200 Hz low-pass filter, 6, 12, 18, or 24 dB/octave)
o variable subsonic filter (20-50 Hz in 1/6 octave steps, 6/12/18/24 dB per octave)
o subwoofer phase control (0/180 degrees)
* time correction adjustment (0-10 mSec)
* 17-band parametric EQ
* STAR Topology
* detachable front cover
* blue power LED
* fuse rating: 20A x 2
* 8-gauge power and ground leads recommended
* 13-3/4"W x 2-1/4"H x 9-9/16"D
MRAF350 - Alpine MRA F350 5 Ch 50W x 5 RMS Digital Theater Amplifier
Alpine has now made it possible for you to experience multi channel DVD sound quality in your vehicle. The new Alpine MRA-F350 which is a five channel digital theater car stereo amplifier is controlled by a well-matched in dash car stereo from Alpine. This car audio amplifier is designed to offer you full multi channel sound quality along with stunning realism. The digital design of the amplifier provides 50 watts to each of the channels, as it supplies plenty of clean power to the rear, front and center channel speakers of your car stereo.
The subwoofer preamp output carries to the low frequencies to your subwoofer amplifier. You just have to connect a digital sound like a game system or a DVD player to the optical digital input and the internal processor of the amplifier would convert the digital information into surround sound. An added advantage is that the amplifier includes an in built Dolby Pro Logic II processor that provides realistic multi channel sound to the standard car stereo CD player.
Apart from the low pass crossover, there is also an subwoofer output subsonic filter. You can easily measure the frequency that ranges from 20-50 Hz in a 1/6 octave steps only with a selectable slope of 24, 18, 12 or 6 dB octave. The output of the subwoofer is a line level signal with a subsonic filter and a low pass crossover. The Alpine MRA-F350 amplifier is designed with a parametric equalizer that has a total 17 band. These are divided like five for the center, five for the rear, five for the front and two for the subwoofer. The amplifier is also designed with an optical digital input that can be used with digital sources like game systems or DVD players.
The most important point to note is that this Alpine MRA-F350 amplifier requires a compatible alpine stereo for the set up and control. The best compatible alpine head units for the amplifier are DVA-9965, DVA-9861, DVA-9860, IVA-W205, IVA-W200, IVA-D901, IVA-D310, IVA-D105 and IVA-D100.
