WTS BUTLER 2150 (MULUSSSSSS)
Results 1 to 10 of 10
  • Short URL:  http://modifika.si/192086
    2 Days 6 Hrs 11 Mins 14 Secs
    mau jual power butler 2150 mulus sekaliii... pakai dari baruu...
    baru gante tabung nyaa.. karena matii...
    TDB 2150
    T H E R M I O N I C
    Vacuum Tube Driven Mobile Power Amplifier
    DESIGN
    With authentic Vacuum Tube response and an open-ended design, (ZERO global negative feedback), Tube Driver BLUE overcomes one of the most universally agreed upon sonic problems plaguing virtually all current amplifier designs; harsh degenerative feedback causes a plethora of undesirable sonic products. Tube Driver BLUE eliminates global negative feedback entirely! Coupled with a totally unique output load mirroring circuit, the hand selected 6SL7GT twin triode tubes operate in a safe, near plate-saturated mode continuously. The design creates the ideal electrical environment for classic vacuum tube thermionic characteristics.
    PERFORMANCE
    Tube Driver BLUE amplifiers utilize natural vacuum tube thermionic emissions to automatically enhance biasing of the audiophile-quality Sanken bi-polar devices used in every model. This unique USA patented design reduces both Crossover and Total Harmonic Distortion (THD) figures to LESS than 0.15%. This achievement is almost unheard of in an open-ended, ZERO negative feedback high fidelity amplifier. Conventional open-ended/low feedback vacuum tube amplifiers often exhibit real world THD of 2% or greater and are generally limited to quite low output power. Tube Driver BLUE succeeds in operating at 10 times less THD while maintaining real power vacuum tube tonality! Now you can hear the original pure essence of vacuum tube audio with Tube Driver BLUE.
    PROTECTION
    All this performance must be effectively controlled. The exceptional electrical design of the Tube Driver BLUE, coupled with a MASSIVE aluminum heat exchanger and heat sink, provides protection and cooling capacity far in excess of any contemplated needs. A long life, temperature-controlled cooling fan is activated if the surface temperature exceeds 50 C, keeping heat stress well within safety levels. Additionally, DC fault protection with soft start (10-15 sec) and a fully regulated DC tube-heater supply circuit protect your Tube Driver BLUE amplifiers in every conceivable way.
    General features:
    ZERO negative feedback. No global negative
    degenerative feedback loop
    Open Ended Audiophile Circuitry
    Musical, warm and dynamic, rivalling "all-tube" single-ended home audiophile amplifiers
    Hand selected/matched 6SL7GT Twin Triode tubes
    (One per channel)
    Fully regulated Tube Heaters with Delayed Soft Start
    (10-15 second turn-on delay)
    Load Adaptive Vacuum Tube Driven output circuitry
    Massive (400% oversize) internal/external Heat Exchanger with Temperature-controlled Fan Cooling
    Tightly regulated MosFET Power Supply
    DC fault / Short Circuit Protection Circuitry
    Dual Color Diagnostic LED: Green=Normal / Red=Fault
    Gold Plated RCA, Power and Speaker Connectors
    Frosted Platinum finish
    Tube Illumination: Internal BLUE LEDs
    Patented Design
    Concept & Design: BK Butler / USA
    Specifications:
    Rated Power (all channels driven):
    2 x 150 Watts RMS per channel @ 4 ohms
    1 x 500 Watts RMS Bridged (Mono) @ 4 ohms
    2-Ohm Stereo, 4-Ohm Mono Stable
    Freq response: 5Hz to 100kHz (+/- 1dB)
    THD: <0.15% (30kHz bandwidth)
    S/N Ratio: >110dB (A-Weighted)
    Idling Current: 2.4 Amps
    Input Sensitivity: .450v - 12v RMS
    Fuses: 2x25A ATC
    Dimensions: 10.25"W x 17.3"L x 2.4"T
    Weight: 12 Lbs.
    ini pic nya,,
    mau jual: 4.25 jt.. negoo....
    hub 089 88888 616
    Jakarta Utara
    4 Days 19 Hrs 56 Mins 38 Secs
    bro tabungnya ganti apa? dan gantinya ama siapa? thx
    Quote Originally Posted by franzcul View Post
    gantu stg broo.. yg lama rusakk.. hehe...
    uppppp
    uuupppppppp.....................
    up up up up up up......
    up.. up.. up.. up..
    up.. up.. up.. up..
    up.. up.. up.. up..
    Ground Wire - Serpong
    2 Hrs 4 Mins 53 Secs
    wah sayang bro ya tubenya, kok ga cari sama yg pair 6SL triode ori nya?? masa ga nemu?? Pake brp lama tuh bisa mati tubenya (dua2 mati atau satu bro) ?? thanks.
    Quote Originally Posted by indosg View Post
    itu pair koq tabung, kna pake yg std.. hehe...
    mati satu tube na.. pake uda 2 tahun.. wajar lah..
  1. wts: b u t l e r tdb 2150
    By leon9 in forum Power Amplifier
    Last Post: 9th August 2012, 21:09
  2. AMPLIFIER : BUTLER TUBE DRIVER BLUE TIPE TDB 2150 (Bekas)
    By SpeakerStore in forum Power Amplifier
    Last Post: 7th October 2011, 16:56
  3. Replies: 78
    Last Post: 20th March 2010, 00:41
  4. Butler Blue Tube Driver TDB 2150
    By Pioneer22 in forum Power Amplifier
    Last Post: 5th November 2009, 21:04
  5. Replies: 1
    Last Post: 10th June 2009, 22:15
