CLARION DXZ-676USB kondisi muluuus n segel........(soldmthanks modcom......)
Results 1 to 10 of 11
  • Short URL:  http://modifika.si/192787
    CLARION DXZ-676USB kondisi muluuus n segel........sold
    Digital sound has never sounded so good. With Clarion’s Sound Restorer signal processing and a 24-bit DAC - the result is music so pure, so detailed,
    it will be like it’s the first time you’ve heard it.
    Experience your music like never before
    * CD-R/RW ready
    * MP3, WMA and iTunes® AAC compatible with ID3-TAG display
    * Rear USB connector
    * Maximum track capacity: 65,025 (255 tracks in 255 folders)
    * 18 FM, 6 AM station preset
    * iPod® control capability via optional EA1276
    * Subwoofer volume control
    * 24-bit D/A converter
    * Sound Restorer
    * Digital Z-Enhancer sound customisation
    * 2-band parametric equaliser
    * MAGNA BASS EX dynamic bass enhancement
    * Built-in High-pass filter & Low-pass filter
    * 4-channel × 53 watts of MOS-FET amplification
    * Motorised sloping console
    * Full dot display with Screensavers
    * "SLIDETRAK" for dynamic operation
    * Mobile Phone input and mute
    * Auxiliary Input with level control
    * 6-volt/6-channel audio pre-out
    * CeNET Control of: DVD changer, TV tuner, 6-disc CD changer, and iPod
    * AUX Bluetooth transceiver BLT370 ready
    * OEM steering wheel remote wired interface capability
    * Detachable control panel
    24-Bit D/A Converter
    Conventional D/A Converters just can’t compare to Clarion’s 24-Bit DAC with Noise Shaper. The result of years of engineering, this new D/A features a 24-bit D/A Converter combined with incredible 128x over sampling to realise detailed high frequency reproduction and incredible S/N ratios. Experience your favourite music like you’ve never heard it before.
    Sound Restorer
    Hear your music the way it was meant to be heard. Clarion’s Sound Restorer recreates the high frequency information that is lost during compression. The result is clear and detailed sound - the way it was meant to be heard.
    Bluetooth® Ready
    Talk on your mobile phone or enjoy your favourite album - wirelessly. Simply connect the BLT370 Bluetooth interface to your DXZ676USB for high quality, wireless audio.
    MP3/WMA/iTunes® AAC Compatible with ID3-TAG Display
    Formats like MP3 and WMA, are said to be the de facto standard for compression, as well as AAC with higher compression ratio are supported. This facilitates enjoyment of music data downloaded from music stores on the internet. The ID3-TAG display function offers information about the song title, artist, or album name on the screen of your Clarion source unit.
    Full-dot LCD Display
    The HMI display in the DXZ676USB features a full-dot LCD designed to provide information that is easy-to-read and incredibly detailed.
    Digital Z-Enhancer
    Clarion’s Digital Z-Enhancer controls P-EQ, HPF, and LPF through the DSP, allow you to select from three equalising patterns that emphasise the range of tones in the upper/base regions respectively while maintaining perfect acoustic balance. Furthermore, by adding gain adjustment (HI, MID, LOW) to the 3 equalising patterns, it is now possible to choose from 9 different equalising patterns to customise the sound quality so that it matches your speaker system or music source perfectly.
    4 × 53W MOS-FET Power Amplifier
    MOS-FET chips, known to have superior performance as power amplifier audio components, are employed in 4 × 53W high power amplifiers. MOS-FETs’ linear and low-distortion performance drastically improves S/N ratio at higher frequency ranges, which are more susceptible to noise, allowing the listeners to enjoy sound reproduction ever closer to the original sound as intended by the musician.
    CEA 2006 Power Ratings
    21W × 4RMS [4Ω@14.4V ≤1% THD+N]
    S/N 87dB (Ref:1W into 4Ω)
    TUNER SECTION
    Frequency bands
    FM: (MHz) 0.05MHz steps 87.5 to 108
    MW: (kHz) 9 kHz steps 531 to 1,602
    LW: (kHz) 3 kHz steps 153 to 279
    FM usable sensitivity (dBf) 9
    FM 50 dB quieting sensitivity (dBf) 17
    FM alternate channel selectivity (dBf) 75
    FM stereo separation @1 kHz (dB) 25
    FM stereo freq. resp. @ ±3 dB (Hz) 30 to 15,000
    CD SECTION
    Wow/Flutter (WRMS) Below measurable lmits
    S/N ratio (dB) 100
    Frequency response (Hz) 5 to 20,000
    Dynamic range (dB) 95
    Harmonic distortion (%) 0.01
    AUDIO SECTION
    Power output (DIN45324, +B = 14.4 V) 4 × 25 W
    GENERAL
    Dimensions (W × H × D), mm 178 × 50 × 158
    Remote control (W × H × D), mm 44 × 113 × 11
    Weight (kg) 1.6
    Power consumption: less than 15 A
    Speaker impedance 4Ω (4Ω to 8Ω allowable)
    Jak'z city
    4 Days 9 Hrs 40 Mins 36 Secs
    nett brp bos?
    pm sent bos,thanks.......
    yogyakarta,indonesia
    2 Hrs 33 Mins 34 Secs
    bedany ma 586usb ap boz??
    skalian pm harga net ny..tukar tambah bs??
    Bos, pm net harga sampe medan ya, thanks
    samai medan 1,35jt nett nya bos,thanks.......
    Garasi Hercules...
    Net
    Bos...SMS net ya...02132572707
    Pm sent bos,thanks...
    Net Price
    PM super net price nya ya bro...?oya kondisi optik masih ok kan?
Mega Glodok Kemayoran MBtech
  1. ALPINE CDA-9855 kondisi muluuus n segel..........(sold,thanks modcom...)
    Last Post: 5th March 2010, 10:45
  2. ALPINE CDA-9833 kondisi muluuus n segel.....(sold,thanks modcom....)
    Last Post: 28th December 2009, 13:39
  3. ALPINE CDA-9833 kondisi muluuus n segel...(sold,thanks modcom....)
    Last Post: 6th November 2009, 23:18
  4. CLARION HXD1 kondisi muluuus n segel.......(sold,thanks modcom...)
    Last Post: 27th June 2009, 00:44
