Digital Design DD512b (2 pcs) + Alpine PDX 1.1000 on sale!
  • Short URL:  http://modifika.si/191833
    www.belanjaaudio.com
    8 Hrs 12 Secs
    Digital Design DD512b (2 pcs) + Alpine PDX 1.1000 , only 7 juta (was 11 juta)
    http://www.belanjaaudio.com/promolist/combodeals
    Call / SMS 081 56 0866
    Digital Design DD512b Specification :
    * Optimized for 100-300 watt systems
    * Multi-layer spiders
    * Laminated surround
    * Double stack magnets
    * High-temp voice coil
    * Laminated tinsel leads
    * Hand-built quality
    * Rubber Magnet Boot
    The newly upgraded 510b and 512b subwoofers bring DD impact and durability to the most affordable price ranges we've ever offered. You still get the hand built, high performance quality at a price within every budget. The 500b Series was designed to optimize performance from amplifiers in the 100-400 watt RMS range. Not everyone is going to try to crush their tonsils with the latest bass-jacked MP3, but that doesn't mean one should have to settle for lower quality parts or design.
    The 500b series woofers benefit from the highest quality parts available, close production tolerances, and hand built quality as do all DD woofers. The motor and moving systems have been designed to get higher efficiency from lower powered systems. We found ways to reduce mass from the cone, surround, spiders and voice coil which raises the efficiency on a given level of power. The suspension stiffness and excursion capability were carefully dialed in through many real world test samples. The result is a very fast woofer capable of delivering surprising output from modest power sources.
    The 500b Series feature multiple layers of durable cloth in the spider system, our exclusive laminated lead wires into the spider layers, double laminated half-roll surround, non-pressed cone and a motor system modeled after the 3500e Series woofers. The 510b and 512b are very easy to use in vented, TLs, and specialized band-pass boxes and are the perfect presents in gift boxes. Now there aren't any excuses to get anything less than a DD system in every car.
    SPECIFICATIONS
    Voice Coil Diameter 2.0"
    Magnet Weight 90 oz
    Power Handling RMS/Peak 300/1200
    Suspension 50 mm
    Nominal Impedance 4.0 Ohm
    DC Resistance 3.4 Ohm
    Model 510b 512b
    Rec Box (cubic ft) 1.5 2.5
    Port Area (sq in) 24 40
    Port Length (inches) 23 22
    Woofer Diameter 10" 12"
    Free Air Resonance
    38 Hz 36 Hz
    Qts 0.405 0.433
    Qes 0.461 0.499
    Qms 3.29 3.29
    Vas 23L 60L
    Sensitivity 86.5 dB 89dB
    Shipping Weight 13 lbs 14 lbs
    Online Shopping For Car Audio & Video
    Latest news on BelanjaAudio.Com , visit our thread
    http://www.modifikasi.com/forumdisplay.php?f=190
    Showroom : Jl. Mayjen Sungkono 176 - 178 , Ruko Grand Sungkono B-3 , Surabaya
    Call/SMS @ 081 856 0866, YM: infobelanja@yahoo.co.id, FB: www.facebook.com/belanja.audio
    Talking yes``
    [url=http://www.pascherfrancais.com/portefeuille]Portefeuille pas cher[url] Portefeuille pas cher, [url=http://www.pascherfrancais.com/portefeuille/chanel-portefeuille]Chanel Portefeuille pas cher[url] Chanel Portefeuille pas cher, [url=http://www.pascherfrancais.com/portefeuille/coach-portefeuille]Coach Portefeuille pas cher[url] Coach Portefeuille pas cher, [url=http://www.pascherfrancais.com/portefeuille/dportefeuille]D&G Portefeuille pas cher[url] D&G Portefeuille pas cher, [url=http://www.pascherfrancais.com/portefeuille/dooney-bourke-portefeuille]Dooney & Bourke Portefeuille pas cher[url] Dooney & Bourke Portefeuille pas cher,
    karawaci
    anjrit DIGITAL DESIGN!!!!!!! kok ga ada yang ambil yah?????
    uda tinggal dioper neh ke mobil lain.......anjrit.....
    kondisi brp persen neh.....
    anyway....lo salah masuk kamar bro........hahahahhaa
  1. Digital Design
    By R35 in forum Diskusi Subwoofer
    Last Post: 14th February 2012, 17:20
  2. Alpine PDX-1.1000 Monoblock On Sale
    By belanjaaudio in forum Diskusi Power Amplifier
    Last Post: 16th March 2010, 00:49
  3. digital design
    By yudi setiwan in forum Diskusi Subwoofer
    Last Post: 2nd November 2009, 01:05
  4. digital design
    By We5t-Co4st in forum Diskusi Subwoofer
    Last Post: 17th October 2008, 02:04
